I've been tinkering with an old filter that I once had working on 910 MHz.
After replacing the 1/4 wave sections with resonators for 1090 MHz,
I found that I had no way to tune it up!
In the past, I was able to bring filters into work and tweak them during my lunch hour..
But, now I'm retired and don't have the money for expensive gear.
So, I'm looking for DIY way to get the job done.
Since I have receivers that can hear 1090, all I really need is a good signal source..
It needs to have enough power, to get past all the attenuation inherent in an Un-tuned filter..
First, I looked at getting a broad-band noise generator. I've used them before, but never for tuning filters.
Factory made units on Ebay seem to costly.
Then, I saw this page.. http://lea.hamradio.si/~s57uuu/astro/sidi_debug/harmgen_w_rtx.htm
http://www.ebay.com/itm/371005322188
The diodes aren't too expensive..
But, how to drive the diode.?. I need a VHF transmitter that has a harmonic on 1090 MHz!
My VHF Ham radios are on 144 to 148 MHz..
Wait a sec! I own one of those digital FM stereo transmitters!
And 99.1 Mhz x 11 = 1090.1 Mhz !! I think it's got about 2 Watts out in high-power..
I also have a 1296 MHz amplifier that I could use to boost the L-band harmonic signal level, if needed..
What do you guys think? Will it work? Should I order a batch of diodes?
