Client v3.1.201 armhf
Rory Fairbairn
Hi
Got a couple of issues with pfclient v3.1.201 armhf.
As you can see, it says I have an up time of over 22hrs and a start date of last night. This is a bit wrong. The start date is the date and time I shut my client down and its only been up for 12.5 hrs.
It also says there is no MLAT data. Not entirely convinced on that as i'm seeing mlat on my dump1090 mutability 1.15 dev map.
Any ideas? Not sure how to even attempt to fix this.
Hi
Not sure on the uptime. Will see if we can replicate.
The MLAT bandwidth is zero as you are not using the Plane Finder MLAT system at the moment but are feeding in MLAT data from Dump1090. The MLAT bandwidth is only for MLAT calculations within the Plane Finder system. At the moment limited to units with a GPS and a few RTL dongles across the UK at the moment
