Log View Problem
Philip Robinson
I keep getting this message, Failed to parse response from Plane Finder server: HTTP/1.1 200 OK.
It's happening far to often for my liking and if all my data is not being fed to Planefinder then it makes me wonder if i should bother at all.
I'm feeding using an RTL Dongle and a Raspberry Pi using the PF Client software.
Can anyone explain to me what's causing this to happen.
Copy of my Log View,
2016-05-04 16:38:47.738665 [-] Successfully sent 853 aircraft updates across 10 packets (65.00KB)2016-05-04 16:38:35.59681 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK2016-05-04 16:38:05.649751 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK2016-05-04 16:36:14.702705 [-] Successfully sent 951 aircraft updates across 11 packets (72.00KB)2016-05-04 16:36:02.693005 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK2016-05-04 16:34:14.507393 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK2016-05-04 16:33:19.940098 [-] Successfully sent 931 aircraft updates across 10 packets (69.00KB)2016-05-04 16:31:47.374342 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK2016-05-04 16:30:29.133694 [-] Successfully sent 938 aircraft updates across 10 packets (68.00KB)2016-05-04 16:30:01.420343 [!] Failed to parse response from Plane Finder server: HTTP/1.1 400 Bad Request2016-05-04 16:29:44.842273 [!] Failed to parse response from Plane Finder server: HTTP/1.1 400 Bad Request2016-05-04 16:29:29.386996 [!] Failed to parse response from Plane Finder server: HTTP/1.1 400 Bad Request2016-05-04 16:29:11.952161 [!] Data upload failed with error: 'Client not authenticated - local time on client out of limits, suggest setting up NTP locally - for help contact [email protected]'2016-05-04 16:28:21.908720 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK2016-05-04 16:27:45.628309 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK2016-05-04 16:26:57.688282 [-] Successfully sent 889 aircraft updates across 10 packets (67.00KB)2016-05-04 16:26:31.524977 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK2016-05-04 16:25:42.262182 [!] Data upload failed with error: 'Client not authenticated - local time on client out of limits, suggest setting up NTP locally - for help contact [email protected]'2016-05-04 16:24:59.257246 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK2016-05-04 16:24:43.479007 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK2016-05-04 16:24:04.732715 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK2016-05-04 16:23:49.334549 [-] Successfully sent 906 aircraft updates across 10 packets (66.00KB)2016-05-04 16:23:34.167952 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK2016-05-04 16:22:46.483572 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK2016-05-04 16:21:43.164988 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK2016-05-04 16:21:09.619208 [!] Data upload failed with error: 'Client not authenticated - local time on client out of limits, suggest setting up NTP locally - for help contact [email protected]'2016-05-04 16:20:19.240442 [-] Successfully sent 853 aircraft updates across 10 packets (63.00KB)2016-05-04 16:18:11.402259 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK2016-05-04 16:17:55.963958 [-] Successfully sent 806 aircraft updates across 10 packets (59.00KB)2016-05-04 16:16:17.484093 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK2016-05-04 16:15:35.38350 [-] Successfully sent 822 aircraft updates across 10 packets (60.00KB)2016-05-04 16:14:51.795980 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK2016-05-04 16:12:54.71926 [-] Successfully sent 839 aircraft updates across 10 packets (60.00KB)
MTIA
Phil
Hi Phil,
I've had a look and you have 4 share codes allocated to you!
The most recent one uploading is getting to us but the local time on your Pi is off at the moment by about 7 seconds. I would look at setting up NTP on your Pi.
Just had a quick Google around and found this guide but there are many more I would look at following..
Lee
Philip Robinson
Hi Lee,
Still getting the Failed To Parse Error and i'm not sure what to do now as i have NTP installed on the Pi and keep getting the problem, and it's happening more frequently.
2016-05-15 18:33:50.381 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:32:50.871230 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:32:04.704103 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:31:46.285445 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:31:17.417213 [-] Successfully sent 1129 aircraft updates across 14 packets (86.00KB)
2016-05-15 18:31:00.834414 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:30:37.156675 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:30:21.691550 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:30:05.281853 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:29:09.831388 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:28:54.373037 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:28:35.69300 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:28:17.640536 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:27:06.739649 [-] Successfully sent 786 aircraft updates across 10 packets (60.00KB)
2016-05-15 18:26:51.737571 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:26:36.92854 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:25:51.365388 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:25:34.917144 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:25:06.869815 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:24:36.382616 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:24:20.931254 [-] Successfully sent 725 aircraft updates across 10 packets (56.00KB)
2016-05-15 18:24:00.391593 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:21:52.629216 [-] Successfully sent 702 aircraft updates across 10 packets (55.00KB)
2016-05-15 18:19:48.508621 [-] Successfully sent 737 aircraft updates across 10 packets (56.00KB)
2016-05-15 18:18:43.999503 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:17:37.929325 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:17:06.827160 [-] Successfully sent 785 aircraft updates across 10 packets (59.00KB)
2016-05-15 18:16:51.263255 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:16:24.320862 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:16:08.865085 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:15:27.805121 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:12:15.992375 [-] Successfully sent 796 aircraft updates across 10 packets (59.00KB)
2016-05-15 18:11:25.113593 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:10:43.799625 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:10:12.56358 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:09:48.699627 [-] Successfully sent 811 aircraft updates across 10 packets (60.00KB)
2016-05-15 18:08:48.428352 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:08:21.387013 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:07:39.915561 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:07:24.461169 [-] Successfully sent 789 aircraft updates across 10 packets (61.00KB)
2016-05-15 18:06:54.270954 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:05:30.869104 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:04:52.507340 [-] Successfully sent 802 aircraft updates across 10 packets (63.00KB)
2016-05-15 18:04:13.959344 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:03:22.359353 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:02:45.802627 [-] Successfully sent 821 aircraft updates across 11 packets (61.00KB)
2016-05-15 18:02:35.340763 [!] Failed to parse response from Plane Finder server: HTTP/1.1 200 OK
2016-05-15 18:00:40.20225 [-] User location has been verified.2016-05-15 18:00:33.982279 [-] Echo port is now listening on: 192.168.0.27:300542016-05-15 18:00:33.971890 [-] Web server is now listening on: http://192.168.0.27:300532016-05-15 18:00:33.968554 [-] TCP connection established: 127.0.0.1:300052016-05-15 18:00:33.945797 [-] user_longitude = -3.0067002016-05-15 18:00:33.945725 [-] user_latitude = 53.4872802016-05-15 18:00:33.945618 [-] web_server_port = 300532016-05-15 18:00:33.945559 [-] select_timeout = 102016-05-15 18:00:33.945497 [-] aircraft_timeout = 302016-05-15 18:00:33.945427 [-] data_format = 12016-05-15 18:00:33.945370 [-] tcp_port = 300052016-05-15 18:00:33.945303 [-] tcp_address = 127.0.0.12016-05-15 18:00:33.945173 [-] connection_type = 12016-05-15 18:00:33.942971 [-] pfclient (3.4.30 armhf) started with the following options:2016-05-15 18:00:15.446175 [-] Data proxy is shutting down2016-05-15 18:00:06.605070 [-] Web server is shutting down2016-05-15 18:00:01.826686 [-] Echo port is shutting down2016-05-15 18:00:01.800148 [-] Shutting down workers...2016-05-15 18:00:01.799966 [-] Closed TCP connection: 127.0.0.1:30005
Regards
Phil
Thanks Phil,
We will take a look. Rest assured the data is getting to the server ok and the message in essence is wrong!
We'll see if we can get it resolved though!
Lee
Hi Phil,
I have set up some logging on the server end for this issue. From 0930 BST can you let me know when it happens again please?
One thing I notice is that the time on your Pi is jumping around a LOT. I wonder if the Pi is an older Pi running at 100% CPU and is simply doing far too much!
What else does your Pi have installed on it?
