I'll try and make the radial, and see how it works on my trianglespider!
ETA:
I'm also thinking of trying slightly different triangle radials, currently I have them folded in triangle shape, but the end is insulated from the rest, I.E. it should work as a 3/4L radial. Im planning on making a second set of triangle radials where the end IS connected to the start to make a kind of butterfly-like connected 1/4L dipole with a slightly larger BW.
Once more, new antenna build, swapping it right now
ETA2: first results with the triangle radials are a bit crappy, so switching to 1/4L 45* radials right now.
