Log View
Since the last update, LOG does not include the number of positions submitted. (Earlier, it generated a 7-10 mbps network traffic alone by its autorefresh behaviour)
You can check the correct operation on the statistics page of your receiver. To access it, either log in to the PF website and select the required item from the menu or check it through the "leaderboard". Filter the list by your country then pick the line with your username... "Daily Breakdown" tab will tell you if everything is ok.
Save the page as a bookmark for future easy access.
