Gain = 7.15 dBi, SWR = 1.1
I have done some changes in impedance matching arrangement and then simulated the new design with 4nec2 software.
STRATEGY:
(1) Determine Antenna Impedance. This is done by Simulation of antenna without matching stub. (I have assumed 1600 ohms in the previous design, which was wrong approach, and proved to be too high).
(2) Using the antenna impedance Zant & connecting cable impedance Zcab, determine required stub impedance Zstb of matching stub using formula Zstb = √(Zant x Zcab).
(3) Using stub impedance obtained in (3) above, and the stub wire dia d, calculate center-to-center spacing between stub conductors S, using formulae Zstb = 276 log (2S/d).
(4) Simulate antenna WITH matching stub using dimensions obtained as in (3) above.
CALCULATIONS:
To get fairly accurate value of antenna impedance, I ran the simulation after removing the impedance matching stub and connecting feeder cable directly to antenna at its center.
The results show that the Antenna Impedance = 411 - j435 ohms
Using the Antenna Impedance obtained above (411 - j435 ohms)
Zant= √(square of 411 + square of 435 ) = 598 ohms. The previous design's assumed value of 1600 ohms was therefore wrong.
Based on new value of Antenna impedance obtained by simulation, I did following calculation for the dimensions of matching stub which worked out to be 3mm stub conductor spacing for a wire dia of 1mm. See calculations below.
Required impedance of Matching Stub Zstb = √(Zant x Zcab) = √(598 x 75) = 212 ohms
Stub Dimension calculation:
S= spacing between stub conductors (center-to-center)
d= dia of stub wire = 1mm (#18AWG)
which can be rearranged as S = (d/2) x 10 to power (Zstb/276)
Using d = 1mm and Zstb = 212 ohms,
S = (1/2) x 10 to power(212/276) = 3mm
I then simulated with a 3mm stub (wire #6, #7, & #8 in th first sreeshot - input geometry data. The coaxial cable connection is at wire #14)
The input/output data is shown in the 4 screenshots below (Gain = 7.15 dBi, SWR = 1.1 - see image 3, left window):
image 1 of 4 - input data
image 2 of 4 - input data
image 3 of 4 - output data
image 4 of 4 - output data
STRATEGY:
CALCULATIONS:
