Plane Finder Client New Version! 3.4.25
Hello Andreas,
We only publish the changes for major release and so the release notes for 3.7.x apply to all.
There have only been two releases since 3.7.1 and they only included fixes for the Radarcape receivers and also users in China. We only push out if there is a need.
In your case 3.7.20 to 3.7.40 there was nothing changed.
Lee
Andreas Warburton
Thanks a lot, Lee, for your super quick reply! Regarding the auto-update capability, would you be able to point me to how that is implemented in PF? For example, the FR24 folks use a script in /etc/cron.d
I think my pf auto-update capability is absent, so would like to troubleshoot it if possible.
Many thanks,
Andreas
Yes we wanted to keep out very simple as have seen issues with other clients and their updates and big issues!
3.7.40 was released on 22/01 but like I say it only had fixes for users in China. 3.7.20 was fixes for Radarcape V2 firmware and that was last May 2017.
Andreas Warburton
Got it, and understood now, thank you kindly! I, and I'm sure many of my fellow feeders, are grateful for the stability of your software. Thank you for your answers/support.
Best,
Andreas
4.1.1 includes Google Maps for now.
Please try not to use older versions as at some point the get blocked on our systems
I checked again, and found v 4.1.1 is DUAL mode.
By default Open Street Map, but can be switched to Google Map.
Delted v 3.7.40 from this post:
https://forum.planefinder.net/threads/raspberry-pi-b-rpi2-rpi3-installation-instructions-for-raspbian-dump1090-data-feeder.241/post-2451
Also there are following two additional features compared to v 3.7.40
(1) Range Ring
(2) Polar Curve
OPEN STREET MAP
GOOGLE MAP
Hi Lee,
Do I need to remove the 3.7.40 if I want to upgrade to 4.1.1?
On one of my Pi I removed 3.7.40, then installed 4.1.1
sudo dpkg --purge pfclient
wget http://client.planefinder.net/pfclient_4.1.1_armhf.deb
sudo dpkg -i pfclient_4.1.1_armhf.deb
On other Pi, I simply installed 4.1.1 over 3.7.40
Both the methods work ok.
FUNG SAI HOU
Hi ab cd,
Yes, thanks for the info. I simply overwrite it with just the method you shared to me.
It looks good, very good improvement for Planefinder. Well Done.
Sai Hou
FUNG SAI HOU
I found out that Planefinder (pfclient 4.1.1), the polar range chart will not update automatically. The down side of this new update is, it will not save the polar range chart. If it can be saved. then it would be nice.
Which polar chart on which map?
Are there any errors in the JavaScript console at all in the browser?
Also can you tell me the browser and operating system you are using to access it please?
We have never saved the polar chart on the device, if you want it saved then please visit the website which stores this.
FUNG SAI HOU
Hi Lee,
Thanks for the reply.
I am using Google Chrome, Windows 7 X64. The polar range chart will not auto update the range plot.
http://IP:30053/map.html
Look at the AXM6263, flight is there but the range will not plot automatically.
Sai Hou
