Again I refer to this diagram. Can someone help me understand what length L refers to? As in, L = 234/1090 Mhz = .2146 (presumably meters, or 214.6 mm). On one side of the diagram they show λ/4. On the opposite side L=234/f(MHz). I could take that to mean that L = λ/4, but that makes no sense when we know that λ/4 of 1090 Mhz is 69 mm. :confused: Without L=234/f(MHz) the diagram makes sense to me.
L = 234/1090 Mhz = .2146 feet = 0.2146 x 12 inches = 0.2146 x 12 x 25.4 mm = 65.4 mm
Confusion caused by ARRL diagram not mentioning units. They take for granted that every one in the world uses FPS (foot, pound, seconds) system.
@giacomo1989: I think I'll make one with a 69 mm balun. Then I can always shorten it if I need to. By the way, in your post #2131 above, did you notice the two diagrams show different techniques for attaching the baluns?
Hi ab cd. After Giacomo wrote that I remember that ARRL uses feet and inches, right? Why do you think they compute 65.4 mm instead of 69 mm for 1/4 wavelength?
ETA: Maybe ARRL uses the Imperial speed of light vs. Metric speed of light. :D
I think you're right. 234/1090 = 0.21467 X 12 (inches) = 2.576 inches = 65.43 mm. Close to 69 mm, but not exact. :)
Wavelength (meters) = Speed of Electromagnetic waves in meters per sec/frequency in Hz
Wavelength (feet) = Speed of Electromagnetic waves in feet per sec/frequency in Hz
Speed of electromagnetic waves is same as speed of light, as light is also electromagnetic wave.
The speed of light (MKS or SI or Metric units) = 299,792,458 meters/sec
The speed of light (FPS or Imperial units) = 186,282 miles/sec = 983,571,056 ft/sec.
For practical purposes, these figures can be rounded to:
300,000,000 meters/sec
984,000,000 ft/sec
Hence:
Wavelength in Metric (MKS/SI) units = 300,000,000/ MHz x 1,000,000 = 300/MHz (meters)
Wavelength in Imperial (FPS) units =984,000,000/ MHz x 1,000,000 = 984/MHz (feet)
1/4 wavelength in meters = 1/4 x 300/f (Mhz) = 75/f (Mhz)
1/4 wavelength in feet = 1/4 x 984/f (Mhz) = 246/f (Mhz)
The ARRL Book uses 234/ f (Mhz) , which gives about 5% less length than 246/f (Mhz). Why? no idea.
Measurement Systems:
CGS = Centimeter Gram Seconds - old scientific system, no more in use.
MKS = Meter Kilogram Seconds.
SI = International Standard Units = MKS (almost).
FPS = Imperial = Foot, Pound, Seconds.
DougJohnson
Don't forget to adjust for the velocity factor of the coax. But I am looking forward to your results. Maybe I can save my poor Franklin.
The problem I have with tweaking tap locations is the same as yours. The only instrumentation I have is very crude --- stick the thing up for a few days and count messages, range, and dBFS.
-- Doug
The speed of light (metric units) = 299,792,458 meters/sec
984,000,000 ft/sec
Hence:
Wavelength in metric units = 300,000,000/ MHz x 1,000,000 = 300/MHz meters
Wavelength in metric units =984,000,000/ MHz x 1,000,000 = 984/MHz meters
The ARRL Book uses 234/ f (Mhz) , which gives about 5% less length. Why? no idea.
Great answer. I think I have all the information I need now to start cutting. I'll start with 69 mm and do a test, then maybe cut back to 65 mm and do more testing.
-- Doug
It occurred to me that we're an interesting hybrid of non-HAM radio hobbyists. Of course, there are some exceptions, like ab cd and a couple others here. But I think most of us ADS-B hobbyists are plug and pray types. :D
ETA: Thank goodness there are a few HAMs here to help us with the calculations!
I am NOT a HAM, nor ever have been, but I do have a keen interest in Telecommunications, Electronics, & Computers, and like DIY & Experimenting.
Plug & Pray .... me too :D
Aha. I thought you were a HAM from something you posted once - Morse Code?
giacomo1989
I had noticed it :) It's just a wire. Use the second as it has less resistance and just easier to do :D Let me know
trigger
@jepolch:
@DougJohnson:
Before you try decoupling sleeves & balun, try to adjust cable tap of Franklin. This can best be done with Franklin on a temporary support (pvc pipe, wooden plank etc) in your attic or open yard, and at height of arms reach. Weather now is good for working in open yard :)
Don't give up on the Franklin.
I did pretty much what ab cd suggests. I sat under my patio umbrella with the antenna hanging off one of the spokes. I ran adsb Scope and got a feel for where the edge of detection was. I watched a plane which was just at the edge of the detection but coming towards me. Move the tap a couple of mm and if the plane disappears put the tap back to where it was (the plane should re-appear). Move the tap a couple of mm in the opposite direction. Repeat for the next plane. It helps if you have a beer in your spare hand ;)
I cut a metal connectors out of a connector block, cut it in half then slipped them onto the wire before bending to shape. I soldered the ends of the coax which made connection to the cut down connector easier. Moving the tap was just a matter of unscrewing the screw and pushing the connector along the wire. I also put a bit of insulation tape between the 2 connectors in case they touched.
THANK YOU! :cool:
DougJohnson
Do you have a feel for how much difference you were able to get? It is too late for me to try the terminal block idea for this one, but I am sure there are other things I could try. -- Doug
I cut a metal connectors out of a connector block, cut it in half then slipped them onto the wire before bending to shape. I soldered the ends of the coax which made connection to the cut down connector easier. Moving the tap was just a matter of unscrewing the screw and pushing the connector along the wire. I also put a bit of insulation tape between the 2So connectors in case they touched.
Thanks for the tips. So you got yours working good? How many elements? Will Diet Coke work OK? :D
I'll bet you could wiggle the single connector around the bends to get it where you need to.
