Plane Finder Client Beta 4 (3.0.2080)
#83
You will find it uses a fraction less CPU
Do we need to run PF software with modesdeco2_windows to allow the data to be sent???
Without modesdeco2_windows
2015-11-26 16:15:53.206344 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-11-26 16:15:53.206344 Failed to connect to all known addresses for host: '127.0.0.1'
2015-11-26 16:15:47.184229 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-11-26 16:15:47.184229 Failed to connect to all known addresses for host: '127.0.0.1'
2015-11-26 16:15:41.158818 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-11-26 16:15:41.158818 Failed to connect to all known addresses for host: '127.0.0.1'
2015-11-26 16:15:35.135907 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-11-26 16:15:35.135907 Failed to connect to all known addresses for host: '127.0.0.1'
2015-11-26 16:15:29.127996 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-11-26 16:15:29.127996 Failed to connect to all known addresses for host: '127.0.0.1'
2015-11-26 16:15:23.86386 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-11-26 16:15:23.86386 Failed to connect to all known addresses for host: '127.0.0.1'
2015-11-26 16:15:17.65375 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-11-26 16:15:17.65375 Failed to connect to all known addresses for host: '127.0.0.1'
With modesdeco2_windows
2015-11-26 16:26:36.497928 TCP connection established: 127.0.0.1:30005
2015-11-26 16:26:36.497928 Client restarted successfully
2015-11-26 16:26:36.497928 Closed TCP connection: 127.0.0.1:30005
2015-11-26 16:18:04.755083 TCP connection established: 127.0.0.1:30005
#87
I'm really sorry but I don't know what else we can do!
The errors you see in the log don't matter and won't affect the stats drop you are seeing. You refer to another site in the local area with a similar drop so it could be something external in the area, perhaps some interference!
Do the other sites you feed offer the detailed stats we do so you can see the drop there too? This is not about uptime, it is amount of data which the graph you showed from somewhere else does not show.
Dear Lee,
Somehow my problem solved after 16 days suffering. Don't know what happened, how it solved. Real Beneficiary of this event is FA, they are getting my feed(i am the first from my country for FA) as a testing phase !
Zahidul Hasan.
FAJS5
#89
Hi All,
new to Pi and had some teething issues
I'm just a bit confused
when I installed the PF feeder in the Pi
I didn't feed and had the following log errors
2015-12-16 21:02:24.672838 Attempted to exceed maximum Mode-S AVR-TCP packet buffer size
2015-12-16 21:02:21.856275 Attempted to exceed maximum Mode-S AVR-TCP packet buffer size
2015-12-16 21:02:05.862879 TCP connection established: 127.0.0.1:30005
2015-12-16 21:02:05.862213 Echo port is now listening on: 192.168.16.60:30054
2015-12-16 21:02:05.861983 Web server is now listening on: http://192.168.16.60:30053
2015-12-16 21:02:05.857711 user_longitude = 28.xxxxxx
2015-12-16 21:02:05.857613 user_latitude = -26.xxxxx
2015-12-16 21:02:05.857501 web_server_port = 30053
2015-12-16 21:02:05.857425 select_timeout = 10
2015-12-16 21:02:05.857357 aircraft_timeout = 30
2015-12-16 21:02:05.857283 data_format = 4
2015-12-16 21:02:05.857206 tcp_port = 30005
2015-12-16 21:02:05.857121 tcp_address = 127.0.0.1
2015-12-16 21:02:05.856997 connection_type = 1
2015-12-16 21:02:05.856077 pfclient (3.1.201 armhf) started with the following options:
additional to that, I lost my PF key and couldn't change settings
got it since and just pressed buttons till it started working
Tcp Address 127.0.0.1
Tcp Port 30005
Select Timeout 10
Data Upload Interval 10
Data Format Beast
Connection Type TCP
Aircraft Timeout 30
Latitude -26.074501
Longitude 28.222915
I changed the radio from AVR-TCP to BEAST
and all running ok - even thou I'm using a DVT dongle
Please explain this to me, or should I use different settings ?
p.s. Im runnng the Flighaware Pi version ( latest )
with FR24, ADSB Exc & PFinder feeders
#90
I think you've worked it out but the port you've connected to on Dump1090 must be outputting beast format.
Also the sharecode would have been on the web page after setting up and mailed to you as well.
#91
hey lee,
question for ya, seems the rpi2 deb relies on the system to be using systemd in order to run as service/autostart, however im using upstart as i find it easier to write confs for my apps, is there something i can do to autorun pfclient within upstart?
#92
It actually is using simple init scripts that Debian seems to convert to systemd config if that is installed.
Take a look at the init scripts I think it leaves behind or the systemd config for the option we need to start it up.
#93
ive gone ahead and completly removed stsyemd and will rely on upstart. however after reinstall of pfclient.deb i see in the logs its not creating a systemd config like it did before, but still not autostarting. if i go with the tgz route for pf client, what are (if any) the run arguments
#96
Hey everyone. Long time no see. I'm building an ads-b box on an Ubuntu (Linux Mint) laptop. What's the latest Linux client, and is there one for amd64? Thanks.
#97
you can see all the clients available @ https://planefinder.net/sharing/client
i only see a x86(i386) deb for linux, you can wget the installer with:
wget http://client.planefinder.net/pfclient_3.0.2080_i386.deb
then
sudo dpkg -i pfclient_3.0.2080_i386.deb
and your done.
browse to 127.0.0.1(or LAN IP):30053 and complete setup
