Here are results of my 3 antennas WITHOUT AMPLIFIER, and short (12 feet) Coax from antenna to Receiver.
As you can see, the Franklin & 5/8 wavelength Coil-Tuned are much inferior to Sleeved dipole when run WITHOUT AMPLIFIER.
This shows that:
(1) Half-wave Dipole is inherently tuned with SWR=1 if its two legs are cut at 69mm. This is very easy for any DIY hobbyist.
(2) Franklin & coil tuned (and coco also) require tuning which depends on dimensions & alignments. Little errors caused by DIY hobbyist throw them far away from optimum. These can be best made accurately only in Factory environment with all jigs, tools, templates & sophisticated test equipment.
Half wave Sleeved Dipole (Pepsi-can)
5/8 wavelength dipole with tuning/matching coils
4-element Franklin with Matching stub.
This shows that:
