Hello everyone,
Thank you all for installing the last beta and a special thanks to those that we worked with directly on a couple of issues.
The latest version is 3.0.1435 and can be found here along with a change log which we will keep updated there too.
For those who want the commands for the update it is simply..
Hopefully CPU should be a bit lower than before for those that saw it higher than we did in our testing. Not a huge amount of new stuff for Pi users just some increased stability.
What is new though is a native build that can be installed directly on the Radarcape unit. This is a slightly different build and is designed at the moment for the default Angstrom with soft float support. To install it is simply a case of ssh'ing to the unit and running.
If you need help with the SSH part we suggest you look at http://wiki.modesbeast.com
Once installed follow the same instructions as a Pi for setup by visiting http://<ip of unit>:30053. Obvious differences are to set the "Format" to "Radarcape" and to also set it to "127.0.0.1" and "10006" for the IP and port.
wget http://client.planefinder.net/pfclient_3.0.1435_armhf.deb
sudo dpkg -i pfclient_3.0.1435_armhf.deb
opkg install http://client.planefinder.net/pfclient_3.0.1435_armel.opk
