Plane Finder Client Beta 4 (3.0.2080)
#23
cant answer that yet. this is my first 24 hours with the new client, the latest the flight listing shows is 8am local. so heres the log from 8-9am local -230 utc
2015-08-21 09:00:01.651221 Successfully sent 39 aircraft updates over the past minute (3.00kb)
2015-08-21 08:58:58.940251 Successfully sent 41 aircraft updates over the past minute (3.00kb)
2015-08-21 08:57:55.668535 Successfully sent 42 aircraft updates over the past minute (3.00kb)
2015-08-21 08:56:53.84643 Successfully sent 41 aircraft updates over the past minute (3.00kb)
2015-08-21 08:55:50.81753 Successfully sent 39 aircraft updates over the past minute (3.00kb)
2015-08-21 08:54:47.334854 Successfully sent 38 aircraft updates over the past minute (3.00kb)
2015-08-21 08:53:44.689974 Successfully sent 40 aircraft updates over the past minute (3.00kb)
2015-08-21 08:52:42.211395 Successfully sent 47 aircraft updates over the past minute (4.00kb)
2015-08-21 08:51:39.679578 Successfully sent 50 aircraft updates over the past minute (4.00kb)
2015-08-21 08:50:37.157270 Successfully sent 53 aircraft updates over the past minute (4.00kb)
2015-08-21 08:49:34.150457 Successfully sent 48 aircraft updates over the past minute (4.00kb)
2015-08-21 08:48:31.372219 Successfully sent 49 aircraft updates over the past minute (4.00kb)
2015-08-21 08:47:27.493411 Successfully sent 52 aircraft updates over the past minute (4.00kb)
2015-08-21 08:46:23.981567 Successfully sent 59 aircraft updates over the past minute (4.00kb)
2015-08-21 08:45:21.71835 Successfully sent 60 aircraft updates over the past minute (4.00kb)
2015-08-21 08:44:18.479175 Successfully sent 60 aircraft updates over the past minute (4.00kb)
2015-08-21 08:43:15.828193 Successfully sent 60 aircraft updates over the past minute (4.00kb)
2015-08-21 08:42:11.912333 Successfully sent 54 aircraft updates over the past minute (4.00kb)
2015-08-21 08:41:30.602968 TCP connection established: localhost:1005
2015-08-21 08:41:30.601994 Client restarted successfully
2015-08-21 08:41:30.601994 Closed TCP connection: localhost:1005
2015-08-21 08:41:30.601994 Decoder select timeout occurred, restarting...
2015-08-21 08:40:55.972332 Successfully sent 60 aircraft updates over the past minute (4.00kb)
2015-08-21 08:39:52.296189 Successfully sent 59 aircraft updates over the past minute (4.00kb)
2015-08-21 08:38:49.517218 Successfully sent 54 aircraft updates over the past minute (4.00kb)
2015-08-21 08:37:44.955338 Successfully sent 54 aircraft updates over the past minute (4.00kb)
2015-08-21 08:36:40.222178 Successfully sent 48 aircraft updates over the past minute (4.00kb)
2015-08-21 08:35:35.649578 Successfully sent 48 aircraft updates over the past minute (4.00kb)
2015-08-21 08:34:33.21873 Successfully sent 46 aircraft updates over the past minute (4.00kb)
2015-08-21 08:33:29.948174 Successfully sent 49 aircraft updates over the past minute (4.00kb)
2015-08-21 08:32:26.797390 Successfully sent 45 aircraft updates over the past minute (4.00kb)
2015-08-21 08:31:23.781781 Successfully sent 38 aircraft updates over the past minute (3.00kb)
2015-08-21 08:30:16.6253 Successfully sent 37 aircraft updates over the past minute (3.00kb)
2015-08-21 08:29:06.193243 Successfully sent 29 aircraft updates over the past minute (3.00kb)
2015-08-21 08:27:59.304224 Successfully sent 35 aircraft updates over the past minute (3.00kb)
2015-08-21 08:27:12.29630 Failed to establish a data proxy connection. Receiver data cannot be sent!
2015-08-21 08:27:12.29630 Failed to connect to all known addresses for host: 'dataupload.planefinder.net'
2015-08-21 08:26:20.207116 Successfully sent 29 aircraft updates over the past minute (3.00kb)
2015-08-21 08:25:15.665896 Successfully sent 30 aircraft updates over the past minute (3.00kb)
2015-08-21 08:24:13.317873 Successfully sent 31 aircraft updates over the past minute (3.00kb)
2015-08-21 08:23:11.47063 Successfully sent 36 aircraft updates over the past minute (3.00kb)
2015-08-21 08:22:08.687167 Successfully sent 34 aircraft updates over the past minute (3.00kb)
2015-08-21 08:21:05.165765 Successfully sent 30 aircraft updates over the past minute (3.00kb)
2015-08-21 08:20:02.296492 Successfully sent 28 aircraft updates over the past minute (3.00kb)
2015-08-21 08:18:58.745762 Successfully sent 24 aircraft updates over the past minute (3.00kb)
2015-08-21 08:17:56.320184 Successfully sent 24 aircraft updates over the past minute (3.00kb)
2015-08-21 08:16:54.25364 Successfully sent 28 aircraft updates over the past minute (3.00kb)
2015-08-21 08:15:50.185377 Successfully sent 25 aircraft updates over the past minute (3.00kb)
2015-08-21 08:14:46.297333 Successfully sent 18 aircraft updates over the past minute (3.00kb)
2015-08-21 08:13:42.193118 Successfully sent 18 aircraft updates over the past minute (3.00kb)
2015-08-21 08:12:39.949416 Successfully sent 18 aircraft updates over the past minute (3.00kb)
2015-08-21 08:11:37.628781 Successfully sent 18 aircraft updates over the past minute (3.00kb)
2015-08-21 08:10:35.308127 Successfully sent 23 aircraft updates over the past minute (3.00kb)
2015-08-21 08:09:29.804981 Successfully sent 30 aircraft updates over the past minute (3.00kb)
2015-08-21 08:08:26.36141 Successfully sent 35 aircraft updates over the past minute (4.00kb)
2015-08-21 08:07:23.176558 Successfully sent 32 aircraft updates over the past minute (4.00kb)
2015-08-21 08:06:19.404781 Successfully sent 39 aircraft updates over the past minute (4.00kb)
2015-08-21 08:05:16.875199 Successfully sent 41 aircraft updates over the past minute (4.00kb)
2015-08-21 08:04:14.206398 Successfully sent 40 aircraft updates over the past minute (4.00kb)
2015-08-21 08:03:11.714820 Successfully sent 37 aircraft updates over the past minute (4.00kb)
2015-08-21 08:02:08.241084 Successfully sent 36 aircraft updates over the past minute (4.00kb)
#27
also, i should add, in my planefinder.net account, the sharecode showed offline since 8am, even though it was sending live updates onward. i had to force close and restrt. the restart option in the pfclient popup menu didnt work
#29
you wrote:
Highlights of this release are...
MLAT now supported with Radarcape receivers
Radarcape has a function to feed directly to planefinder.
With this internal function MLAT does not work ?
Does MLAT work only with your ADSB Software?
Radarcape -> PC (Windows/linux) with planefinder ADSB client -> planefinder.net
What output format from Radarcape to PC is needed in that case.
#30
The internal radarcape feeder doesn't support MLAT and in fact will be removed from future versions as it can send some data we are not happy with.
You can install our new client directly on the Radarcape however and this does support MLAT
#35
For PF,i used ADS-B Dongle... but the problem is..this setting 'jumped' into FR24 line..
also the amount of data sent to server is about 1.4Mb/day..is it too much? i also would like to inform that DO not send me the email telling me the dongle is off for many hours..very irritating as the ASDB dongle is seldom used for 24 hrs non-stop. I need to switched off the computer too before go to bed. The only thing that is left to run 24 hrs is my FR24 unit which is a stand-alone unit.
YSWG
#36
Occasionally I get these errors, but not always together. The RPi uses the Google DNS, rather than the modem (since my ISP's DNS is unreliable)
2015-08-30 03:32:52.305629 Successfully sent 103 aircraft updates over the past minute (9.00kb)
2015-08-30 03:32:39.311538 TCP connection established: 10.0.0.45:30005
2015-08-30 03:32:34.310752 Failed TCP connection to all provided addresses for: 10.0.0.45:30005
2015-08-30 03:32:34.310661 Failed to resolve remote socket address 10.0.0.45 30005: Name or service not known (errno: -2)
2015-08-30 03:32:34.310365 Client restarted successfully
2015-08-30 03:32:34.310290 Closed TCP connection: 10.0.0.45:30005
2015-08-30 03:32:34.310004 Decoder select timeout occurred, restarting...
2015-08-30 03:32:30.19191 Failed to establish a data proxy connection. Receiver data cannot be sent!
2015-08-30 03:32:30.18970 Failed to resolve remote socket address dataupload.planefinder.net 80: Name or service not known (errno: -2)
#37
is there / will we have the ability to run multiple instances of the client, for locations that cant run thr client locally? for example i have receivers in newfoundland, alberta, and british columbia, i would like to devote 1 instance each on my master server
#38
The Linux version sits quite happily alongside one another. Windows version not so sure
#40
I can supply details on getting this to work side by side on Linux but wouldn't want to do this on Windows.
The Windows version is not our preferred install OS by a LONG shot!
