2015-05-22 08:30:14.275422 Successfully sent 126 aircraft updates over the past minute (10.00kb)
2015-05-22 08:29:11.105520 Successfully sent 127 aircraft updates over the past minute (10.00kb)
2015-05-22 08:28:07.507473 Successfully sent 119 aircraft updates over the past minute (10.00kb)
2015-05-22 08:27:05.11742 Successfully sent 119 aircraft updates over the past minute (10.00kb)
2015-05-22 08:26:02.76098 Successfully sent 128 aircraft updates over the past minute (10.00kb)
2015-05-22 08:24:59.128690 Successfully sent 115 aircraft updates over the past minute (9.00kb)
2015-05-22 08:24:34.291300 User location has been verified.
2015-05-22 08:23:56.652562 TCP connection established: 127.0.01:30005
2015-05-22 08:23:56.652132 Web server is now listening on:
http://192.168.1.42:30053
2015-05-22 08:23:56.646145 Echo port is now listening on:
http://192.168.1.42:30054
2015-05-22 08:23:56.619524 user_longitude = 14.204050
2015-05-22 08:23:56.619371 user_latitude = 51.681805
2015-05-22 08:23:56.619213 web_server_port = 30053
2015-05-22 08:23:56.619090 select_timeout = 10
2015-05-22 08:23:56.618970 aircraft_timeout = 30
2015-05-22 08:23:56.618843 data_format = 1
2015-05-22 08:23:56.618720 tcp_port = 30005
2015-05-22 08:23:56.618594 tcp_address = 127.0.01
2015-05-22 08:23:56.618455 connection_type = 1
2015-05-22 08:23:56.617613 pfclient (3.0.1657 armhf) started with the following options:
2015-05-22 08:23:50.25132 Web server is shutting down
2015-05-22 08:23:42.398769 Shutting down workers...
2015-05-22 08:23:42.398569 Closed TCP connection
2015-05-22 08:23:42.398015 poll returned with error: Interrupted system call (errno: 4)
2015-05-22 08:23:42.397638 Processing shutdown request...
2015-05-22 08:23:18.266410 Successfully sent 117 aircraft updates over the past minute (10.00kb)
2015-05-22 08:22:14.859210 Successfully sent 130 aircraft updates over the past minute (10.00kb)
2015-05-22 08:21:11.992405 Successfully sent 129 aircraft updates over the past minute (11.00kb)
2015-05-22 08:20:09.572808 Successfully sent 115 aircraft updates over the past minute (10.00kb)
2015-05-22 08:19:06.728052 Successfully sent 116 aircraft updates over the past minute (10.00kb)
2015-05-22 08:18:03.625671 Successfully sent 119 aircraft updates over the past minute (10.00kb)
2015-05-22 08:17:00.786447 Successfully sent 114 aircraft updates over the past minute (10.00kb)
2015-05-22 08:15:58.207251 Successfully sent 115 aircraft updates over the past minute (10.00kb)
2015-05-22 08:14:54.606617 Successfully sent 121 aircraft updates over the past minute (10.00kb)
2015-05-22 08:13:51.381246 Successfully sent 126 aircraft updates over the past minute (11.00kb)
2015-05-22 08:12:48.545820 Successfully sent 141 aircraft updates over the past minute (11.00kb)
2015-05-22 08:11:45.721462 Successfully sent 130 aircraft updates over the past minute (11.00kb)
2015-05-22 08:10:42.832447 Successfully sent 124 aircraft updates over the past minute (11.00kb)
2015-05-22 08:09:39.831158 Successfully sent 103 aircraft updates over the past minute (10.00kb)
2015-05-22 08:08:29.225831 Successfully sent 95 aircraft updates over the past minute (9.00kb)
2015-05-22 08:07:26.279074 Successfully sent 103 aircraft updates over the past minute (10.00kb)
2015-05-22 08:06:23.364713 Successfully sent 96 aircraft updates over the past minute (9.00kb)
2015-05-22 08:05:20.590764 Successfully sent 98 aircraft updates over the past minute (9.00kb)
2015-05-22 08:04:17.995259 Successfully sent 94 aircraft updates over the past minute (9.00kb)
2015-05-22 08:03:14.925258 Successfully sent 83 aircraft updates over the past minute (8.00kb)
2015-05-22 08:02:39.242507 User location has been verified.
2015-05-22 08:02:11.919513 TCP connection established: 127.0.01:30005
2015-05-22 08:02:11.919133 Web server is now listening on:
2015-05-22 08:02:11.888233 user_longitude = 14.204050
2015-05-22 08:02:11.888090 user_latitude = 51.681805
2015-05-22 08:02:11.887938 web_server_port = 30053
2015-05-22 08:02:11.887824 poll_timeout = 10000
2015-05-22 08:02:11.887709 aircraft_timeout = 30
2015-05-22 08:02:11.887591 data_format = 1
2015-05-22 08:02:11.887458 tcp_port = 30005
2015-05-22 08:02:11.887200 tcp_address = 127.0.01
2015-05-22 08:02:11.886930 connection_type = 1
2015-05-22 08:02:11.885792 pfclient version: 3.0.1435 started with the following options:
2015-05-22 08:02:02.445113 Web server is shutting down
2015-05-22 08:01:56.467027 Shutting down workers...
2015-05-22 08:01:56.466838 Closed TCP connection
2015-05-22 08:01:56.466268 poll returned with error: Interrupted system call (errno: 4)
2015-05-22 08:01:56.465878 Processing shutdown request...
2015-05-22 08:01:36.272280 User location has been verified.
2015-05-22 08:01:23.66076 TCP connection established: 127.0.01:30005
2015-05-22 08:01:23.64623 Client restarted successfully
2015-05-22 08:01:23.64359 Closed TCP connection
2015-05-22 08:01:22.964860 Remote request to restart client received
2015-05-22 07:59:24.196368 Web server is shutting down
2015-05-22 07:59:19.972679 Shutting down workers...
2015-05-22 07:59:19.972392 Processing shutdown request...
2015-05-22 07:59:18.859272 Failed connection to all provided addresses
2015-05-22 07:59:18.859046 Failed to open connection to socket: Connection refused (errno: 111)
2015-05-22 07:59:18.858094 Client restarted successfully
2015-05-22 07:59:18.857910 Closed TCP connection
2015-05-22 07:59:18.857441 Zero-byte response received, closing connection
2015-05-22 07:59:03.448358 TCP connection established: 127.0.01:30005
2015-05-22 07:59:03.447161 Client restarted successfully
2015-05-22 07:59:03.446809 Closed TCP connection
2015-05-22 07:59:03.446275 poll timeout occurred, restarting...
2015-05-22 07:58:53.438271 TCP connection established: 127.0.01:30005
2015-05-22 07:58:53.437098 Client restarted successfully
2015-05-22 07:58:53.436902 Closed TCP connection
2015-05-22 07:58:53.436331 poll timeout occurred, restarting...
2015-05-22 07:58:42.14321 Successfully sent 3 aircraft updates over the past minute (2.00kb)
2015-05-22 07:58:19.68078 TCP connection established: 127.0.01:30005
2015-05-22 07:58:19.66973 Client restarted successfully
2015-05-22 07:58:19.66781 Closed TCP connection
2015-05-22 07:58:19.66257 poll timeout occurred, restarting...
2015-05-22 07:58:09.58306 TCP connection established: 127.0.01:30005
2015-05-22 07:58:09.56995 Client restarted successfully
2015-05-22 07:58:09.56802 Closed TCP connection
2015-05-22 07:58:09.56265 poll timeout occurred, restarting...
2015-05-22 07:57:48.568135 TCP connection established: 127.0.01:30005
2015-05-22 07:57:48.566976 Client restarted successfully
2015-05-22 07:57:48.566785 Closed TCP connection
2015-05-22 07:57:48.566259 poll timeout occurred, restarting...
2015-05-22 07:57:39.604576 Successfully sent 10 aircraft updates over the past minute (3.00kb)
2015-05-22 07:56:37.677415 Successfully sent 16 aircraft updates over the past minute (3.00kb)
2015-05-22 07:55:36.290701 Successfully sent 7 aircraft updates over the past minute (2.00kb)
2015-05-22 07:55:02.7804 TCP connection established: 127.0.01:30005
2015-05-22 07:54:57.6396 Failed connection to all provided addresses
2015-05-22 07:54:56.805531 Failed to open connection to socket: Connection refused (errno: 111)
2015-05-22 07:54:51.804303 Failed connection to all provided addresses
2015-05-22 07:54:51.539990 Failed to open connection to socket: Connection refused (errno: 111)
2015-05-22 07:54:46.538773 Failed connection to all provided addresses
2015-05-22 07:54:46.279238 Failed to open connection to socket: Connection refused (errno: 111)
