DIPOLE LENGTH vs. RADIATION PATTERN & GAIN
As seen from above diagram, the full wavelength dipole has a combination of high gain and a horizontal pattern which is most favourable for ADS-B, but has the disadvantage of very high impedance, which requires impedance matching arrangement (stub, coil etc)
The 1.25 wavelength dipole is also similar to full wavelength, and has slightly better directivity in horizontal direction, & lower impedance than fullwave, hence easier to match the impedance. It Is very popular as 5/8 wavelength whip with ground plane (the 1.25 wavelength dipole is two limbs of 5/8 = 2 x 5/8 = 10/8 =1.25).
The 5/8 wavelength whip with maching coil at bottom is a popular whip for mounting on vehicles, where metallic body of the vehicle serves as ground plane.
