I found a small coax filter that I had from my days on 900 Mhz ATV and decided to cut it down for 1090..
http://www.rfcafe.com/references/electrical/coaxial-resonator.htm
http://www.rcgroups.com/forums/showthread.php?t=1366534&page=16
Here is a simple 1/4-wave coax filter crudely installed in the middle of the coax feeding a small 1/2 wave dipole.
My Filter is attached to my 1090 coax at the radio, using a Coax 'T' fitting. (SMA).
I don't have access to RF lab equipment anymore, so I had to guess how to 'build' the filter.
There is one interesting feature about this resonate filter, that might help a person without a good lab..
If the end of the filter cable, is left open (instead of shorted), it is what we RF guys call a Suck-Out.
It will pull out RF power, at it's resonate frequency. (Hams install these Suck-Out Traps on TV feed lines when TV owners complain about Ham interference).
So, I connected the 'T' and started trimming the bottom of the coax, moving towards the 45mm mark.
As I cut off small pieces of coax, I could see the signal display (RTL1090) dropping like crazy..
I had the AGC turned off and tweaked the gain for a few 'bars' and kept clipping.
I think the coax must have a velocity factor of .66, since the attenuation at 1090 was extremely high at 45 mm.
So, I soldered a short across the open end and now had my filter..
Taking it in and out of the antenna line, made n0 difference in the signal levels seen from the AC..
So, I left it installed in-line and started plane watching..
After a couple of hours, I could see no reduction in range. Planes were reaching the Maximum Range lines.
And a few were actually exceeding the max range (re-drawing it)..
The nice part about using this kind of filter, is the short circuit provides good static electricity discharge protection for the radio.. (or LNA).
