BenderCigar
Hi, I am running the PlaneFinder client on Windows 11. I am using a serial connected receiver that can either speak BEAST or AVR protocols. My receiver uses an FTDI USB to serial interface and requires a baud rate of 3000000 and RTS/CTS handshaking. I can create a Putty profile and connect to my receiver and, in AVR mode, see what looks like sensible information being sent from the receiver. The problem that I am running into with the plane finder client is that it says in the logs that it can not open the serial port. I have verified that I do not have an active Putty session (or other software) running that has the port open. I tried enabling the plane finder client to run as administrator. I rebooted my machine, all to no avail.
I tried specifying the serial port as “COM4”. “COM4:” and “com4” but no luck. Device Manager does not show any other serial deice named “COM4” or any variant. I verified that when I unplug my receiver, the COM4 device in Device Manager goes away (and comes back when I replug it).
The only thing that I can think of is that plane finder client does not support 3000000 baud. Also, how do I configure the serial port to use RTS/CTS (hardware) handshaking?
Log File:
2023-06-19 06:33:43.423595 [-] Attemping to open serial port 'COM4'
2023-06-19 06:33:38.415939 [!] Failed to open serial port: COM4
2023-06-19 06:33:38.415792 [-] Attemping to open serial port 'COM4'
2023-06-19 06:33:33.404500 [!] Failed to open serial port: COM4
2023-06-19 06:33:33.404467 [-] Attemping to open serial port 'COM4'
2023-06-19 06:33:33.404362 [-] Client restarted successfully
2023-06-19 06:33:32.665345 [-] Restarting due to configuration change
2023-06-19 06:33:17.834049 [-] Received a restart request, restarting...
Log File:
