Janos Konya
Hello guys,
Have you got a pre-filled text file for transforming the decoded hex code of the ground stations to ICAO, IATA, or friendly name with country code?
dumpVDL2 already translates AC code from a basestation database - as you can see in "ac info" line. I need a solution for ground stations too.
GS code file would be loaded into memory at start, to make ground stations readable also for human eyes.
required format:
Any help is appreciated
Update:
--> Directory of an installed Multipsk contains the needed list in the file "VDL2_Ground_Stations.txt".
...it can be used also for dumpVDL2 without changing the structure of contained text.
Here is the new output:
required format:
hex_address [airport_icao_code ground_station_details] [ground_station_location]
#example:
29E0C5 [EDDB Berlin Schonefeld DE] [Berlin Schonefeld]
Update:
