ModeSMixer2 crashes immediately after startup (Windows)
MrSoolmaan
I want my SBS-1e to feed data to VRS and I've heard I need ModeSMixer2 for this.
When I startup ModeSMixer2 it almost immediately crashes on my Windows PC. I've tried on Windows 7, 8, 10 and Windows Server 2012.
As it crashes on all these different PC's I must be doing something wrong.
I use this start line : modesmixer2.exe --inConnect 192.168.1.170:10001 --outServer avr:c
I want it to connect to my SBS-1e over the network. Basestation can connect succesfully to 192.168.1.170:10001
Any ideas why ModeSMixer2 crashes?
Thanks for any help!
MartinC
From modesmixer2 --help
--outServer arg Output server. Format: type:port Types: beast,avr,avrmlat,msg,sbs30006,sbs10001,fatsv
shouldn't your outServer be specifying a port number like -outServer avr:10101?
Martin
MrSoolmaan
Thanks Martin!
Yes you are right, after adding that the software did not crash.
However, it connects now, and VRS also connects, but I'm not seeing any messages.
My startline : modesmixer2 --inConnect 192.168.1.170:10001 --outServer avr:10101 --web 8080
At startup I get this log:
2016-03-05 17:01:49.006 INFO ModeSMixer2 v.20150825
2016-03-05 17:01:49.011 INFO outServer(avr:10101) started
2016-03-05 17:01:49.015 INFO inConnect(192.168.1.170:10001) connecting 192.168.1.170:10001
2016-03-05 17:01:49.019 INFO inConnect(192.168.1.170:10001) connected
2016-03-05 17:01:49.120 INFO outServer(avr:10101) 127.0.0.1:58286 connected
So this does look good. In VRS I also see connected, but Total Messages 0, Bad Messages 0, Aircraft Tracked 0
Any ideas what could be going wrong?
MartinC
I am using a Beast connecting on a serial port with a start line of
modesmixer2.exe --inSerial COM4:3000000:hardware --outServer beast:33001
I feed RAW data to VRS hence the beast format on the outServer
Here's the log that goes with it...
2016-03-07 11:29:24.353 INFO ModeSMixer2 20141121
2016-03-07 11:29:24.362 INFO InputServer added
2016-03-07 11:29:24.382 INFO inSerial(COM4) connected
2016-03-07 11:29:24.384 INFO OutputServer added
2016-03-07 11:29:24.386 INFO outServer(beast:33001) started
2016-03-07 11:29:24.388 INFO inSerial(COM4) BEAST data stream detected
2016-03-07 11:29:24.678 INFO outServer(beast:33001) connected 127.0.0.1:49788
2016-03-07 11:29:24.682 INFO outServer(beast:33001) started
2016-03-07 11:29:25.756 INFO Determination of coverage area for feed done
2016-03-07 11:29:26.013 INFO outServer(beast:33001) connected 127.0.0.1:49800
2016-03-07 11:29:26.015 INFO outServer(beast:33001) started
2016-03-07 11:29:27.072 INFO outServer(beast:33001) connected 127.0.0.1:49811
2016-03-07 11:29:27.074 INFO outServer(beast:33001) started
2016-03-07 11:29:29.509 INFO outServer(beast:33001) connected 127.0.0.1:49854
2016-03-07 11:29:29.516 INFO outServer(beast:33001) started
Martin
