[email protected]:~ $ view1090-mutability --help
| view1090 ModeS Viewer EB_SOURCE EB_VERSION |
--no-interactive Disable interactive mode, print messages to stdout
--interactive-rows <num> Max number of rows in interactive mode (default: 15)
--interactive-ttl <sec> Remove from list if idle for <sec> (default: 60)
--interactive-rtl1090 Display flight table in RTL1090 format
--modeac Enable decoding of SSR modes 3/A & 3/C
--net-bo-ipaddr <IPv4> TCP Beast output listen IPv4 (default: 127.0.0.1)
--net-bo-port <port> TCP Beast output listen port (default: 30005)
--lat <latitude> Reference/receiver latitide for surface posn (opt)
--lon <longitude> Reference/receiver longitude for surface posn (opt)
--max-range <distance> Absolute maximum range for position decoding (in nm, default: 300)
--no-crc-check Disable messages with broken CRC (discouraged)
--no-fix Disable single-bits error correction using CRC
--fix Enable single-bits error correction using CRC
--aggressive More CPU for more messages (two bits fixes, ...)
--metric Use metric units (meters, km/h, ...)
--show-only <addr> Show only messages from the given ICAO on stdout
--help Show this help
