Plane Finder Client New Version! 3.3.222
MartinC
Lee,
Since updating to the latest version, I am seeing blocks of...
gethostbyname failed with errno: 11001
...this might be coincidence but, then again it might not. Googling the error 11001 mentions "Stack overflow" which doesn't sound healthy.
Running Win 10 with plenty of free resources and Client 3.3 (222).
Martin
Hi Martin,
We have actually increased logging but is it connecting fine after getting those errors?
Perhaps you could share your config here? Please make sure you remove the share code though.
Lee
MartinC
Hi Lee,
Thanks for replying.
In order to post my log to here I opened it in an editor rather than just looking at it through the web i/f. It appears there's another error that I wasn't seeing in the browser...
2016-02-09 11:15:31.259275 [-] Successfully sent 912 aircraft updates across 10 packets (74.00KB)
2016-02-09 11:16:23.577206 [!] Failed to connect to all known addresses for host: 'dataupload.planefinder.net'
2016-02-09 11:16:23.577206 [V] Failed to establish a data proxy connection. Receiver data cannot be sent!
2016-02-09 11:16:54.585119 [!] Failed to connect to all known addresses for host: 'dataupload.planefinder.net'
2016-02-09 11:16:54.585119 [V] Failed to establish a data proxy connection. Receiver data cannot be sent!
2016-02-09 11:17:15.358000 [!] Failed to connect to all known addresses for host: 'dataupload.planefinder.net'
2016-02-09 11:17:15.358000 [V] Failed to establish a data proxy connection. Receiver data cannot be sent!
2016-02-09 11:17:36.405001 [!] gethostbyname failed with errno: 11001
2016-02-09 11:17:36.405001 [V] Failed to establish a data proxy connection. Receiver data cannot be sent!
2016-02-09 11:18:07.413912 [!] Failed to connect to all known addresses for host: 'dataupload.planefinder.net'
2016-02-09 11:18:07.413912 [V] Failed to establish a data proxy connection. Receiver data cannot be sent!
2016-02-09 11:18:38.426724 [!] Failed to connect to all known addresses for host: 'dataupload.planefinder.net'
2016-02-09 11:18:38.426724 [V] Failed to establish a data proxy connection. Receiver data cannot be sent!
2016-02-09 11:19:09.435151 [!] Failed to connect to all known addresses for host: 'dataupload.planefinder.net'
2016-02-09 11:19:09.435151 [V] Failed to establish a data proxy connection. Receiver data cannot be sent!
2016-02-09 11:19:19.443225 [!] gethostbyname failed with errno: 11001
2016-02-09 11:19:19.443734 [V] Failed to establish a data proxy connection. Receiver data cannot be sent!
2016-02-09 11:19:29.453842 [!] gethostbyname failed with errno: 11001
2016-02-09 11:19:29.453842 [V] Failed to establish a data proxy connection. Receiver data cannot be sent!
2016-02-09 11:19:39.475424 [!] gethostbyname failed with errno: 11001
2016-02-09 11:19:39.475424 [V] Failed to establish a data proxy connection. Receiver data cannot be sent!
2016-02-09 11:19:49.485531 [!] gethostbyname failed with errno: 11001
2016-02-09 11:19:49.485531 [V] Failed to establish a data proxy connection. Receiver data cannot be sent!
2016-02-09 11:19:59.510615 [!] gethostbyname failed with errno: 11001
2016-02-09 11:19:59.510615 [V] Failed to establish a data proxy connection. Receiver data cannot be sent!
2016-02-09 11:20:09.522689 [!] gethostbyname failed with errno: 11001
2016-02-09 11:20:09.522689 [V] Failed to establish a data proxy connection. Receiver data cannot be sent!
2016-02-09 11:20:19.547773 [!] gethostbyname failed with errno: 11001
2016-02-09 11:20:19.547773 [V] Failed to establish a data proxy connection. Receiver data cannot be sent!
2016-02-09 11:20:29.557623 [!] gethostbyname failed with errno: 11001
2016-02-09 11:20:29.557623 [V] Failed to establish a data proxy connection. Receiver data cannot be sent!
2016-02-09 11:20:39.567698 [!] gethostbyname failed with errno: 11001
2016-02-09 11:20:39.567698 [V] Failed to establish a data proxy connection. Receiver data cannot be sent!
2016-02-09 11:20:49.575769 [!] gethostbyname failed with errno: 11001
2016-02-09 11:20:49.576270 [V] Failed to establish a data proxy connection. Receiver data cannot be sent!
2016-02-09 11:22:14.726500 [-] Successfully sent 917 aircraft updates across 10 packets (72.00KB)
2016-02-09 11:24:02.419964 [-] Successfully sent 916 aircraft updates across 10 packets (71.00KB)
2016-02-09 11:25:49.256399 [-] Successfully sent 822 aircraft updates across 10 packets (64.00KB)
2016-02-09 11:27:34.980635 [-] Successfully sent 771 aircraft updates across 10 packets (63.00KB)
2016-02-09 11:29:21.57262 [-] Successfully sent 807 aircraft updates across 10 packets (64.00KB)
...tell me where the config lives and I'll post it here too.
Martin
Strange, looks like DNS failed temporarily to resolve the IP address of our hosts, I wouldn't worry too much but if it happens again I would look at what your system DNS is set to and maybe change them to something like the Google DNS servers on 8.8.8.8 & 8.8.4.4
I've been running the update for a few days now. All seems OK and no errors reported in the log.
Marty Becker
I have been these errors for several hours.
2016-02-12 00:08:12.144016 [!] Data upload failed with error: 'Database error'
I am seeing activity on the local client.
Marty
Marty Becker
Hi Marty,
Is it still doing it now?
Lee
Yes, Lee.
Marty
2016-02-12 02:25:26.188152 [!] Data upload failed with error: 'Database error'2016-02-12 02:25:15.601705 [!] Data upload failed with error: 'Database error'2016-02-12 02:25:04.991266 [!] Data upload failed with error: 'Database error'2016-02-12 02:24:54.70337 [!] Data upload failed with error: 'Database error'2016-02-12 02:24:43.449942 [!] Data upload failed with error: 'Database error'2016-02-12 02:24:32.795945 [!] Data upload failed with error: 'Database error'2016-02-12 02:24:22.179130 [!] Data upload failed with error: 'Database error'2016-02-12 02:24:11.537837 [!] Data upload failed with error: 'Database error'2016-02-12 02:24:00.846579 [!] Data upload failed with error: 'Database error'2016-02-12 02:23:50.225655 [!] Data upload failed with error: 'Database error'2016-02-12 02:23:39.576095 [!] Data upload failed with error: 'Database error'2016-02-12 02:23:28.873089 [!] Data upload failed with error: 'Database error'2016-02-12 02:23:18.249608 [!] Data upload failed with error: 'Database error'2016-02-12 02:23:07.729213 [!] Data upload failed with error: 'Database error'2016-02-12 02:22:57.187274 [!] Data upload failed with error: 'Database error'
Marty Becker
Looks like it is returnung to normal.
Marty
2016-02-12 02:47:13.123669 [-] Successfully sent 1432 aircraft updates across 10 packets (62.00KB)2016-02-12 02:45:14.887486 [-] Successfully sent 1480 aircraft updates across 10 packets (65.00KB)2016-02-12 02:43:15.687303 [-] Successfully sent 1480 aircraft updates across 10 packets (65.00KB)2016-02-12 02:41:16.95308 [-] Successfully sent 1498 aircraft updates across 10 packets (65.00KB)2016-02-12 02:41:03.989920 [!] Failed to parse response from Plane Finder server: HTTP/1.1 404 Not Found2016-02-12 02:40:53.585956 [!] Failed to parse response from Plane Finder server: HTTP/1.1 404 Not Found2016-02-12 02:39:42.597821 [!] Failed to parse response from Plane Finder server: HTTP/1.1 404 Not Found2016-02-12 02:39:32.201009 [!] Failed to parse response from Plane Finder server: HTTP/1.1 404 Not Found2016-02-12 02:39:21.783820 [-] Successfully sent 1548 aircraft updates across 10 packets (67.00KB)2016-02-12 02:38:44.969304 [!] Failed to parse response from Plane Finder server: HTTP/1.1 404 Not Found2016-02-12 02:38:34.569526 [!] Failed to parse response from Plane Finder server: HTTP/1.1 404 Not Found2016-02-12 02:38:24.174543 [!] Failed to parse response from Plane Finder server: HTTP/1.1 404 Not Found2016-02-12 02:38:01.774011 [!] Failed to parse response from Plane Finder server: HTTP/1.1 404 Not Found2016-02-12 02:37:51.385504 [!] Failed to parse response from Plane Finder server: HTTP/1.1 404 Not Found2016-02-12 02:37:28.846228 [-] Successfully sent 70584 aircraft updates across 443 packets (2895.00KB)2016-02-12 02:37:16.779674 [!] Data upload failed with error: 'Database error'2016-02-12 02:37:06.297060 [!] Data upload failed with error: 'Database error'2016-02-12 02:36:55.777217 [!] Data upload failed with error: 'Database error'2016-02-12 02:36:45.303178 [!] Failed to parse response from Plane Finder server: HTTP/1.1 500 hphp_invoke2016-02-12 02:36:34.896115 [!] Data upload failed with error: 'Database error'2016-02-12 02:36:24.443960 [!] Data upload failed with error: 'Database error'2016-02-12 02:36:13.993065 [!] Data upload failed with error: 'Database error'2016-02-12 02:36:03.473669 [!] Data upload failed with error: 'Database error'2016-02-12 02:35:52.916992 [!] Data upload failed with error: 'Database error'2016-02-12 02:35:42.346941 [!] Data upload failed with error: 'Database error'
Hi Lee,
Update complete to version 3.3.222 armhf on my pi2, no problems encountered so far.
Quick difference noted , now blue and yellow aircraft colours on map view :30053
Mike.
Just a quickie, rebooted and now feeder running 3.3.222 but no data being processed, map view blank, tried setting pi to avr tcp to loopback 127.0.0.1 and 30005, still no joy so far.
Edit , got it working again on localhost :30053 but web view very slow to load on occasions or wont load at all.
I now have blue coloured mlat aircraft and yellow others, this did not happen with previous pfclient version .What has changed to make this happen..I like that bit !
Chris VE3ZO
I'm not seeing any information. using the network configuration and have it set to Kinetic..more than likely an error on my part. localip:30053
Hi chris VE3ZO, I eventually got things working again by using network config localhost beast port :30005.
I was using loopback 127.0.0.1:30005 which is the prefered way but when i did, my 30053 screen view had no aircraft, just a map.
Hope this helps,
Mike M0RRQ.
Oz Wald
New version running like a dream.
My new sharecode, going up, just met my old sharecode on the way down.
Chris VE3ZO
I am still unable to get this to work. Using a Kinetic 1090 puck and a beagleboard pc..provided by planefinder.
I tried the actual IP of the unit ..which is functioning perfectly on the web interface. and I also tried the ip and port listed above
Do i need to remove the old share name when the new one is put on the list, since they are the same unit?
It is also allowed through the firewall..
