galenthurber
Just built an ugly horseshoe antenna; it works.
it's a smaller version of a 145Mhz one.
each arm (L shape) has 1/4wave horizontal & 1/2wave vertical.
The antenna is fed where the open end of the horizontal element arms almost touch; 10mm apart.
The feed line must come in at 90degrees to the horizontal elements.
The antenna is mounted 4' lower than my main ADSB antenna and it has reached 132nm so far.
the pattern should egg shaped off of each end.
Aim the antenna like gunsights.
stay tuned
stay tuned
