The output port of the directional coupler must be connected to a measurement device. I'm using a diode detector on mine. The diode feeds a DC voltmeter, to give me a relative measurement of the reflected power (SWR). It's really very crude, but works fine..
If you wanted to, you could connect the measurement port to a spectrum analyzer. Like this YouTube guy did..
If you are measuring 1090 Mhz antennas... Just use one of your RTL SDR sticks and get your return-loss measurements in dB off your computer display..You can make your generator sweep-step, and your PC will act like a spectrum analyzer.
It will show you where the antenna is resonating best..
One other thing you will need is a good 50 ohm load.. If you are using 75 ohm coax and testing 75 ohm antennas, get a 75 ohm load..
Before connecting your antenna to a test cable, install the dummy load on the end of the cable..
Just about 100% of the RF into the load will be absorbed (turned into heat).
So, the test port should be showing zero power out (or close to it) with the load installed..
Then remove the load and note the Return loss reading (it will be very high), before you install a test antenna..
The power reflected back(SWR-Return Loss) from that antenna will be flowing out the monitor port of the Directional Coupler. A really good antenna will look like the test load.
To make accurate measurements of Return Loss, you can reverse the RF in-out ports on your Coupler, and take a relative measurement in both directions. Then, do the math..
I never do it that way.. I just try to tune the antenna (or filter) to the lowest possible return loss and then test it for function. Comparing it to another (known good) antenna..
