Automated Installation of Dump1090-Mutability, Data Feeders, and Performance Graphs
To find the latest PFClient version number while in SSH console of RPI:
#Download planefinder's pfclient download page, and save it as file pfc
~$ sudo wget -O pfc "https://planefinder.net/sharing/client"
#Read from saved file pfc, the line containing word armhf.deb
~$ grep 'armhf.deb' pfc
#Above command will give following output which contains current version of pfclient for RPi
<a href="http://client.planefinder.net/pfclient_3.7.1_armhf.deb" class="download-link generic">
#After noting the version number, remove Plane Finder page saved as file pfc
~$ sudo rm pfc
#If in above method, instead of command,
#following command is used,
~$ grep 'armhf.deb' pfc | grep -o -P '(?<=pfclient_).*(?=_armhf.deb)'
#it will give only version number like below
3.7.1
Currently, the installation of dump1090-fa, Planefinder data feeder "pfclient" and "mlatclient" for adsbexchange fails.
This is because JP's scripts are not updated for sometime. As a result the version numbers in the script are outdated.
To update version numbers, edit file variables.sh and change version numbers of following software as shown in red, which are latest version numbers:
1) PIAWARE
2) PFCLIENT
3) MLATCLIENT
~$ sudo nano adsb-receiver/bash/variables.sh
#!/bin/bash
## SOFTWARE VERSIONS
# The ADS-B Receiver Project
PROJECTVERSION="2.5.0"
# FlightAware PiAware
PIAWAREVERSION="3.5.0"
# PlaneFinder ADS-B Client
PFCLIENTVERSIONARM="3.7.20"
PFCLIENTVERSIONI386="3.7.20"
# Flightradar24 Linux Debian package
FR24CLIENTVERSIONI386="1.0.18-5"
# mlat-client
MLATCLIENTVERSION="0.2.9"
MLATCLIENTTAG="v0.2.9"
# PhantomJS
PHANTOMJSVERSION="2.1.1"
After changing version numbers and Saving the file variables.sh, run the install script.
cd ~/adsb-receiver
./install.sh
zahidulhasan
Dear Sir,
Can you tell me how to clean uninstall "adsb-receiver web portal" from Jessie ? My graphs are broken, seems i have to install it again.
zahidulhasan
Dear Sir, graph stopped working as well as dump10190-mutability 1.15. Plz advice where to check.
Can You advice me how to increase dump1090-fa ring length ?
mgunther
For anyone who still has dump1090-mutability installed but cannot get the map or graphs working, try to change the ownership of the /run/dump1090-mutability directory:
~ $ sudo chown -R dump1090:nogroup /run/dump1090-mutability
(Some recent versions of fr24feed had mistakenly set the ownership of this directory to 'nobody:nogroup')
zahidulhasan
Dear Sir,
Today i tried to install dump1090-mutability with the script, but its result came as this. Not showing the version number in right side while no plane visible, But no error message in the map also. All other clients working properly. I thought FR24feed could have installed any dump, but if i uninstall dump1090-mutability, all client stop feeding. Can you tell me what the problem going around ?
zahidulhasan
@zahidulhasan
As the Flightradar24 upgrade problem is now over, can you please delete all your posts on this crisis so that the thread remains dedicated to its main theme. I am also going to delte all my posts on FR24 crisis.
Thank you.
Dear Sir, Its done. Thank you for your nice co-operation. But still i have issue with 1.0.19-11 but its fine with 1.0.18-9.
Zahidul Hasan.
pilax
Hi
I made two installations with this software on two different raspbian lite.
I used (I think) the same parameters but on one raspberry, the web interface do no have the Flights link...
So it is impossible to list all flights or search for a specific Flight...
Do you know why or what can I do to correct this ?
zahidulhasan
Dear Sir,
My installation halted with this message. I am trying in raspbian stretch lite. Now how to solve it ?
E: Package 'debhelper' has no installation candidate
INSTALLATION HALTED!
UNABLE TO INSTALL A REQUIRED PACKAGE.
SETUP HAS BEEN TERMINATED!
The package "debhelper" could not be installed in 5 attempts.
ANY FURTHER SETUP AND/OR INSTALLATION REQUESTS HAVE BEEN TERMINIATED
Try update first, then run script again.
sudo apt-get update
cd ~/adsb-receiver
./install.sh
zahidulhasan
Dear Sir,
I am trying to install in a brand new setup 2.6.3 setup, but in live dump1090 map i always getting piaware page. I did not touched any flightaware/piaware element in this installation. Can you check it ?
Dear Sir,
Did you clear browser cache?
Try this
Clear browser cache (Ctrl+Shift+Delete), then reload browser (Ctrl+F5).
Sometimes browsers are stubborn and dont easily clear their cache. Try other browsers, for example if you are facing this issue on Firefox, then try Google Chrome and Internet Explorer.
zahidulhasan
Try this
Yes sir, It was browser cache problem. Now everything ok. Sorry for late reply. Hope you are well.
Zahidul Hasan.
FUNG SAI HOU
Hi all,
Is there a way or script that can uninstall / remove the ADSB-Receiver completely?
I have ADSB-Receiver Performance Graph installed and the PiAware WEB installed, and in this case the PiAware WEB is not working and taken over by the ADSB-Receiver.
If there is a way to let me access the PiAware WEB then uninstall / remove of ADSB-Receiver is not necessary.
Regards.
