Aircraft icons not showing
OzFlyer
Hi all,
I have just started using planefinder again after some years. Aircraft icons are not showing, bu if I set settings to default text is showing. Also, on a zoomed out view, no icons or text is showing. Would someone please explain why?
Steve
wiedehopf
Could you elaborate if you are talking about the local planefinder client page, or the planefinder.net webpage?
Also which browser / system are you using?
Have you tried another browser?
OzFlyer
I am running Windows 10, latest update. Firefox, latest update. I have tried Chrome and I thought I had tried Edge, but not IE. However, this morning I tried Edge and IE and both worked. Attached are a couple of screen shots of what I can get in FF or Chrome. In Chrome, as I don't use it a lot, I reset to default settings, no change. I am reluctant to reset FF as I have a lot of customisations there.
Steve
wiedehopf
Delete the cache, that doesn't reset anything.
Also try disabling all extensions and see if one of them is the culprit.
OzFlyer
Got Chrome working, needed to disable hardware acceleration in settings! Disabled h/w acceleration in FF, no go.
wiedehopf
Having to disable hardware acceleration points to problems with your setup, maybe graphics drivers.
I'm not sure it's a problem with the webpage, rather not many pages use 2d graphics acceleration i guess.
Maybe @Lee Armstrong has a suggestion.
OzFlyer
Could be, I recently updated the driver, I am running an older NVIDIA GTX275. It used to work on that card, so it must be a WIN 10 or driver issue. I'm about to try to re-install the driver, or roll back a version or two.
