Logs
Philip Robinson
Evening All,
I am feeding Planefinder and have aircraft on my map, the thing is no aircraft are showing in the logs.
It normally tells you how many aircraft were received.
Anyone have any ideas as to why this is?
MTIA
Phil
From the latest (5.0.161) client update, log does not contain detailed info about number of planes or amount of sent data anymore. It is mainly for detecting if there is a problem with the connection.
You can find stats for your station here, http://IP_of_your_station:30053/stats.html
It works on local network only.
...and more detailed info is available by picking your station through the sharers list: (using country filter). https://planefinder.net/coverage/receivers/
regards,
Janos
