Automated Installation of Dump1090-Mutability, Data Feeders, and Performance Graphs
W1PAC
Hello all,
Kind of semi-necrobumping this post here, but I installed the planefinder client using Joe's script.
Anyways, got a notification that my planefinder feed was down earlier today. Took a look at port 30053 and sure enough, it's offline. On the other hand though, FlightAware is still feeding perfectly fine. FR24 also.
I thought a simple reinstall of the Planefinder client using Joe's script would work... except I can't reinstall via the script, there's no option to.
Any ideas?
(1) First purge current install
sudo dpkg --purge pfclient
(2) After purging, reinstall by running Joe's scrip, OR manually by following commands
wget http://client.planefinder.net/pfclient_4.1.1_armhf.deb
sudo dpkg -i pfclient_4.1.1_armhf.deb
W1PAC
Purged, reinstalled via Joe's script. Still getting a connection refused when it asks me to configure the client via the webpage after install.
W1PAC
This site can’t be reached
"IP address of the Pi" refused to connect.
ERR_CONNECTION_REFUSED
Anwyays, I need to get ready for work. I'll try any suggestions you have tomorrow. :)
You should not use "IP-of-Pi" as is.
You should replace "IP-of-Pi" by IP address you use to SSH to Pi.
For example, my Pi's "IP-of-Pi" is 192.168.0.21, I type following address in web browser to go to Planefinder settings:
192.168.0.21:30053
Ok, what do you get at
IP-of-Pi:8754
FUNG SAI HOU
Hello all,
Any ideas?
Hi W1PAC,
In what Single Board Computer and what OS you currently installed? Which version of dump1090 you chosen to install using the Joe's script? Then Mr. ab cd might have more detail / info to assist you on this matter.
73.
Open file pfclient-config.json for editing
sudo nano /etc/pfclient-config.json
Delete all entries by repatedly pressing Ctrl+k
(Unconfigured file will have only {} )
Copy paste following.
Replace xx.xxx, yy.yyyy, and zzzzzzzzzzz by their actual values. While replacing xxx yyy zzz, take care not to delete any of " , :
"tcp_address":"127.0.0.1",
"tcp_port":"30005",
"select_timeout":"10",
"data_upload_interval":"10",
"connection_type":"1",
"aircraft_timeout":"30",
"data_format":"1",
"latitude":"xx.xxxx",
"longitude":"yy.yyyy",
"sharecode":"zzzzzzzzzzzz"
After copy-paste save file Ctrl+o and Close file Ctrl+x
Reboot RPi
sudo reboot
Now check status
sudo systemctl status pfclient -l
Check map
IP-of-Pi:30053
How are you accessing your Pi?
(A) By connecting a monitor, keyboard and mouse to RPi
OR
(B) By SSH from your Desktop/Laptop
W1PAC
"tcp_port":"30005",
"data_format":"1",
Reboot RPi
sudo reboot
Now check status
Check map
IP-of-Pi:30053
That fixed it! Granted it's quiet time for the BOS area at the moment so no activity on the screen, guess I'll wait to first BOS flights begin their early morning takeoffs.
ClywdSlade
Hi...when dump1090-mut is running I can see all the graphs and the live map in the webportal but I'm not feeding data zu Flightradar I'm offline. When I kill the process dump1090-mut nothing is displayed in the web portal graphs except core utili and stuff and no planes are displayed at the live map but I'm feeding data to Flightradar I'm online.
So is there a way to run both. See all the graphs AND feeding data to Flightradar.
circuit card assembly
wiedehopf
I'd recommend this: https://github.com/wiedehopf/adsb-scripts/wiki/Bundle-install-for-dump1090fa
If you want to continue using the outdated dump1090-mut, you can just reconfigure fr24feed manually:
https://github.com/wiedehopf/adsb-w...90-fa#1-fr24feed-settings-for-people-using-it
Beast TCP with host 127.0.0.1 and port 30005
You can also change that in the FR24 webinterface:
