Error in Log Viewer
FlyTT14
Hi, new to this but I have a problem in my Log Viewer, the only ting I see is the text below..
2015-11-21 15:26:30.147767 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-11-21 15:26:30.147502 Failed to open connection to socket: Connection refused (errno: 111)
2015-11-21 15:26:25.146577 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-11-21 15:26:25.146330 Failed to open connection to socket: Connection refused (errno: 111)
I have tried to follow this link:
http://forum.planefinder.net/thread...ctions-for-raspbian-dump1090-data-feeder.241/
As a check to myself I can see aircraft’s when I enter this command in a terminal windows on my Pi
cd dump1090
./dump1090 --interactive --net --net-http-port 8080
Any idea there to start looking to solve my problem
FlyTT14
Not sure what happened in my first "try"
Wiped the card and installed everything from scratch (copy paste on every command), now I'm waiting for an aircraft to see if it works, No error in the Log View
FlyTT14
Any idea why I see this in my local log (underlined text), I see it very often
015-11-23 13:40:23.26827 Decoder select timeout occurred, restarting...
2015-11-23 13:40:13.21979 TCP connection established: 127.0.0.1:30005
2015-11-23 13:40:13.21279 Client restarted successfully
2015-11-23 13:40:13.21175 Closed TCP connection: 127.0.0.1:30005
2015-11-23 13:40:13.20720 Decoder select timeout occurred, restarting...
2015-11-23 13:39:59.259222 TCP connection established: 127.0.0.1:30005
2015-11-23 13:39:59.258506 Client restarted successfully
2015-11-23 13:39:59.258406 Closed TCP connection: 127.0.0.1:30005
2015-11-23 13:39:59.257973 Decoder select timeout occurred, restarting...
2015-11-23 13:39:47.660367 Successfully sent 6 aircraft updates over the past minute (2.00kb)
2015-11-23 13:39:27.475798 TCP connection established: 127.0.0.1:30005
2015-11-23 13:39:27.475099 Client restarted successfully
2015-11-23 13:39:27.474995 Closed TCP connection: 127.0.0.1:30005
2015-11-23 13:39:27.474528 Decoder select timeout occurred, restarting...
2015-11-23 13:38:46.343401 Successfully sent 9 aircraft updates over the past minute (2.00kb)
2015-11-23 13:37:45.218577 Successfully sent 8 aircraft updates over the past minute (2.00kb)
2015-11-23 13:36:44.172088 Successfully sent 12 aircraft updates over the past minute (2.00kb)
