Please see my following post in another thread of this forum:
Step by Step Method of Installation of PF Client on R Pi B+ (Linux Raspbian)
http://forum.planefinder.net/thread...-raspbian-dump1090-data-feeder.241/#post-2451
ab cd:how can I get back in the file to set back up the lat and long, port number?
I'm having issues.
Error: listen EADDRINUSE
at errnoException (net.js:904:11)
at Server._listen2 (net.js:1042:14)
at listen (net.js:1064:10)
at Server.listen (net.js:1138:5)
at EventEmitter.app.listen (/usr/local/lib/node_modules/pfclient/node_modules/express/lib/application.js:559:24)
at Object.eval (eval at <anonymous> (/usr/local/lib/node_modules/pfclient/client.js:2:423), <anonymous>:6:3412)
at Object.<anonymous> (/usr/local/lib/node_modules/pfclient/client.js:2:1)
at Module._compile (module.js:456:26)
at Object.Module._extensions..js (module.js:474:10)
at Module.load (module.js:356:32)
If you are registered with planefinder with user name "Joe Polchlopek", these are your statistics:
https://planefinder.net/sharing/receiver/8414
I am registeted with user name ab cd and my stats are at https://planefinder.net/sharing/receiver/5993
You have to login to see full details. Since you started data feeding just today, your statistics will be almost nil.
Complete list of all data sharers (receivers):
https://planefinder.net/sharing/receiver_list
Thanks. That would be me. I forgot to add the start script when I set up pfclient last night. I was tired. I need to do that today to prevent gaps. I've been enjoying this forum very much and decided I needed to pay back PlaneFinder by feeding them my data. :)
Yor data graph is showing zero from 7:00 UTC (2:00 Eastern time). Check if your pfclient is feeding data or not by following comnand
sudo cat /tmp/pfclient.log
That's when I have my Pi's set to reboot each night. It didn't start up again because I hadn't had the start script in place yet. :oops: I've got it now.
Give following comand:
sudo pfclient
This will start configuration. Follow the on screen prompts to set up PFClient.
It will ask "home" i.e. receiver location (Latitude & Longitude in decimal format).
It will also ask for your PlaneFinder allocated username & password.
For DVB-T USB Receiver, use following settings.
Receiver Type: “30003”
TCP Port: 30003
Later Edit: Above is applicable only during initial configuration when auto-start script has not yet startted the pfclient. During runtime using this command tries to start another instance of the pfclient & gives erro messages. Better change configuration by editing file client.cfg (see my post # 1473 below).
I'm having issues.
Do you get these during installation or after installation? If during installation at what stage?
I am not expert in this, nor the details written by me. Just below the title of post #3 (pfclient installation instructions), I have given the link to source of these instructions. You may visit that webpage and ask them guidance for the issue you are facing.
Config file is located here
/usr/local/lib/node_modules/pfclient/client.cfg
@bramj: THANK YOU. This info is very helpful for manually changing configuration.
@Sjacket99: You can manually change configuration by
cd /usr/local/lib/node_modules/pfclient/
sudo nano client.cfg
(Later edit: file name corrected to client.cfg)
This will open configurtion file for editing. Edit configuration settings as you want.
Then after making changes, save configuration file pfclient.cfg by (Ctrl+o) then exit (Ctrl+x)
When i run
root@raspberrypi:~# sudo pfclient
[2015-02-07T18:42:24.511Z] PF Client Version: PF2.2.16
[2015-02-07T18:42:33.682Z] Connecting to 127.0.0.1:30003
events.js:72
throw er; // Unhandled 'error' event
That's what I get back.
When i cd into this:
Then do this. Its a empty file.
sudo nano pfclient.cfg
when I do a ls it shows.
root@raspberrypi:~# cd /usr/local/lib/node_modules/pfclient/
root@raspberrypi:/usr/local/lib/node_modules/pfclient# ls
client.cfg client.js htdocs launcher.js node_modules package.json
New cantenna: Purina Cantenna, because it's made from a steel dog food can. Height 69 mm, Diameter 71 mm. I'll try it on the roof next time I fee l motivated. :) I wonder if the grooves will have a negative effect?
When i run
events.js:72
Port already used by another application.
Nice!!!
I've made also another cantenna without cutting down in height the can. Seems to have a better range!!!!
PS. You are so crafty in making your antenna. Mine are s**t compared to yours :(
Sorry I gave wrong file name.
Iit is NOT pfclient.cfg
It is client.cfg
Correct commands are:
When i run
events.js:72
I also get back exactly same error messages when i run the command sudo pfclient.
It appears that since the starting script has already started the pfclient at boot time, this command tries to start a second instance of pfclient, and causes error messages.
Better edit configuration by editing file client.cfg (see my post #1473 above)
Looks great! Hopefully works great. My Vulcan/Mr. Spock logic says grooves should not make any noticeable difference.
@giacomo1989:
Attached simulations for Lollypop, Spider & Dipole, all with 1/4 wavelength (69mm) vertical upper whip.
Note that both the Gain & SWR improve with a simple action: bent down the legs of lollypop!
(1) 8-Legs, Hoizontal (Lollypop)
(2) 8-Legs, Bent down 45 degrees (Spider)
(3) 8-Legs, Bent down 90 degrees (Dipole)
@giacomo1989:
Great info. Thanks! I'm going to have to re-think the dipole. I made one like your little one early in this thread that I have never put to test on the roof.
@giacomo1989:
Thanks so much for doing this.
Don't you think is realy strange that dipole has better SWR than the spider? Maybe there are some considerations about the feeding point that the program does not count
