2nd worse antenna
It was almost the worse antenna tested. But the stock antenna that came with the dongle was a bit worse.
Second place was won by a telescoping antenna, adjusted to 190mm.
I think the reason this one is better than the (mag-mount) stock antenna, is the LNA.. (see pic).
I can't wait to install a real antenna, outdoors on the tower. It will be a bit over 30 feet. (10 meters).
The view from up there is great. I should have taken a camera. ;)
