I would also switch away from the old Windows client to the new one, or just shut it down if the data is coming from a new client anyway. That feeder has quite a few bugs in it!Look what I found today morning flying overhead:
Canadian Warplane Heritage Avro 683 Lancaster B.X C-GVRA
View attachment 2254 View attachment 2252 View attachment 2253
Ah yes, we don't support XP, and neither do Microsoft ;-)Following your advice, I just now tried to install new windows feeder version 2.0.2080 on my old faithful, Windows XP
The Desktop, and hence windows client is not always running. That is the reason I purchased and installed two RPis (each with an independent systems of antenna, Coax, Amplifier, DVB-T dongle).Ah yes, we don't support XP, and neither do Microsoft ;-)
I think we are getting some Pi data from you and actually you should probably just turn the old feeder off. We won't be missing anything.
I would remove the Windows version then, could cause issues.The Desktop, and hence windows client is not always running. That is the reason I purchased and installed two RPis (each with an independent systems of antenna, Coax, Amplifier, DVB-T dongle).
These RPis run continuously 24 hrs a day/ 7 days a week / 52 weeks a year. Windows client runs intermittently, using its own antenna, coax & DVB-T dongle, only when the Desktop is running.
@ab cd, great piece of work as usual![]()
You must be one of the only people in the world with a Smith chart, protractor and a pair of compasses readily to hand. I do have a copy of a Smith chart but have absolutely no idea what to do with it. I use it for standing my coffee mug on.
Exactly as I expected!Hmmmm, I read the first couple of sentences in the first link and I've decided to keep using the chart as a coffee coaster. Thanks for the links though.
How does the Franken spider compare with your best CoCo?
Spider, Cantenna, and Franklin Spider are all inferior to my best CoCo (8 element, open top)
