sergsero
Version 20140905: acarsdeco2_windows_20140905.zip https://drive.google.com/file/d/0B7NYXizl0U6iSDQ1VklhbVVaSXc/edit?usp=sharing
+ Modified algorithm for determining multiple instances of RTL devices with different serial numbers, that are simultaneously connected to the computer.
Now if program was run with the option --device-list, it's allows you to determine the connected devices with their serial numbers:
To run multiple copies acarsdeco2 with different dongles, you need to specify the it unique serial id number in the option --serial-number for each program:
If some dongles (s/n 15) already in the works, this will be indicated:
When you try to run the program with dongle, which is already used (s/n 15), you will receive the following message:
sergsero
sergsero
