Api Google
tonkepen
Hello:
Someone could explain to me how to use this google API? I already did, but I do not know how to use it. So if anyone wants to see my map, how does it?
Thank you.
This allows you to view the Google map from usually a non local IP. i.e. the IP address of your router NAT'ed through
tonkepen
Yes but if you now put my ip, which is fixed 87.216.162.112, I will have to put a port later ?.
For example 87.216.162.112:40 ....
Or the IP / map.html
That's what I do not understand
tonkepen
Ahhhhh, sensational thanks, understood perfectly. So if I give a friend that address you will see my map.
Well thank you as always, doubt clarified.
