Simulation 1 of 2: The Zigzag Franko-Spider
Poor Results :(
Simulation 2 of 2: The Straight Franko-Spider
Good Results :)
Just curious how a 1/4 wave on top would do as opposed to the 138mm whip portion.. this I would think would "balance" out the initial 68 mm feed...
Jim
WELCOME ABOARD JIM!
Good idea, worth trying by simulation, as well as by making a prototype and putting it to trial run.
borchi
Hallo,
thank you... My wife is not happy with the solution... The antenna moves to outside :)
I got an inline amplyfier today with no result... Do i have to use a power injector?
My window is directed to the south-east, about 1 nm away from EDDB/SXF final aproach. Los is only blocked by one building.... Now the cool thing: I recive signals from the direction north, EDDT/TXL right trough my apartment :)
Have a nice evening....
Hallo,
Typical "wifely" behaviour :(
Your wife's dislike to indoor antenna is a blessing in disguise. Now with antenna moved out, you will get better reception.
Amplifier needs two more things to work:
(1) DC power supply
(2) Power inserter
See the diagram below (I have prepared this diagram for jepolch using his equipment, but it applies to other makes of equipment as well).
http://m.ebay.de/itm/161662607940
http://m.ebay.de/itm/331250951381
Good day everyone. I went up to the roof today and did a little tweaking. I cut all the legs and whips on my two spiders to 66 mm. They are made of 2 mm wire, and think that they would work better if shorter. So far, so good. It seems I'm getting at least as many aircraft and maybe a few more. At least I didn't make them worse! In the process of repositioning the radials I broke one off my "worse" spider. :( So now he has 7 legs. Doesn't seem to have hurt him much. I'm going to go up again soon and replace that with one of my conetennas, probably this one.
ETA: Almost forgot to mention, I also changed the angle of the radials to 35 degrees.
You are right.
Some text books do recommend reduction of length, obtained by free-air formula wavelength (in meters) = 300/Mhz, by a certain percentage, which depends on ratio of diameter of wire to wavelength.
According to correction factor graph attached below, for 2mm dia wire at 1090 Mhz, the reduction is 6% i.e. length should be 94%. For a quarter wavelength limb of 69mm, this works out to 69mm x 0.94 = 65mm.
Source of graph below: posted by member JLD in FR24 forum "best antenna":
http://forum.flightradar24.com/threads/3831-best-antenna?p=65115&viewfull=1#post65115
Edit: Image replaced by larger sized image provided by jeploch.
You are right.
Geez, I wonder where I got the idea to shorten my legs? :rolleyes: I thought I'd try 66 mm first. It's easier to cut more off than add on.
ETA: @ab cd: Thanks for the info. That is good stuff.
By the way, you may recall a few posts back I mentioned I was using a cable TV diplexer as a cheap (as in 2 for $5 cheap) high pass filter. My stats are up about 10% since I started using the diplexer.
ETA: I've tried connecting the diplexer in both directions (in/out aimed at antenna or receiver) and it doesn't seem to matter. I'm using the SAT and in/out ports.
Poor Results :(
Good Results :)
That is what I personally experienced aswell, reception of the single U-bend was a lot better than the S-bend.
ETA:
Hooked up the U-bend again,
while the ebay antenna was receiving around 40 planes and 250 or so messages per second.
(Got a new RTL-SDR receiver/decoder as well, one of the noo-elec ones.)
Hallo,
I have noticed the same behaviour, I get a better reception in the direction of the walls on the opposide side of my room when my antenna is placed near the window :p
An easier way to get accuracy is to measure & mark on wire the points of bends while the whole wire is still straight, BEFORE starting any bending & cutting.
For example, for straight stub franko-spider, marking can be done on straight wire as follows:
STEP 1:
Point A - top of wire
Point B - 138mm from A
Point C - 66mm from B
Point D - 6mm from C
Point E - 66mm from D
Point F -69mm from E
Point G - 10mm from F (surplus)
STEP 2:
Make 90* bends at already marked points B, C, D, & E.
STEP 3:
Trim length at bottom according to SO239 to make finished height of lower-most section = 69mm.
Going to make another U-bend FrankenSpider right now to see how it compares to my other one (which has ~140mm of wire in the matching stub)
ETA: from where do you measure for the 69mm segment from the connector towards the first bend, from level/line A, B, or C?
