Did some testing this afternoon.. I checked the 300mm 1090mHz antenna that's installed on the tower.. Still working fine..
The testing with both Open and 50 ohm load was pretty good. The only weak area was up at 2400 mHz.
Not sure if the amp gain is too low, or if the signal generator output is low, or if the new directional coupler is more lossy at 2.4 gHz.
I did not use the either one of my portable frequency counters with this setup.
I found the numerical readout of the VOM was super stable, repeatable and easier to use.
I'll be using the counters when I do near-field directivity testing.
Notice the 100 mHz test.. I know that's below where the directional coupler should be working, but it seemed to indicating it was showing return loss.
I'll have to use it to test a TV antenna, to see if it's really working that low. That 2-stage amp is using 3.3vdc. My 5V supply had a problem.
