FUNG SAI HOU
Hello there,
I am new in Linux and ADSB.
I am using DietPi OS on RasPi 3B with updated OS installed. Below is what I got from putty ssh. The pfclient cannot start automatically after each boot. It has to be started manually. I did create folder & log for "/var/log/pfclient/error.log" as per stated. But it still not working after each boot.
[email protected]:~# sudo service pfclient status
● pfclient.service - LSB: planefinder.net ads-b decoder
Loaded: loaded (/etc/init.d/pfclient)
Active: failed (Result: exit-code) since Thu 2017-11-16 17:12:05 +08; 2min 27s ago
Process: 455 ExecStart=/etc/init.d/pfclient start (code=exited, status=2)
Nov 16 17:12:05 DietPi pfclient[455]: Starting pfclient: pfclient/etc/init.d/pfclient: 35: /etc/init.d/pfclient: cannot create /var/log/pfclient/error.log: Directory nonexistent
Nov 16 17:12:05 DietPi pfclient[455]: failed!
Nov 16 17:12:05 DietPi systemd[1]: pfclient.service: control process exited, code=exited status=2
Nov 16 17:12:05 DietPi systemd[1]: Failed to start LSB: planefinder.net ads-b decoder.
Nov 16 17:12:05 DietPi systemd[1]: Unit pfclient.service entered failed state.
Hint: Some lines were ellipsized, use -l to show in full.
Any experts can help me to solve this issue?
In the mean time, all other ADSB feeders & ADSB beast are working fine like FlightAware Piaware, Dump1090-fa, Opensky-Feeder & FlightRadar24.
I wish I can get it fixed as I don't want to use Raspbian Jessie. DietPi is lightweight and the interface is more comfortable to me.
Thank you and I look forward to hearing from you soon.
Fung SH
Fung SH
