I would hope to see a bandpass effect similar to this, from a 1/4 wave shorted-end 'filter' section.
The shorted-end 1/4~ coax filter, looks like a
parallel resonate tank circuit.
http://sub.allaboutcircuits.com/images/02096.png
Once I get the length cut right (for 130.55 MHz, I think), I can add more sections with more 'T' adapters.
Which should increase the attenuation above and below 130.55 MHz..
I think much of the noise I'm hearing is broadband coming from power-lines etc.
Most of that is vertically polarized and reaches up higher than the 2m band..
But, there are also many local VHF RF signals near the 2.3m band that may
be interfering with the ACARS signals.
http://www.rtl-sdr.com/rtl-sdr-radio-scanner-tutorial-receiving-airplane-data-with-acars/
I also have an old military surplus dual cavity tunable filter for the 100 Mhz range.
I may be able to change it's tune with a hacksaw..
