Plane Finder Client (Windows Beta)
eddm_muc
Why are my old sharecodes (2 sites) not accepted and I have to create a new ones?
"the following error occured: Cannot use an old client sharecode, please create a new one for this client"
does this mean I will loose all stats until now?
It is a new system in the background so we cannot mix the codes.
That said the stats are only a rolling 30 days so it won't be long until they are back.
The built in client on the Radarcape uses the old sharing system with a username and password and will always stay that way.
Our new client can be installed on a Radarcape though but needs a new sharecode in the new system.
kucengemok
error..
2015-06-10 06:01:40.364430 Client restarted successfully
2015-06-10 06:01:39.796458 Restarting due to configuration change
2015-06-10 05:56:03.788590 Failed to establish a data proxy connection. Receiver data cannot be sent!
2015-06-10 05:56:03.787588 Failed to connect to all known addresses for host: 'dataupload.planefinder.net'
2015-06-10 05:52:18.298916 Echo port is now listening on: http://192.168.1.103:30054
2015-06-10 05:52:18.283291 Web server is now listening on: http://192.168.1.103:30053
2015-06-10 05:52:18.80166 We were unable to locate a configuration file and have entered configuration mode by default. Please visit: http://192.168.1.103:30053 to complete configuration.
Setting Value
Tcp Address
127.0.0.1
Tcp Port 30005
Select Timeout 10
Data Upload Interval 10
Data Format 30003
Connection Type TCP
error..
Setting Value
Tcp Address
127.0.0.1
Tcp Port 30005
Select Timeout 10
Data Format 30003
Connection Type TCP
Is that the only error in the log?
I think the error reported is temporary as I can see you connecting fine to the servers.
Are you seeing planes on a map?
Can you post the full log please?
What is the client connecting to? By the looks of the config it is Dump1090 on the local machine?
error..
Setting Value
Tcp Address
127.0.0.1
Tcp Port 30005
Select Timeout 10
Data Format 30003
Connection Type TCP
Actually, I think I have spotted your issue. You have data format 30003 but are connecting to port 30005 which if it is Dump1090 is BeastBinary format. Suggest you edit the settings on the client.
kucengemok
This is the contents of your client log file. It is updated every 5 seconds.
2015-06-10 07:56:36.493723 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:56:36.493723 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:56:30.475389 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:56:30.475389 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:56:24.458235 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:56:24.458235 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:56:18.431979 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:56:18.431979 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:56:12.424974 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:56:12.424974 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:56:06.390951 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:56:06.390951 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:56:00.382831 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:56:00.382831 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:55:54.375415 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:55:54.375415 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:55:48.344145 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:55:48.344145 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:55:42.295714 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:55:42.295714 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:55:36.264446 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:55:36.264446 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:55:30.233176 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:55:30.233176 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:55:24.219878 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:55:24.219878 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:55:18.204235 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:55:18.204235 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:55:12.196657 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:55:12.196657 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:55:06.173330 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:55:06.173330 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:55:00.163539 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:55:00.163539 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:54:54.144648 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:54:54.144648 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:54:48.124739 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:54:48.124739 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:54:42.114073 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:54:42.114073 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:54:36.90053 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:54:36.90053 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:54:30.89265 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:54:30.89265 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:54:24.84186 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:54:24.84186 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:54:18.75616 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:54:18.75616 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:54:12.38336 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:54:12.38336 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:54:06.34569 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:54:06.34569 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:54:00.18926 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:54:00.18926 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:53:53.982883 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:53:53.982883 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:53:47.963608 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:53:47.963608 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:53:41.957231 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:53:41.957231 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:53:35.931156 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:53:35.931156 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:53:29.900051 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:53:29.900051 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:53:23.884408 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:53:23.884408 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:53:17.855578 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:53:17.855578 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:53:11.839934 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:53:11.839934 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:53:05.825266 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:53:05.825266 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:52:59.805066 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:52:59.805066 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:52:53.795131 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:52:53.795131 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:52:47.774292 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:52:47.774292 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:52:41.757013 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:52:41.757013 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:52:35.728241 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:52:35.728241 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:52:29.704976 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:52:29.704976 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:52:23.673709 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:52:23.673709 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:52:17.634815 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:52:17.634815 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:52:11.604076 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:52:11.604076 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:52:05.593267 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:52:05.593267 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:51:59.586077 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:51:59.586077 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:51:53.567830 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:51:53.567830 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:51:47.520935 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:51:47.520935 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:51:41.504512 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:51:41.504512 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:51:35.473242 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:51:35.473242 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:51:29.455890 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:51:29.455890 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:51:23.436915 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:51:23.436915 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:51:17.421270 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:51:17.421270 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:51:11.405370 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:51:11.405370 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:51:05.402410 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:51:05.402410 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:50:59.355517 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:50:59.355517 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:50:53.329234 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:50:53.329234 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:50:47.313591 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:50:47.313591 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:50:41.297945 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:50:41.297945 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:50:35.274431 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:50:35.274431 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:50:29.256068 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:50:29.256068 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:50:23.232083 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:50:23.232083 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:50:17.225718 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:50:17.225718 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:50:11.194448 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:50:11.194448 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:50:05.164765 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:50:05.164765 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:49:59.133860 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:49:59.133860 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:49:53.119976 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:49:53.119976 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:49:47.113739 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:49:47.113739 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:49:41.113186 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:49:41.113186 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:49:35.89423 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:49:35.89423 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:49:29.63334 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:49:29.63334 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:49:23.32065 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:49:23.32065 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:49:17.6254 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:49:17.6254 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:49:11.3586 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:49:11.3586 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:49:04.994507 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:49:04.994507 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:48:58.963238 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:48:58.963238 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:48:52.956390 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:48:52.956390 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:48:46.925121 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:48:46.925121 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:48:40.894518 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:48:40.894518 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:48:34.888659 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:48:34.888659 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:48:28.861692 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:48:28.861692 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:48:22.825784 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:48:22.825784 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:48:16.794514 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:48:16.794514 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:48:10.782870 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:48:10.782870 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:48:04.763060 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:48:04.763060 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:47:58.730541 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:47:58.730541 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:47:52.720486 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:47:52.720486 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:47:46.690711 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:47:46.690711 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:47:40.675066 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:47:40.675066 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:47:34.671680 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:47:34.671680 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:47:28.650478 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:47:28.650478 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:47:22.603583 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:47:22.603583 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:47:16.572313 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:47:16.572313 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:47:10.537194 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:47:10.537194 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:47:04.530892 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:47:04.530892 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:46:58.514855 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:46:58.514855 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:46:52.493799 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:46:52.493799 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:46:46.462530 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:46:46.462530 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:46:40.435210 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:46:40.435210 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:46:34.412928 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:46:34.412928 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:46:28.396471 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:46:28.396471 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:46:22.358842 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:46:22.358842 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:46:16.312783 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:46:16.312783 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:46:10.303530 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:46:10.303530 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:46:04.293622 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:46:04.293622 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:45:58.281149 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:45:58.281149 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:45:52.258154 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:45:52.258154 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:45:46.211454 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:45:46.211454 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:45:40.188925 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:45:40.188925 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:45:34.142031 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:45:34.142031 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:45:32.642028 Failed to establish a data proxy connection. Receiver data cannot be sent!
2015-06-10 07:45:32.642028 Failed to connect to all known addresses for host: 'dataupload.planefinder.net'
2015-06-10 07:45:28.131302 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:45:28.131302 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:45:22.104310 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:45:22.104310 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:45:16.88666 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:45:16.88666 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:45:10.69541 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:45:10.69541 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:45:04.73425 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:45:04.73425 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:44:58.42157 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:44:58.42157 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:44:52.3049 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:44:52.3049 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:44:45.962120 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:44:45.962120 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:44:39.930850 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:44:39.930850 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:44:33.904597 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:44:33.904597 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:44:27.894232 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:44:27.894232 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:44:21.881485 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:44:21.881485 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:44:15.866472 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:44:15.866472 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:44:09.861647 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:44:09.861647 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:44:03.863444 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:44:03.863444 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:43:57.832176 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:43:57.832176 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:43:51.795303 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:43:51.795303 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:43:45.759484 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:43:45.759484 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:43:39.734504 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:43:39.734504 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:43:33.715314 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:43:33.715314 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:43:27.710914 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:43:27.710914 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:43:21.664021 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:43:21.664021 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:43:15.624868 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:43:15.624868 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:43:09.552854 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:43:09.552854 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:43:03.535242 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:43:03.535242 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:42:57.504093 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:42:57.504093 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:42:51.464757 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:42:51.464757 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:42:45.441946 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:42:45.441946 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:42:39.392117 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:42:39.392117 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:42:33.351227 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:42:33.351227 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:42:27.330968 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:42:27.330968 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:42:21.316339 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:42:21.316339 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:42:15.285108 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:42:15.285108 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:42:09.282084 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:42:09.282084 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:42:03.253028 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:42:03.253028 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:41:57.237851 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:41:57.237851 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:41:51.206581 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:41:51.206581 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:41:45.175436 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:41:45.175436 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:41:39.168637 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:41:39.168637 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:41:33.156071 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:41:33.156071 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:41:27.131497 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:41:27.131497 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:41:21.103343 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:41:21.103343 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:41:15.94707 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:41:15.94707 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:41:09.91266 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:41:09.91266 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:41:03.82657 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:41:03.82657 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:40:57.52732 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:40:57.52732 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:40:51.38681 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:40:51.38681 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:40:45.23034 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:40:45.23034 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:40:38.995266 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:40:38.995266 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:40:32.979412 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:40:32.979412 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:40:26.977994 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:40:26.977994 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:40:20.962350 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:40:20.962350 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:40:14.931643 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:40:14.931643 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:40:08.906590 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:40:08.906590 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:40:02.901741 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:40:02.901741 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:39:56.869705 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:39:56.869705 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:39:50.854389 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:39:50.854389 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:39:44.823121 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:39:44.823121 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:39:38.777060 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:39:38.777060 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:39:32.731369 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:39:32.731369 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:39:26.702685 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:39:26.702685 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:39:20.685008 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:39:20.685008 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:39:14.653737 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:39:14.653737 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:39:08.627731 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:39:08.627731 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:39:02.573648 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:39:02.573648 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:38:56.543320 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:38:56.543320 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:38:50.503644 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:38:50.503644 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:38:44.484381 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:38:44.484381 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:38:38.453111 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:38:38.453111 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:38:32.442938 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:38:32.442938 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:38:26.403508 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:38:26.403508 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:38:20.356613 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:38:20.356613 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:38:14.333555 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:38:14.333555 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:38:08.324945 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:38:08.324945 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:38:02.298745 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:38:02.298745 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:37:56.293028 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:37:56.293028 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:37:50.265173 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:37:50.265173 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:37:44.250505 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:37:44.250505 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:37:38.230979 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:37:38.230979 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:37:32.226459 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:37:32.226459 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:37:26.202896 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:37:26.202896 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:37:20.175035 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:37:20.175035 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:37:14.173389 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:37:14.173389 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:37:08.145241 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:37:08.145241 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:37:02.119973 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:37:02.119973 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:36:56.109050 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:36:56.109050 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:36:50.102671 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:36:50.102671 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:36:44.73875 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:36:44.73875 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:36:38.53833 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:36:38.53833 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:36:32.24666 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:36:32.24666 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:36:26.22464 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:36:26.22464 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:36:20.13973 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:36:20.13973 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:36:13.998327 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:36:13.998327 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:36:07.971933 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:36:07.971933 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:36:01.961706 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:36:01.961706 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:35:55.944813 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:35:55.944813 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:35:49.942379 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:35:49.942379 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:35:43.922225 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:35:43.922225 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:35:37.891255 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:35:37.891255 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:35:31.882629 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:35:31.882629 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:35:25.824542 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:35:25.824542 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:35:19.819269 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:35:19.819269 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:35:13.800953 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:35:13.800953 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:35:07.794920 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:35:07.794920 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:35:01.770651 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:35:01.770651 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:34:55.765254 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:34:55.765254 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:34:49.742928 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:34:49.742928 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:34:43.698559 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:34:43.698559 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:34:37.667291 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:34:37.667291 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:34:34.603191 Failed to establish a data proxy connection. Receiver data cannot be sent!
2015-06-10 07:34:34.603191 Failed to connect to all known addresses for host: 'dataupload.planefinder.net'
2015-06-10 07:34:31.643260 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:34:31.643260 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:34:25.615324 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:34:25.615324 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:34:19.565863 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:34:19.565863 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:34:13.538721 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:34:13.538721 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:34:07.498346 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:34:07.498346 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:34:01.469600 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:34:01.469600 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:33:55.451318 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:33:55.451318 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:33:49.435677 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:33:49.435677 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:33:43.411237 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:33:43.411237 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:33:37.389184 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:33:37.389184 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:33:31.321625 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:33:31.321625 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:33:25.299578 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:33:25.299578 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:33:19.282355 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:33:19.282355 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:33:13.252550 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:33:13.252550 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:33:07.232375 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:33:07.232375 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:33:01.225148 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:33:01.225148 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:32:55.197920 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:32:55.197920 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:32:49.167806 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:32:49.167806 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:32:43.146122 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:32:43.146122 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:32:37.111294 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:32:37.111294 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:32:31.95651 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:32:31.95651 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:32:25.65672 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:32:25.65672 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:32:19.47495 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:32:19.47495 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:32:13.23146 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:32:13.23146 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:32:07.22699 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:32:07.22699 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:32:01.7054 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:32:01.7054 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:31:55.2360 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:31:55.2360 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:31:48.982197 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:31:48.982197 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:31:42.973965 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:31:42.973965 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:31:36.943674 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:31:36.943674 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:31:30.896782 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:31:30.896782 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:31:24.865070 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:31:24.865070 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:31:18.832084 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:31:18.832084 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:31:12.793737 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:31:12.793737 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:31:06.764550 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:31:06.764550 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:31:00.723995 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:31:00.723995 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:30:54.712839 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:30:54.712839 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:30:48.693349 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:30:48.693349 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:30:42.662080 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:30:42.662080 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:30:36.640107 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:30:36.640107 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:30:30.614837 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:30:30.614837 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:30:24.603622 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:30:24.603622 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:30:18.602427 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:30:18.602427 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:30:12.586778 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:30:12.586778 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:30:06.570299 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:30:06.570299 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:30:00.542460 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:30:00.542460 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:29:54.495568 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:29:54.495568 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:29:48.462480 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:29:48.462480 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:29:42.415588 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:29:42.415588 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:29:36.414109 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:29:36.414109 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:29:30.381317 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:29:30.381317 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:29:24.350047 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:29:24.350047 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:29:18.339009 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:29:18.339009 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:29:12.152929 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:29:12.152929 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:29:06.47143 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:29:06.47143 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:28:59.950284 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:28:59.950284 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:28:53.747140 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:28:53.747140 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:28:47.638907 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:28:47.638907 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:28:41.576386 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:28:41.576386 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:28:35.553194 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:28:35.553194 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:28:29.353586 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:28:29.353586 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:28:23.285226 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:28:23.285226 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:28:17.253267 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:28:17.253267 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:28:11.221998 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:28:11.221998 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:28:05.183311 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:28:05.183311 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:27:59.158906 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:27:59.158906 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:27:53.124629 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:27:53.124629 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:27:47.104595 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:27:47.104595 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:27:41.74643 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:27:41.74643 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:27:35.43908 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:27:35.43908 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:27:29.24686 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:27:29.24686 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:27:23.14158 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:27:23.14158 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:27:16.915745 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:27:16.915745 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:27:10.884334 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:27:10.884334 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:27:04.879435 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:27:04.879435 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:26:58.853945 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:26:58.853945 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:26:52.840355 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:26:52.840355 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:26:46.812260 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:26:46.812260 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:26:40.773253 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:26:40.773253 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:26:34.741985 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:26:34.741985 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:26:28.694340 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:26:28.694340 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:26:22.687176 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:26:22.687176 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:26:16.663333 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:26:16.663333 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:26:10.637055 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:26:10.637055 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:26:04.638620 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:26:04.638620 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:25:58.606797 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:25:58.606797 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:25:52.565314 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:25:52.565314 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:25:46.535267 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:25:46.535267 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:25:40.523407 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:25:40.523407 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:25:34.492139 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:25:34.492139 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:25:28.469991 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:25:28.469991 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:25:22.438722 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:25:22.438722 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:25:22.134569 Failed to establish a data proxy connection. Receiver data cannot be sent!
2015-06-10 07:25:22.134569 Failed to connect to all known addresses for host: 'dataupload.planefinder.net'
2015-06-10 07:25:16.428016 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:25:16.428016 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:25:10.314145 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:25:10.314145 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:25:04.216457 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:25:04.216457 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:24:58.122687 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:24:58.122687 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:24:51.732041 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:24:51.732041 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:24:45.622786 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:24:45.622786 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:24:39.419640 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:24:39.419640 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:24:33.271606 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:24:33.271606 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:24:27.243039 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:24:27.243039 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:24:21.201226 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:24:21.201226 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:24:15.169473 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:24:15.169473 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:24:09.143605 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:24:09.143605 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:24:03.139789 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:24:03.139789 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:23:57.103967 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:23:57.103967 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:23:51.73892 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:23:51.73892 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:23:45.61639 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:23:45.61639 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:23:39.47314 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:23:39.47314 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:23:33.5673 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:23:33.5673 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:23:26.965496 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:23:26.965496 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:23:20.935569 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:23:20.935569 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:23:14.934499 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:23:14.934499 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:23:08.906586 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:23:08.906586 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:23:02.872824 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:23:02.872824 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:22:56.845536 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:22:56.845536 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:22:50.814269 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:22:50.814269 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:22:44.795109 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:22:44.795109 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:22:38.765120 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:22:38.765120 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:22:32.749476 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:22:32.749476 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:22:26.739582 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:22:26.739582 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:22:20.736006 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:22:20.736006 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:22:14.704612 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:22:14.704612 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:22:08.674445 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:22:08.674445 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:22:02.643284 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:22:02.643284 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:21:56.621844 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:21:56.621844 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:21:50.611235 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:21:50.611235 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:21:44.572434 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:21:44.572434 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:21:38.556790 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:21:38.556790 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:21:32.533111 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:21:32.533111 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:21:26.492760 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:21:26.492760 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:21:20.477115 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:21:20.477115 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:21:14.441713 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:21:14.441713 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:21:08.426877 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:21:08.426877 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:21:02.383718 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:21:02.383718 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:20:56.349425 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:20:56.349425 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:20:50.318157 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:20:50.318157 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:20:44.301275 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:20:44.301275 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:20:38.298733 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:20:38.298733 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:20:32.283089 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:20:32.283089 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:20:26.255212 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:20:26.255212 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:20:20.231012 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:20:20.231012 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:20:14.227722 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:20:14.227722 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:20:08.195228 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:20:08.195228 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:20:02.174770 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:20:02.174770 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:19:56.163513 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:19:56.163513 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:19:50.132240 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:19:50.132240 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:19:44.114605 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:19:44.114605 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:19:38.114012 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:19:38.114012 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:19:32.82075 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:19:32.82075 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:19:26.65572 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:19:26.65572 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:19:20.39086 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:19:20.39086 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:19:14.7517 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:19:14.7517 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:19:08.4949 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:19:08.4949 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:19:02.1853 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:19:02.1853 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:18:55.956526 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:18:55.956526 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:18:49.938910 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:18:49.938910 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:18:43.907909 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:18:43.907909 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:18:37.862935 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:18:37.862935 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:18:31.825605 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:18:31.825605 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:18:25.797034 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:18:25.797034 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:18:19.762715 Failed TCP connection to all provided addresses for: 127.0.0.1:30003
2015-06-10 07:18:19.762715 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:18:18.740278 Client restarted successfully
2015-06-10 07:18:18.189574 Restarting due to configuration change
2015-06-10 07:17:44.838471 Received a restart request, restarting...
2015-06-10 07:17:43.365071 Failed TCP connection to all provided addresses for: 127.0.0.1:10003
2015-06-10 07:17:43.365071 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:17:37.346963 Failed TCP connection to all provided addresses for: 127.0.0.1:10003
2015-06-10 07:17:37.346963 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:17:31.321610 Failed TCP connection to all provided addresses for: 127.0.0.1:10003
2015-06-10 07:17:31.321610 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:17:25.256690 Failed TCP connection to all provided addresses for: 127.0.0.1:10003
2015-06-10 07:17:25.256690 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:17:19.234630 Failed TCP connection to all provided addresses for: 127.0.0.1:10003
2015-06-10 07:17:19.234630 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:17:13.203363 Failed TCP connection to all provided addresses for: 127.0.0.1:10003
2015-06-10 07:17:13.203363 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:17:07.189293 Failed TCP connection to all provided addresses for: 127.0.0.1:10003
2015-06-10 07:17:07.189293 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:17:01.159347 Failed TCP connection to all provided addresses for: 127.0.0.1:10003
2015-06-10 07:17:01.159347 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:16:55.141227 Failed TCP connection to all provided addresses for: 127.0.0.1:10003
2015-06-10 07:16:55.141227 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:16:49.127799 Failed TCP connection to all provided addresses for: 127.0.0.1:10003
2015-06-10 07:16:49.127799 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:16:43.103526 Failed TCP connection to all provided addresses for: 127.0.0.1:10003
2015-06-10 07:16:43.103526 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:16:37.97877 Failed TCP connection to all provided addresses for: 127.0.0.1:10003
2015-06-10 07:16:37.97877 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:16:31.56699 Failed TCP connection to all provided addresses for: 127.0.0.1:10003
2015-06-10 07:16:31.56699 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:16:30.63229 Client restarted successfully
2015-06-10 07:16:25.49370 Failed TCP connection to all provided addresses for: 127.0.0.1:10003
2015-06-10 07:16:25.49370 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:16:24.50924 Client restarted successfully
2015-06-10 07:16:19.46539 Failed TCP connection to all provided addresses for: 127.0.0.1:10003
2015-06-10 07:16:19.46539 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:16:18.43839 Client restarted successfully
2015-06-10 07:16:18.43839 Failed TCP connection to all provided addresses for: 127.0.0.1:10003
2015-06-10 07:16:18.43839 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:16:12.16573 Failed TCP connection to all provided addresses for: 127.0.0.1:10003
2015-06-10 07:16:12.16573 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:16:06.5747 Failed TCP connection to all provided addresses for: 127.0.0.1:10003
2015-06-10 07:16:06.5747 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:16:04.983223 Client restarted successfully
2015-06-10 07:16:04.688258 Restarting due to configuration change
2015-06-10 07:14:36.206449 Received a restart request, restarting...
2015-06-10 07:14:33.875488 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:14:33.875332 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:14:27.856060 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:14:27.856060 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:14:21.832369 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:14:21.832369 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:14:15.806267 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:14:15.806267 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:14:09.749800 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:14:09.749800 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:14:03.703751 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:14:03.703751 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:13:57.678659 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:13:57.678659 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:13:51.648668 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:13:51.648668 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:13:45.619605 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:13:45.619605 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:13:39.611461 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:13:39.611461 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:13:33.597869 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:13:33.597869 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:13:27.547531 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:13:27.547531 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:13:21.513770 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:13:21.513770 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:13:15.486596 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:13:15.486596 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:13:09.468208 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:13:09.468208 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:13:03.458624 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:13:03.458624 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:12:57.446619 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:12:57.446619 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:12:51.425090 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:12:51.425090 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:12:45.413639 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:12:45.413639 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:12:44.409998 Client restarted successfully
2015-06-10 07:12:39.394357 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:12:39.394357 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:12:33.354965 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:12:33.354965 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:12:32.326335 Client restarted successfully
2015-06-10 07:12:27.315650 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:12:27.315650 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:12:21.301548 Failed TCP connection to all provided addresses for: 192.168.1.103:30005
2015-06-10 07:12:21.301548 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 07:12:20.285411 Client restarted successfully
2015-06-10 07:12:20.268572 Restarting due to configuration change
2015-06-10 07:11:24.591028 Client restarted successfully
2015-06-10 07:11:24.591028 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:11:24.591028 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:11:23.997275 Received a restart request, restarting...
2015-06-10 07:11:18.581590 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:11:18.581590 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:11:12.578064 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:11:12.578064 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:11:06.575178 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:11:06.575178 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:11:00.570472 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:11:00.570472 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:10:54.539895 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:10:54.539895 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:10:48.524250 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:10:48.524250 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:10:42.521123 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:10:42.521123 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:10:36.505479 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:10:36.505479 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:10:30.491244 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:10:30.491244 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:10:24.466294 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:10:24.466294 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:10:18.419394 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:10:18.419394 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:10:12.401022 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:10:12.401022 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:10:06.384088 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:10:06.384088 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:10:00.351414 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:10:00.351414 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:09:54.319368 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:09:54.319368 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:09:48.282495 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:09:48.282495 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:09:42.236659 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:09:42.236659 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:09:36.205389 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:09:36.205389 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:09:30.164591 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:09:30.164591 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:09:24.141506 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:09:24.141506 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:09:18.121530 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:09:18.121530 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:09:12.111961 Failed TCP connection to all provided addresses for: 192.168.1.1:30005
2015-06-10 07:09:12.111961 Failed to connect to all known addresses for host: '192.168.1.1'
2015-06-10 07:09:11.80707 Client restarted successfully
2015-06-10 07:09:10.184335 Restarting due to configuration change
2015-06-10 07:07:49.175042 Received a restart request, restarting...
2015-06-10 07:07:48.351985 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:07:48.351985 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:07:42.340987 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:07:42.340987 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:07:36.320993 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:07:36.320993 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:07:30.294516 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:07:30.294516 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:07:24.269582 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:07:24.269582 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:07:18.259183 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:07:18.259183 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:07:12.244634 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:07:12.244634 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:07:06.242911 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:07:06.242911 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:07:00.216593 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:07:00.216593 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:06:54.185640 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:06:54.185640 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:06:48.154619 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:06:48.154619 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:06:42.132730 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:06:42.132730 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:06:36.101461 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:06:36.101461 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:06:30.74477 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:06:30.74477 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:06:24.67115 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:06:24.67115 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:06:18.74406 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:06:18.74406 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:06:12.73280 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:06:12.73280 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:06:06.52403 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:06:06.52403 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:06:00.5507 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:06:00.5507 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:05:53.993286 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:05:53.993286 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:05:47.984504 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:05:47.984504 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:05:41.977249 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:05:41.977249 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:05:35.959114 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:05:35.959114 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:05:29.945294 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:05:29.945294 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:05:23.931830 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:05:23.931830 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:05:17.925859 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:05:17.925859 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:05:11.894054 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:05:11.894054 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:05:05.892568 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:05:05.892568 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:04:59.867655 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:04:59.867655 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:04:53.845423 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:04:53.845423 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:04:47.841072 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:04:47.841072 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:04:41.826684 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:04:41.826497 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:04:35.802590 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:04:35.802590 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:04:29.771321 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:04:29.771321 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:04:23.765745 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:04:23.765745 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:04:17.747281 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:04:17.747281 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:04:11.739451 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:04:11.739451 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:04:05.726832 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:04:05.726832 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:03:59.699677 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:03:59.699677 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:03:53.675466 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:03:53.675466 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:03:47.669621 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:03:47.669621 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:03:41.613560 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:03:41.613560 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:03:35.606639 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:03:35.606639 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:03:34.614579 Client restarted successfully
2015-06-10 07:03:29.614289 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:03:29.614289 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:03:23.607936 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:03:23.607936 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:03:17.613585 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:03:17.613585 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:03:11.607233 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:03:11.607233 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:03:05.609883 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:03:05.609883 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:02:59.607532 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:02:59.607532 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:02:56.764365 Failed to establish a data proxy connection. Receiver data cannot be sent!
2015-06-10 07:02:56.764365 Failed to connect to all known addresses for host: 'dataupload.planefinder.net'
2015-06-10 07:02:53.612181 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:02:53.612181 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:02:47.606185 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:02:47.606185 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:02:41.589610 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:02:41.589610 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:02:35.576600 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:02:35.576600 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:02:29.545461 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:02:29.545461 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:02:23.545031 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:02:23.545031 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:02:17.533018 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:02:17.533018 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:02:11.523668 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:02:11.523668 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:02:05.518316 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:02:05.518316 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:01:59.522965 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:01:59.522965 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:01:53.520614 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:01:53.520614 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:01:47.524264 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:01:47.524264 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:01:41.519912 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:01:41.519912 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:01:35.520561 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:01:35.520561 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:01:29.523210 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:01:29.523210 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:01:23.520859 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:01:23.520859 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:01:17.514940 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:01:17.514940 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:01:11.509168 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:01:11.509168 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:01:05.496068 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:01:05.496068 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:00:59.464800 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:00:59.464800 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:00:53.435854 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:00:53.435854 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:00:47.404584 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:00:47.404584 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:00:41.384557 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:00:41.384557 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:00:35.383929 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:00:35.383929 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:00:29.382966 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:00:29.382966 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:00:23.336070 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:00:23.336070 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:00:17.311862 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:00:17.311862 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:00:11.210961 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:00:11.210961 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 07:00:05.106253 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 07:00:05.106253 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:59:59.12482 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:59:59.12482 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:59:52.809907 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:59:52.809907 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:59:46.698678 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:59:46.698678 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:59:40.612873 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:59:40.612873 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:59:34.509699 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:59:34.509699 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:59:28.309052 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:59:28.309052 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:59:22.199657 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:59:22.199657 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:59:16.103992 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:59:16.103992 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:59:10.66100 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:59:10.66100 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:59:03.990211 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:59:03.990211 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:58:57.983075 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:58:57.983075 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:58:51.951806 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:58:51.951806 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:58:45.914289 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:58:45.914289 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:58:39.905425 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:58:39.905425 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:58:33.875538 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:58:33.875538 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:58:27.870565 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:58:27.870565 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:58:21.831234 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:58:21.831234 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:58:15.808608 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:58:15.808608 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:58:09.775445 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:58:09.775445 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:58:03.734564 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:58:03.734564 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:57:57.705289 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:57:57.705289 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:57:51.640192 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:57:51.640192 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:57:45.600217 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:57:45.600217 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:57:39.566228 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:57:39.566228 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:57:33.543438 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:57:33.543438 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:57:27.523829 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:57:27.523829 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:57:21.502658 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:57:21.502658 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:57:15.491492 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:57:15.491492 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:57:09.474696 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:57:09.474696 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:57:03.462876 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:57:03.462876 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:56:57.431607 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:56:57.431607 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:56:51.402356 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:56:51.402356 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:56:45.374792 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:56:45.374792 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:56:39.341850 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:56:39.341850 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:56:33.333619 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:56:33.333619 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:56:27.317976 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:56:27.317976 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:56:21.285099 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:56:21.285099 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:56:15.253832 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:56:15.253832 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:56:09.226905 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:56:09.226905 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:56:03.216995 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:56:03.216995 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:55:57.209974 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:55:57.209974 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:55:51.186378 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:55:51.186378 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:55:45.165130 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:55:45.165130 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:55:39.139177 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:55:39.139177 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:55:33.131748 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:55:33.131748 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:55:27.116104 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:55:27.116104 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:55:21.91835 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:55:21.91835 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:55:15.44942 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:55:15.44942 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:55:09.37304 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:55:09.37304 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:55:03.15064 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:55:03.15064 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:54:56.983293 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:54:56.983293 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:54:50.969649 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:54:50.969649 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:54:44.954005 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:54:44.954005 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:54:38.926546 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:54:38.926546 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:54:32.916209 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:54:32.916209 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:54:26.895042 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:54:26.895042 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:54:20.878822 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:54:20.878822 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:54:14.863177 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:54:14.863177 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:54:08.822033 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:54:08.822033 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:54:02.785209 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:54:02.785209 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:53:56.783688 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:53:56.783688 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:53:55.283681 Failed to establish a data proxy connection. Receiver data cannot be sent!
2015-06-10 06:53:55.283681 Failed to connect to all known addresses for host: 'dataupload.planefinder.net'
2015-06-10 06:53:50.770042 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:53:50.770042 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:53:44.738773 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:53:44.738773 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:53:38.734158 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:53:38.734158 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:53:32.707314 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:53:32.707314 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:53:26.660417 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:53:26.660417 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:53:20.646577 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:53:20.646577 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:53:14.645343 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:53:14.645343 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:53:08.620090 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:53:08.620090 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:53:02.597286 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:53:02.597286 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:52:56.561324 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:52:56.561324 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:52:50.552529 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:52:50.552529 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:52:44.537754 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:52:44.537754 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:52:38.525109 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:52:38.525109 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:52:32.505345 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:52:32.505345 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:52:26.485362 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:52:26.485362 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:52:20.476816 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:52:20.476816 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:52:14.454708 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:52:14.454708 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:52:08.443822 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:52:08.443822 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:52:02.428178 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:52:02.428178 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:51:56.424532 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:51:56.424532 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:51:50.405065 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:51:50.405065 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:51:44.358171 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:51:44.358171 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:51:38.351206 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:51:38.351206 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:51:32.335321 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:51:32.335321 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:51:26.316010 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:51:26.316010 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:51:20.289820 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:51:20.289820 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:51:14.242925 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:51:14.242925 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:51:08.213689 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:51:08.213689 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:51:02.210598 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:51:02.210598 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:50:56.207470 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:50:56.207470 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:50:50.192260 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:50:50.192260 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:50:44.181393 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:50:44.181393 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:50:38.171778 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:50:38.171778 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:50:32.131924 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:50:32.131924 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:50:26.115010 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:50:26.115010 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:50:20.103415 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:50:20.103415 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:50:14.56521 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:50:14.56521 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:50:08.40878 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:50:08.40878 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:50:02.17708 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:50:02.17708 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:49:55.998636 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:49:55.998636 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:49:49.999284 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:49:49.999284 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:49:43.998934 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:49:43.998934 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:49:37.995622 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:49:37.995622 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:49:31.988666 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:49:31.988666 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:49:25.964480 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:49:25.964480 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:49:19.947566 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:49:19.947566 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:49:13.922461 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:49:13.922461 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:49:07.907624 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:49:07.907624 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:49:01.894427 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:49:01.894427 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:48:55.892003 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:48:55.892003 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:48:49.885104 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:48:49.885104 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:48:43.870369 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:48:43.870369 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:48:37.863176 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:48:37.863176 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:48:31.813734 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:48:31.813734 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:48:25.802684 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:48:25.802684 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:48:19.800626 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:48:19.800626 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:48:13.785407 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:48:13.785407 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:48:07.769763 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:48:07.769763 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:48:01.765091 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:48:01.765091 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:47:55.758040 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:47:55.758040 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:47:49.755944 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:47:49.755944 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:47:43.715276 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:47:43.715276 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:47:42.715273 Client restarted successfully
2015-06-10 06:47:41.829884 Restarting due to configuration change
2015-06-10 06:47:18.435698 Received a restart request, restarting...
2015-06-10 06:47:17.466945 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:47:17.466945 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:47:11.460357 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:47:11.460357 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:47:05.459202 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:47:05.459202 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:46:59.414757 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:46:59.414757 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:46:53.399114 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:46:53.399114 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:46:47.388990 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:46:47.388990 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:46:41.373346 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:46:41.373346 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:46:35.364260 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:46:35.364260 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:46:29.343519 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:46:29.343519 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:46:23.336521 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:46:23.336521 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:46:17.316554 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:46:17.316554 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:46:11.320056 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:46:11.320056 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:46:05.312501 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:46:05.312501 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:45:59.296118 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:45:59.296118 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:45:53.264849 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:45:53.264849 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:45:51.701606 Data proxy is shutting down
2015-06-10 06:45:49.643178 Echo port is shutting down
2015-06-10 06:45:47.195465 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:45:47.195465 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:45:46.179839 Echo port is now listening on: http://192.168.1.103:30054
2015-06-10 06:45:46.179839 Web server is now listening on: http://192.168.1.103:30053
2015-06-10 06:45:46.148587 user_longitude = 102.246000
2015-06-10 06:45:46.148587 user_latitude = 6.159300
2015-06-10 06:45:46.148587 web_server_port = 30053
2015-06-10 06:45:46.148587 select_timeout = 10
2015-06-10 06:45:46.148587 aircraft_timeout = 30
2015-06-10 06:45:46.148587 data_format = 1
2015-06-10 06:45:46.148587 tcp_port = 30005
2015-06-10 06:45:46.148587 tcp_address = 127.0.0.1
2015-06-10 06:45:46.148587 connection_type = 1
2015-06-10 06:45:46.148587 pfclient (3.0.1823 windows) started with the following options:
2015-06-10 06:45:45.351710 Web server is shutting down
2015-06-10 06:45:43.439803 Shutting down workers...
2015-06-10 06:45:40.252293 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:45:40.252293 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:45:34.232987 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:45:34.232987 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:45:31.154852 Failed to establish a data proxy connection. Receiver data cannot be sent!
2015-06-10 06:45:31.154852 Failed to connect to all known addresses for host: 'dataupload.planefinder.net'
2015-06-10 06:45:28.187233 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:45:28.187233 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:45:22.154166 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:45:22.154166 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:45:21.154163 Client restarted successfully
2015-06-10 06:45:16.153542 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:45:16.153542 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:45:10.144498 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:45:10.144498 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:45:09.144494 Client restarted successfully
2015-06-10 06:45:04.133823 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:45:04.133823 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:45:03.133820 Client restarted successfully
2015-06-10 06:45:03.133820 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:45:03.133820 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:44:57.132462 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:44:57.132462 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:44:51.129422 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:44:51.129422 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:44:45.124797 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:44:45.124797 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:44:39.86322 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:44:39.86322 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:44:33.61467 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:44:33.61269 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:44:27.29838 Failed TCP connection to all provided addresses for: 127.0.0.1:30005
2015-06-10 06:44:27.29838 Failed to connect to all known addresses for host: '127.0.0.1'
2015-06-10 06:44:26.29834 Client restarted successfully
2015-06-10 06:44:25.823654 Restarting due to configuration change
2015-06-10 06:42:13.705555 Client restarted successfully
2015-06-10 06:42:13.705555 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:42:13.705555 Zero-byte response received, closing connection
2015-06-10 06:42:08.922924 Received a restart request, restarting...
2015-06-10 06:42:05.736586 TCP connection established: 192.168.1.1:80
2015-06-10 06:42:05.736586 Client restarted successfully
2015-06-10 06:42:05.736586 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:42:05.736586 Zero-byte response received, closing connection
2015-06-10 06:41:57.721448 TCP connection established: 192.168.1.1:80
2015-06-10 06:41:57.721448 Client restarted successfully
2015-06-10 06:41:57.721448 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:41:57.721448 Zero-byte response received, closing connection
2015-06-10 06:41:49.697081 TCP connection established: 192.168.1.1:80
2015-06-10 06:41:49.697081 Client restarted successfully
2015-06-10 06:41:49.697081 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:41:49.697081 Zero-byte response received, closing connection
2015-06-10 06:41:41.751531 TCP connection established: 192.168.1.1:80
2015-06-10 06:41:41.751531 Client restarted successfully
2015-06-10 06:41:41.751531 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:41:41.751531 Zero-byte response received, closing connection
2015-06-10 06:41:33.877893 TCP connection established: 192.168.1.1:80
2015-06-10 06:41:33.876893 Client restarted successfully
2015-06-10 06:41:33.876893 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:41:33.875893 Zero-byte response received, closing connection
2015-06-10 06:41:25.840044 TCP connection established: 192.168.1.1:80
2015-06-10 06:41:25.840044 Client restarted successfully
2015-06-10 06:41:25.840044 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:41:25.840044 Zero-byte response received, closing connection
2015-06-10 06:41:17.854473 TCP connection established: 192.168.1.1:80
2015-06-10 06:41:17.854473 Client restarted successfully
2015-06-10 06:41:17.854473 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:41:17.854473 Zero-byte response received, closing connection
2015-06-10 06:41:09.875119 TCP connection established: 192.168.1.1:80
2015-06-10 06:41:09.875119 Client restarted successfully
2015-06-10 06:41:09.875119 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:41:09.875119 Zero-byte response received, closing connection
2015-06-10 06:41:01.943706 TCP connection established: 192.168.1.1:80
2015-06-10 06:41:01.940704 Client restarted successfully
2015-06-10 06:41:01.940704 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:41:01.940704 Zero-byte response received, closing connection
2015-06-10 06:40:53.915809 TCP connection established: 192.168.1.1:80
2015-06-10 06:40:53.915809 Client restarted successfully
2015-06-10 06:40:53.915809 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:40:53.915809 Zero-byte response received, closing connection
2015-06-10 06:40:45.947406 TCP connection established: 192.168.1.1:80
2015-06-10 06:40:45.945406 Client restarted successfully
2015-06-10 06:40:45.945406 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:40:45.945406 Zero-byte response received, closing connection
2015-06-10 06:40:37.922158 TCP connection established: 192.168.1.1:80
2015-06-10 06:40:37.922158 Client restarted successfully
2015-06-10 06:40:37.922158 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:40:37.922158 Zero-byte response received, closing connection
2015-06-10 06:40:29.945095 TCP connection established: 192.168.1.1:80
2015-06-10 06:40:29.945095 Client restarted successfully
2015-06-10 06:40:29.945095 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:40:29.945095 Zero-byte response received, closing connection
2015-06-10 06:40:21.923974 TCP connection established: 192.168.1.1:80
2015-06-10 06:40:21.923974 Client restarted successfully
2015-06-10 06:40:21.923974 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:40:21.923974 Zero-byte response received, closing connection
2015-06-10 06:40:13.958698 TCP connection established: 192.168.1.1:80
2015-06-10 06:40:13.958698 Client restarted successfully
2015-06-10 06:40:13.958698 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:40:13.958698 Zero-byte response received, closing connection
2015-06-10 06:40:06.41554 TCP connection established: 192.168.1.1:80
2015-06-10 06:40:06.41554 Client restarted successfully
2015-06-10 06:40:06.41554 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:40:06.41554 Zero-byte response received, closing connection
2015-06-10 06:39:58.34478 TCP connection established: 192.168.1.1:80
2015-06-10 06:39:58.33477 Client restarted successfully
2015-06-10 06:39:58.32476 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:39:58.32476 Zero-byte response received, closing connection
2015-06-10 06:39:50.2685 TCP connection established: 192.168.1.1:80
2015-06-10 06:39:50.2685 Client restarted successfully
2015-06-10 06:39:50.2685 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:39:50.2685 Zero-byte response received, closing connection
2015-06-10 06:39:42.109251 TCP connection established: 192.168.1.1:80
2015-06-10 06:39:42.109251 Client restarted successfully
2015-06-10 06:39:42.109251 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:39:42.109251 Zero-byte response received, closing connection
2015-06-10 06:39:34.125590 TCP connection established: 192.168.1.1:80
2015-06-10 06:39:34.125590 Client restarted successfully
2015-06-10 06:39:34.125590 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:39:34.125590 Zero-byte response received, closing connection
2015-06-10 06:39:26.151483 TCP connection established: 192.168.1.1:80
2015-06-10 06:39:26.135859 Client restarted successfully
2015-06-10 06:39:26.135859 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:39:26.135859 Zero-byte response received, closing connection
2015-06-10 06:39:18.167181 TCP connection established: 192.168.1.1:80
2015-06-10 06:39:18.167181 Client restarted successfully
2015-06-10 06:39:18.167181 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:39:18.167181 Zero-byte response received, closing connection
2015-06-10 06:39:10.182440 TCP connection established: 192.168.1.1:80
2015-06-10 06:39:10.182440 Client restarted successfully
2015-06-10 06:39:10.182440 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:39:10.182440 Zero-byte response received, closing connection
2015-06-10 06:39:02.203685 TCP connection established: 192.168.1.1:80
2015-06-10 06:39:02.203685 Client restarted successfully
2015-06-10 06:39:02.203685 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:39:02.203685 Zero-byte response received, closing connection
2015-06-10 06:38:54.173442 TCP connection established: 192.168.1.1:80
2015-06-10 06:38:54.173442 Client restarted successfully
2015-06-10 06:38:54.173442 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:38:54.173442 Zero-byte response received, closing connection
2015-06-10 06:38:46.240576 TCP connection established: 192.168.1.1:80
2015-06-10 06:38:46.240576 Client restarted successfully
2015-06-10 06:38:46.240576 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:38:46.240576 Zero-byte response received, closing connection
2015-06-10 06:38:38.264305 TCP connection established: 192.168.1.1:80
2015-06-10 06:38:38.264305 Client restarted successfully
2015-06-10 06:38:38.264305 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:38:38.264305 Zero-byte response received, closing connection
2015-06-10 06:38:30.252016 TCP connection established: 192.168.1.1:80
2015-06-10 06:38:30.252016 Client restarted successfully
2015-06-10 06:38:30.252016 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:38:30.252016 Zero-byte response received, closing connection
2015-06-10 06:38:22.310942 TCP connection established: 192.168.1.1:80
2015-06-10 06:38:22.310942 Client restarted successfully
2015-06-10 06:38:22.310942 Closed TCP connection: 192.168.1.1:80
2015-06-10 06:38:22.310942 Zero-byte response received, closing connection
2015-06-10 06:38:14.464309 TCP connection established: 192.168.1.1:80
2015-06-10 06:38:14.464309 Client restarted successfully
2015-06-10 06:38:13.776221 Restarting due to configuration change
2015-06-10 06:37:54.357185 Client restarted successfully
2015-06-10 06:37:54.357185 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:37:54.357185 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:37:53.982187 Received a restart request, restarting...
2015-06-10 06:37:48.353344 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:37:48.353344 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:37:42.344045 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:37:42.344045 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:37:36.330418 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:37:36.330418 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:37:30.311578 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:37:30.311578 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:37:24.306268 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:37:24.306268 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:37:18.306700 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:37:18.306700 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:37:12.308349 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:37:12.308349 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:37:06.304998 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:37:06.304998 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:37:01.237596 Data proxy is shutting down
2015-06-10 06:37:00.268845 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:37:00.268845 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:59.909468 Echo port is shutting down
2015-06-10 06:36:59.253218 Echo port is now listening on: http://192.168.1.103:30054
2015-06-10 06:36:59.253218 Web server is now listening on: http://192.168.1.103:30053
2015-06-10 06:36:59.221967 user_longitude = 102.246000
2015-06-10 06:36:59.221967 user_latitude = 6.159300
2015-06-10 06:36:59.221967 web_server_port = 30053
2015-06-10 06:36:59.221967 select_timeout = 10
2015-06-10 06:36:59.221967 aircraft_timeout = 30
2015-06-10 06:36:59.221967 data_format = 3
2015-06-10 06:36:59.221967 tcp_port = 8088
2015-06-10 06:36:59.221967 tcp_address = 192.168.1.103
2015-06-10 06:36:59.221967 connection_type = 1
2015-06-10 06:36:59.221967 pfclient (3.0.1823 windows) started with the following options:
2015-06-10 06:36:59.143841 Web server is shutting down
2015-06-10 06:36:59.143841 Echo port is shutting down
2015-06-10 06:36:57.810504 Data proxy is shutting down
2015-06-10 06:36:55.324400 Web server is shutting down
2015-06-10 06:36:53.932321 Shutting down workers...
2015-06-10 06:36:52.342226 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:52.342226 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:52.24208 Shutting down workers...
2015-06-10 06:36:51.980205 Data proxy is shutting down
2015-06-10 06:36:50.795137 Web server is shutting down
2015-06-10 06:36:50.795137 Echo port is shutting down
2015-06-10 06:36:50.198101 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:50.198101 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:49.969087 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:49.969087 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:49.784079 Shutting down workers...
2015-06-10 06:36:46.337875 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:46.337875 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:44.198750 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:44.198750 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:43.966737 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:43.966737 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:40.341683 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:40.341683 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:38.201950 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:38.201950 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:37.948162 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:37.948162 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:34.323153 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:34.323153 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:32.194812 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:32.194812 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:31.804185 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:31.804185 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:30.788558 Echo port is now listening on: http://192.168.1.103:30054
2015-06-10 06:36:30.788558 Web server is now listening on: http://192.168.1.103:30053
2015-06-10 06:36:30.757307 user_longitude = 102.246000
2015-06-10 06:36:30.757307 user_latitude = 6.159300
2015-06-10 06:36:30.757307 web_server_port = 30053
2015-06-10 06:36:30.757307 select_timeout = 10
2015-06-10 06:36:30.757307 aircraft_timeout = 30
2015-06-10 06:36:30.757307 data_format = 3
2015-06-10 06:36:30.757307 tcp_port = 8088
2015-06-10 06:36:30.757307 tcp_address = 192.168.1.103
2015-06-10 06:36:30.757307 connection_type = 1
2015-06-10 06:36:30.757307 pfclient (3.0.1823 windows) started with the following options:
2015-06-10 06:36:28.257298 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:28.257298 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:26.163541 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:26.163541 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:22.237396 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:22.237396 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:20.143640 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:20.143640 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:19.128014 Web server is now listening on: http://192.168.1.103:30053
2015-06-10 06:36:19.128014 Echo port is now listening on: http://192.168.1.103:30054
2015-06-10 06:36:19.81137 user_longitude = 102.246000
2015-06-10 06:36:19.81137 user_latitude = 6.159300
2015-06-10 06:36:19.81137 web_server_port = 30053
2015-06-10 06:36:19.81137 select_timeout = 10
2015-06-10 06:36:19.81137 aircraft_timeout = 30
2015-06-10 06:36:19.81137 data_format = 3
2015-06-10 06:36:19.81137 tcp_port = 8088
2015-06-10 06:36:19.81137 tcp_address = 192.168.1.103
2015-06-10 06:36:19.81137 connection_type = 1
2015-06-10 06:36:19.18638 pfclient (3.0.1823 windows) started with the following options:
2015-06-10 06:36:16.231327 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:16.231327 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:10.218481 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:10.218481 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:36:04.212799 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:36:04.212799 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:35:58.193061 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:35:58.193061 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:35:52.186386 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:35:52.186386 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:35:46.153185 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:35:46.153185 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:35:40.126623 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:35:40.126623 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:35:34.103042 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:35:34.103042 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:35:28.72050 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:35:28.72050 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:35:22.58795 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:35:22.58795 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:35:16.43153 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:35:16.43153 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:35:10.34474 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:35:10.34474 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:35:04.21223 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:35:04.21223 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:34:58.5578 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:34:58.5578 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:34:51.989035 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:34:51.989035 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:34:45.973390 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:34:45.973390 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:34:39.942366 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:34:39.942366 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:34:33.915366 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:34:33.915366 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:34:27.884372 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:34:27.884372 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:34:21.855959 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:34:21.855959 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:34:15.834780 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:34:15.834780 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:34:09.801912 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:34:09.801912 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:34:03.775125 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:34:03.775125 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:33:57.764267 Failed TCP connection to all provided addresses for: 192.168.1.103:8088
2015-06-10 06:33:57.764267 Failed to connect to all known addresses for host: '192.168.1.103'
2015-06-10 06:33:56.733014 Client restarted successfully
2015-06-10 06:33:56.644354 Restarting due to configuration change
2015-06-10 06:33:26.363120 Received a restart request, restarting...
2015-06-10 06:33:24.409988 Failed TCP connection to all provided addresses for: :
2015-06-10 06:33:24.409988 Failed to connect to all known addresses for host: ''
2015-06-10 06:33:19.396373 Failed TCP connection to all provided addresses for: :
2015-06-10 06:33:19.396373 Failed to connect to all known addresses for host: ''
2015-06-10 06:33:14.383781 Failed TCP connection to all provided addresses for: :
2015-06-10 06:33:14.383781 Failed to connect to all known addresses for host: ''
2015-06-10 06:33:09.375067 Failed TCP connection to all provided addresses for: :
2015-06-10 06:33:09.375067 Failed to connect to all known addresses for host: ''
2015-06-10 06:33:04.367415 Failed TCP connection to all provided addresses for: :
2015-06-10 06:33:04.367415 Failed to connect to all known addresses for host: ''
2015-06-10 06:32:59.351535 Failed TCP connection to all provided addresses for: :
2015-06-10 06:32:59.351535 Failed to connect to all known addresses for host: ''
2015-06-10 06:32:54.349562 Failed TCP connection to all provided addresses for: :
2015-06-10 06:32:54.349562 Failed to connect to all known addresses for host: ''
2015-06-10 06:32:49.348092 Failed TCP connection to all provided addresses for: :
2015-06-10 06:32:49.348092 Failed to connect to all known addresses for host: ''
2015-06-10 06:32:44.333351 Failed TCP connection to all provided addresses for: :
2015-06-10 06:32:44.333351 Failed to connect to all known addresses for host: ''
2015-06-10 06:32:39.328697 Failed TCP connection to all provided addresses for: :
2015-06-10 06:32:39.328697 Failed to connect to all known addresses for host: ''
2015-06-10 06:32:34.320666 Failed TCP connection to all provided addresses for: :
2015-06-10 06:32:34.320666 Failed to connect to all known addresses for host: ''
2015-06-10 06:32:29.313245 Failed TCP connection to all provided addresses for: :
2015-06-10 06:32:29.313245 Failed to connect to all known addresses for host: ''
2015-06-10 06:32:24.310157 Failed TCP connection to all provided addresses for: :
2015-06-10 06:32:24.310157 Failed to connect to all known addresses for host: ''
2015-06-10 06:32:19.306925 Failed TCP connection to all provided addresses for: :
2015-06-10 06:32:19.306925 Failed to connect to all known addresses for host: ''
2015-06-10 06:32:14.292704 Failed TCP connection to all provided addresses for: :
2015-06-10 06:32:14.292704 Failed to connect to all known addresses for host: ''
2015-06-10 06:32:09.291410 Failed TCP connection to all provided addresses for: :
2015-06-10 06:32:09.291410 Failed to connect to all known addresses for host: ''
2015-06-10 06:32:04.290119 Failed TCP connection to all provided addresses for: :
2015-06-10 06:32:04.290119 Failed to connect to all known addresses for host: ''
2015-06-10 06:31:59.238822 Failed TCP connection to all provided addresses for: :
2015-06-10 06:31:59.238822 Failed to connect to all known addresses for host: ''
2015-06-10 06:31:54.237438 Failed TCP connection to all provided addresses for: :
2015-06-10 06:31:54.237438 Failed to connect to all known addresses for host: ''
2015-06-10 06:31:49.236703 Failed TCP connection to all provided addresses for: :
2015-06-10 06:31:49.236703 Failed to connect to all known addresses for host: ''
2015-06-10 06:31:44.235419 Failed TCP connection to all provided addresses for: :
2015-06-10 06:31:44.235419 Failed to connect to all known addresses for host: ''
2015-06-10 06:31:39.225299 Failed TCP connection to all provided addresses for: :
2015-06-10 06:31:39.225299 Failed to connect to all known addresses for host: ''
2015-06-10 06:31:34.214823 Failed TCP connection to all provided addresses for: :
2015-06-10 06:31:34.214823 Failed to connect to all known addresses for host: ''
2015-06-10 06:31:29.201424 Failed TCP connection to all provided addresses for: :
2015-06-10 06:31:29.201424 Failed to connect to all known addresses for host: ''
2015-06-10 06:31:24.188934 Failed TCP connection to all provided addresses for: :
2015-06-10 06:31:24.188934 Failed to connect to all known addresses for host: ''
2015-06-10 06:31:19.94298 Failed TCP connection to all provided addresses for: :
2015-06-10 06:31:19.94298 Failed to connect to all known addresses for host: ''
2015-06-10 06:31:14.93366 Failed TCP connection to all provided addresses for: :
2015-06-10 06:31:14.93366 Failed to connect to all known addresses for host: ''
2015-06-10 06:31:09.80214 Failed TCP connection to all provided addresses for: :
2015-06-10 06:31:09.80214 Failed to connect to all known addresses for host: ''
2015-06-10 06:31:04.79111 Failed TCP connection to all provided addresses for: :
2015-06-10 06:31:04.79111 Failed to connect to all known addresses for host: ''
2015-06-10 06:30:59.75707 Failed TCP connection to all provided addresses for: :
2015-06-10 06:30:59.75707 Failed to connect to all known addresses for host: ''
2015-06-10 06:30:54.66212 Failed TCP connection to all provided addresses for: :
2015-06-10 06:30:54.66212 Failed to connect to all known addresses for host: ''
2015-06-10 06:30:49.61835 Failed TCP connection to all provided addresses for: :
2015-06-10 06:30:49.61835 Failed to connect to all known addresses for host: ''
2015-06-10 06:30:44.46955 Failed TCP connection to all provided addresses for: :
2015-06-10 06:30:44.46955 Failed to connect to all known addresses for host: ''
2015-06-10 06:30:39.43178 Failed TCP connection to all provided addresses for: :
2015-06-10 06:30:39.43178 Failed to connect to all known addresses for host: ''
2015-06-10 06:30:34.39457 Failed TCP connection to all provided addresses for: :
2015-06-10 06:30:34.39457 Failed to connect to all known addresses for host: ''
2015-06-10 06:30:29.29179 Failed TCP connection to all provided addresses for: :
2015-06-10 06:30:29.29179 Failed to connect to all known addresses for host: ''
2015-06-10 06:30:24.27284 Failed TCP connection to all provided addresses for: :
2015-06-10 06:30:24.27284 Failed to connect to all known addresses for host: ''
2015-06-10 06:30:19.25888 Failed TCP connection to all provided addresses for: :
2015-06-10 06:30:19.25888 Failed to connect to all known addresses for host: ''
2015-06-10 06:30:14.10719 Failed TCP connection to all provided addresses for: :
2015-06-10 06:30:14.10719 Failed to connect to all known addresses for host: ''
2015-06-10 06:30:09.7710 Failed TCP connection to all provided addresses for: :
2015-06-10 06:30:09.7710 Failed to connect to all known addresses for host: ''
2015-06-10 06:30:04.4858 Failed TCP connection to all provided addresses for: :
2015-06-10 06:30:04.4858 Failed to connect to all known addresses for host: ''
2015-06-10 06:29:59.4208 Failed TCP connection to all provided addresses for: :
2015-06-10 06:29:59.4208 Failed to connect to all known addresses for host: ''
2015-06-10 06:29:53.998789 Failed TCP connection to all provided addresses for: :
2015-06-10 06:29:53.998789 Failed to connect to all known addresses for host: ''
2015-06-10 06:29:48.985981 Failed TCP connection to all provided addresses for: :
2015-06-10 06:29:48.985981 Failed to connect to all known addresses for host: ''
2015-06-10 06:29:43.984134 Failed TCP connection to all provided addresses for: :
2015-06-10 06:29:43.984134 Failed to connect to all known addresses for host: ''
2015-06-10 06:29:38.976984 Failed TCP connection to all provided addresses for: :
2015-06-10 06:29:38.976984 Failed to connect to all known addresses for host: ''
2015-06-10 06:29:33.969063 Failed TCP connection to all provided addresses for: :
2015-06-10 06:29:33.969063 Failed to connect to all known addresses for host: ''
2015-06-10 06:29:28.963574 Failed TCP connection to all provided addresses for: :
2015-06-10 06:29:28.963574 Failed to connect to all known addresses for host: ''
2015-06-10 06:29:23.954025 Failed TCP connection to all provided addresses for: :
2015-06-10 06:29:23.954025 Failed to connect to all known addresses for host: ''
2015-06-10 06:29:18.945439 Failed TCP connection to all provided addresses for: :
2015-06-10 06:29:18.945439 Failed to connect to all known addresses for host: ''
2015-06-10 06:29:13.937870 Failed TCP connection to all provided addresses for: :
2015-06-10 06:29:13.937870 Failed to connect to all known addresses for host: ''
2015-06-10 06:29:08.933198 Failed TCP connection to all provided addresses for: :
2015-06-10 06:29:08.933198 Failed to connect to all known addresses for host: ''
2015-06-10 06:29:03.931971 Failed TCP connection to all provided addresses for: :
2015-06-10 06:29:03.931971 Failed to connect to all known addresses for host: ''
2015-06-10 06:28:58.922611 Failed TCP connection to all provided addresses for: :
2015-06-10 06:28:58.922611 Failed to connect to all known addresses for host: ''
2015-06-10 06:28:53.919368 Failed TCP connection to all provided addresses for: :
2015-06-10 06:28:53.919368 Failed to connect to all known addresses for host: ''
2015-06-10 06:28:48.912190 Failed TCP connection to all provided addresses for: :
2015-06-10 06:28:48.912190 Failed to connect to all known addresses for host: ''
2015-06-10 06:28:43.904475 Failed TCP connection to all provided addresses for: :
2015-06-10 06:28:43.904475 Failed to connect to all known addresses for host: ''
2015-06-10 06:28:38.901661 Failed TCP connection to all provided addresses for: :
2015-06-10 06:28:38.901661 Failed to connect to all known addresses for host: ''
2015-06-10 06:28:33.887045 Failed TCP connection to all provided addresses for: :
2015-06-10 06:28:33.887045 Failed to connect to all known addresses for host: ''
2015-06-10 06:28:28.884525 Failed TCP connection to all provided addresses for: :
2015-06-10 06:28:28.884525 Failed to connect to all known addresses for host: ''
2015-06-10 06:28:23.883207 Failed TCP connection to all provided addresses for: :
2015-06-10 06:28:23.883207 Failed to connect to all known addresses for host: ''
2015-06-10 06:28:18.874488 Failed TCP connection to all provided addresses for: :
2015-06-10 06:28:18.874488 Failed to connect to all known addresses for host: ''
2015-06-10 06:28:13.859160 Failed TCP connection to all provided addresses for: :
2015-06-10 06:28:13.859160 Failed to connect to all known addresses for host: ''
2015-06-10 06:28:08.857671 Failed TCP connection to all provided addresses for: :
2015-06-10 06:28:08.857671 Failed to connect to all known addresses for host: ''
2015-06-10 06:28:03.856661 Failed TCP connection to all provided addresses for: :
2015-06-10 06:28:03.856661 Failed to connect to all known addresses for host: ''
2015-06-10 06:27:58.855819 Failed TCP connection to all provided addresses for: :
2015-06-10 06:27:58.855819 Failed to connect to all known addresses for host: ''
2015-06-10 06:27:53.735694 Failed TCP connection to all provided addresses for: :
2015-06-10 06:27:53.735694 Failed to connect to all known addresses for host: ''
2015-06-10 06:27:48.724750 Failed TCP connection to all provided addresses for: :
2015-06-10 06:27:48.724750 Failed to connect to all known addresses for host: ''
2015-06-10 06:27:43.717969 Failed TCP connection to all provided addresses for: :
2015-06-10 06:27:43.717969 Failed to connect to all known addresses for host: ''
2015-06-10 06:27:38.716606 Failed TCP connection to all provided addresses for: :
2015-06-10 06:27:38.716606 Failed to connect to all known addresses for host: ''
2015-06-10 06:27:33.701977 Failed TCP connection to all provided addresses for: :
2015-06-10 06:27:33.701977 Failed to connect to all known addresses for host: ''
2015-06-10 06:27:28.700689 Failed TCP connection to all provided addresses for: :
2015-06-10 06:27:28.700689 Failed to connect to all known addresses for host: ''
2015-06-10 06:27:23.699724 Failed TCP connection to all provided addresses for: :
2015-06-10 06:27:23.699724 Failed to connect to all known addresses for host: ''
2015-06-10 06:27:18.697153 Failed TCP connection to all provided addresses for: :
2015-06-10 06:27:18.697153 Failed to connect to all known addresses for host: ''
2015-06-10 06:27:13.691284 Failed TCP connection to all provided addresses for: :
2015-06-10 06:27:13.691284 Failed to connect to all known addresses for host: ''
2015-06-10 06:27:08.689804 Failed TCP connection to all provided addresses for: :
2015-06-10 06:27:08.689804 Failed to connect to all known addresses for host: ''
2015-06-10 06:27:03.688067 Failed TCP connection to all provided addresses for: :
2015-06-10 06:27:03.688067 Failed to connect to all known addresses for host: ''
2015-06-10 06:26:58.678139 Failed TCP connection to all provided addresses for: :
2015-06-10 06:26:58.678139 Failed to connect to all known addresses for host: ''
2015-06-10 06:26:53.675764 Failed TCP connection to all provided addresses for: :
2015-06-10 06:26:53.675764 Failed to connect to all known addresses for host: ''
2015-06-10 06:26:48.674112 Failed TCP connection to all provided addresses for: :
2015-06-10 06:26:48.674112 Failed to connect to all known addresses for host: ''
2015-06-10 06:26:43.655468 Failed TCP connection to all provided addresses for: :
2015-06-10 06:26:43.655468 Failed to connect to all known addresses for host: ''
2015-06-10 06:26:38.654670 Failed TCP connection to all provided addresses for: :
2015-06-10 06:26:38.654670 Failed to connect to all known addresses for host: ''
2015-06-10 06:26:33.640927 Failed TCP connection to all provided addresses for: :
2015-06-10 06:26:33.640927 Failed to connect to all known addresses for host: ''
2015-06-10 06:26:28.640065 Failed TCP connection to all provided addresses for: :
2015-06-10 06:26:28.640065 Failed to connect to all known addresses for host: ''
2015-06-10 06:26:23.619981 Failed TCP connection to all provided addresses for: :
2015-06-10 06:26:23.619981 Failed to connect to all known addresses for host: ''
2015-06-10 06:26:18.618497 Failed TCP connection to all provided addresses for: :
2015-06-10 06:26:18.618497 Failed to connect to all known addresses for host: ''
2015-06-10 06:26:13.607492 Failed TCP connection to all provided addresses for: :
2015-06-10 06:26:13.607492 Failed to connect to all known addresses for host: ''
2015-06-10 06:26:08.592182 Failed TCP connection to all provided addresses for: :
2015-06-10 06:26:08.592182 Failed to connect to all known addresses for host: ''
2015-06-10 06:26:03.581858 Failed TCP connection to all provided addresses for: :
2015-06-10 06:26:03.581858 Failed to connect to all known addresses for host: ''
2015-06-10 06:25:58.580570 Failed TCP connection to all provided addresses for: :
2015-06-10 06:25:58.580570 Failed to connect to all known addresses for host: ''
2015-06-10 06:25:53.579656 Failed TCP connection to all provided addresses for: :
2015-06-10 06:25:53.579656 Failed to connect to all known addresses for host: ''
2015-06-10 06:25:48.572754 Failed TCP connection to all provided addresses for: :
2015-06-10 06:25:48.572754 Failed to connect to all known addresses for host: ''
2015-06-10 06:25:43.567831 Failed TCP connection to all provided addresses for: :
2015-06-10 06:25:43.567831 Failed to connect to all known addresses for host: ''
2015-06-10 06:25:38.557689 Failed TCP connection to all provided addresses for: :
2015-06-10 06:25:38.557689 Failed to connect to all known addresses for host: ''
2015-06-10 06:25:33.554269 Failed TCP connection to all provided addresses for: :
2015-06-10 06:25:33.554269 Failed to connect to all known addresses for host: ''
2015-06-10 06:25:28.552519 Failed TCP connection to all provided addresses for: :
2015-06-10 06:25:28.552519 Failed to connect to all known addresses for host: ''
2015-06-10 06:25:23.551077 Failed TCP connection to all provided addresses for: :
2015-06-10 06:25:23.551077 Failed to connect to all known addresses for host: ''
2015-06-10 06:25:18.549667 Failed TCP connection to all provided addresses for: :
2015-06-10 06:25:18.549667 Failed to connect to all known addresses for host: ''
2015-06-10 06:25:13.548200 Failed TCP connection to all provided addresses for: :
2015-06-10 06:25:13.548200 Failed to connect to all known addresses for host: ''
2015-06-10 06:25:08.546983 Failed TCP connection to all provided addresses for: :
2015-06-10 06:25:08.546983 Failed to connect to all known addresses for host: ''
2015-06-10 06:25:03.546311 Failed TCP connection to all provided addresses for: :
2015-06-10 06:25:03.546311 Failed to connect to all known addresses for host: ''
2015-06-10 06:24:58.535786 Failed TCP connection to all provided addresses for: :
2015-06-10 06:24:58.535786 Failed to connect to all known addresses for host: ''
2015-06-10 06:24:53.534103 Failed TCP connection to all provided addresses for: :
2015-06-10 06:24:53.534103 Failed to connect to all known addresses for host: ''
2015-06-10 06:24:48.532484 Failed TCP connection to all provided addresses for: :
2015-06-10 06:24:48.532484 Failed to connect to all known addresses for host: ''
2015-06-10 06:24:43.523837 Failed TCP connection to all provided addresses for: :
2015-06-10 06:24:43.523837 Failed to connect to all known addresses for host: ''
2015-06-10 06:24:38.511008 Failed TCP connection to all provided addresses for: :
2015-06-10 06:24:38.511008 Failed to connect to all known addresses for host: ''
2015-06-10 06:24:33.508286 Failed TCP connection to all provided addresses for: :
2015-06-10 06:24:33.508286 Failed to connect to all known addresses for host: ''
2015-06-10 06:24:28.492804 Failed TCP connection to all provided addresses for: :
2015-06-10 06:24:28.492804 Failed to connect to all known addresses for host: ''
2015-06-10 06:24:23.486753 Failed TCP connection to all provided addresses for: :
2015-06-10 06:24:23.486753 Failed to connect to all known addresses for host: ''
2015-06-10 06:24:18.485984 Failed TCP connection to all provided addresses for: :
2015-06-10 06:24:18.485984 Failed to connect to all known addresses for host: ''
2015-06-10 06:24:13.480493 Failed TCP connection to all provided addresses for: :
2015-06-10 06:24:13.480493 Failed to connect to all known addresses for host: ''
2015-06-10 06:24:08.464465 Failed TCP connection to all provided addresses for: :
2015-06-10 06:24:08.464465 Failed to connect to all known addresses for host: ''
2015-06-10 06:24:03.453558 Failed TCP connection to all provided addresses for: :
2015-06-10 06:24:03.453558 Failed to connect to all known addresses for host: ''
2015-06-10 06:23:58.452140 Failed TCP connection to all provided addresses for: :
2015-06-10 06:23:58.452140 Failed to connect to all known addresses for host: ''
2015-06-10 06:23:53.451184 Failed TCP connection to all provided addresses for: :
2015-06-10 06:23:53.451184 Failed to connect to all known addresses for host: ''
2015-06-10 06:23:48.447887 Failed TCP connection to all provided addresses for: :
2015-06-10 06:23:48.447887 Failed to connect to all known addresses for host: ''
2015-06-10 06:23:43.446696 Failed TCP connection to all provided addresses for: :
2015-06-10 06:23:43.446696 Failed to connect to all known addresses for host: ''
2015-06-10 06:23:38.431821 Failed TCP connection to all provided addresses for: :
2015-06-10 06:23:38.431821 Failed to connect to all known addresses for host: ''
2015-06-10 06:23:33.418841 Failed TCP connection to all provided addresses for: :
2015-06-10 06:23:33.418841 Failed to connect to all known addresses for host: ''
2015-06-10 06:23:28.416105 Failed TCP connection to all provided addresses for: :
2015-06-10 06:23:28.416105 Failed to connect to all known addresses for host: ''
2015-06-10 06:23:23.403041 Failed TCP connection to all provided addresses for: :
2015-06-10 06:23:23.403041 Failed to connect to all known addresses for host: ''
2015-06-10 06:23:18.401993 Failed TCP connection to all provided addresses for: :
2015-06-10 06:23:18.401993 Failed to connect to all known addresses for host: ''
2015-06-10 06:23:13.394207 Failed TCP connection to all provided addresses for: :
2015-06-10 06:23:13.394207 Failed to connect to all known addresses for host: ''
2015-06-10 06:23:08.389428 Failed TCP connection to all provided addresses for: :
2015-06-10 06:23:08.389428 Failed to connect to all known addresses for host: ''
2015-06-10 06:23:03.380219 Failed TCP connection to all provided addresses for: :
2015-06-10 06:23:03.380219 Failed to connect to all known addresses for host: ''
2015-06-10 06:22:58.374183 Failed TCP connection to all provided addresses for: :
2015-06-10 06:22:58.374183 Failed to connect to all known addresses for host: ''
2015-06-10 06:22:53.371430 Failed TCP connection to all provided addresses for: :
2015-06-10 06:22:53.371430 Failed to connect to all known addresses for host: ''
2015-06-10 06:22:48.365906 Failed TCP connection to all provided addresses for: :
2015-06-10 06:22:48.365906 Failed to connect to all known addresses for host: ''
2015-06-10 06:22:43.363486 Failed TCP connection to all provided addresses for: :
2015-06-10 06:22:43.363486 Failed to connect to all known addresses for host: ''
2015-06-10 06:22:38.351339 Failed TCP connection to all provided addresses for: :
2015-06-10 06:22:38.351339 Failed to connect to all known addresses for host: ''
2015-06-10 06:22:33.341277 Failed TCP connection to all provided addresses for: :
2015-06-10 06:22:33.341277 Failed to connect to all known addresses for host: ''
2015-06-10 06:22:28.327526 Failed TCP connection to all provided addresses for: :
2015-06-10 06:22:28.327526 Failed to connect to all known addresses for host: ''
2015-06-10 06:22:23.316701 Failed TCP connection to all provided addresses for: :
2015-06-10 06:22:23.316701 Failed to connect to all known addresses for host: ''
2015-06-10 06:22:18.315552 Failed TCP connection to all provided addresses for: :
2015-06-10 06:22:18.315552 Failed to connect to all known addresses for host: ''
2015-06-10 06:22:13.302756 Failed TCP connection to all provided addresses for: :
2015-06-10 06:22:13.302756 Failed to connect to all known addresses for host: ''
2015-06-10 06:22:08.301315 Failed TCP connection to all provided addresses for: :
2015-06-10 06:22:08.301315 Failed to connect to all known addresses for host: ''
2015-06-10 06:22:03.290943 Failed TCP connection to all provided addresses for: :
2015-06-10 06:22:03.290943 Failed to connect to all known addresses for host: ''
2015-06-10 06:21:58.289761 Failed TCP connection to all provided addresses for: :
2015-06-10 06:21:58.289761 Failed to connect to all known addresses for host: ''
2015-06-10 06:21:53.288320 Failed TCP connection to all provided addresses for: :
2015-06-10 06:21:53.288320 Failed to connect to all known addresses for host: ''
2015-06-10 06:21:48.272244 Failed TCP connection to all provided addresses for: :
2015-06-10 06:21:48.272244 Failed to connect to all known addresses for host: ''
2015-06-10 06:21:43.270482 Failed TCP connection to all provided addresses for: :
2015-06-10 06:21:43.270482 Failed to connect to all known addresses for host: ''
2015-06-10 06:21:38.268930 Failed TCP connection to all provided addresses for: :
2015-06-10 06:21:38.268930 Failed to connect to all known addresses for host: ''
2015-06-10 06:21:33.267554 Failed TCP connection to all provided addresses for: :
2015-06-10 06:21:33.267554 Failed to connect to all known addresses for host: ''
2015-06-10 06:21:28.251187 Failed TCP connection to all provided addresses for: :
2015-06-10 06:21:28.251187 Failed to connect to all known addresses for host: ''
2015-06-10 06:21:23.246371 Failed TCP connection to all provided addresses for: :
2015-06-10 06:21:23.246371 Failed to connect to all known addresses for host: ''
2015-06-10 06:21:18.241815 Failed TCP connection to all provided addresses for: :
2015-06-10 06:21:18.241815 Failed to connect to all known addresses for host: ''
2015-06-10 06:21:13.240523 Failed TCP connection to all provided addresses for: :
2015-06-10 06:21:13.240523 Failed to connect to all known addresses for host: ''
2015-06-10 06:21:08.186051 Failed TCP connection to all provided addresses for: :
2015-06-10 06:21:08.186051 Failed to connect to all known addresses for host: ''
2015-06-10 06:21:03.184605 Failed TCP connection to all provided addresses for: :
2015-06-10 06:21:03.184605 Failed to connect to all known addresses for host: ''
2015-06-10 06:20:58.178466 Failed TCP connection to all provided addresses for: :
2015-06-10 06:20:58.178466 Failed to connect to all known addresses for host: ''
2015-06-10 06:20:53.171142 Failed TCP connection to all provided addresses for: :
2015-06-10 06:20:53.171142 Failed to connect to all known addresses for host: ''
2015-06-10 06:20:48.157303 Failed TCP connection to all provided addresses for: :
2015-06-10 06:20:48.156301 Failed to connect to all known addresses for host: ''
2015-06-10 06:20:43.107007 Failed TCP connection to all provided addresses for: :
2015-06-10 06:20:43.107007 Failed to connect to all known addresses for host: ''
2015-06-10 06:20:38.20708 Failed TCP connection to all provided addresses for: :
2015-06-10 06:20:38.20708 Failed to connect to all known addresses for host: ''
2015-06-10 06:20:33.19414 Failed TCP connection to all provided addresses for: :
2015-06-10 06:20:33.19414 Failed to connect to all known addresses for host: ''
2015-06-10 06:20:28.120 Failed TCP connection to all provided addresses for: :
2015-06-10 06:20:28.120 Failed to connect to all known addresses for host: ''
2015-06-10 06:20:22.998980 Failed TCP connection to all provided addresses for: :
2015-06-10 06:20:22.998980 Failed to connect to all known addresses for host: ''
2015-06-10 06:20:17.988938 Failed TCP connection to all provided addresses for: :
2015-06-10 06:20:17.988938 Failed to connect to all known addresses for host: ''
2015-06-10 06:20:12.983369 Failed TCP connection to all provided addresses for: :
2015-06-10 06:20:12.983369 Failed to connect to all known addresses for host: ''
2015-06-10 06:20:07.973654 Failed TCP connection to all provided addresses for: :
2015-06-10 06:20:07.973654 Failed to connect to all known addresses for host: ''
2015-06-10 06:20:05.254390 Failed to establish a data proxy connection. Receiver data cannot be sent!
2015-06-10 06:20:05.254390 Failed to connect to all known addresses for host: 'dataupload.planefinder.net'
2015-06-10 06:20:02.957508 Failed TCP connection to all provided addresses for: :
2015-06-10 06:20:02.957508 Failed to connect to all known addresses for host: ''
2015-06-10 06:19:57.941868 Failed TCP connection to all provided addresses for: :
2015-06-10 06:19:57.941868 Failed to connect to all known addresses for host: ''
2015-06-10 06:19:52.926225 Failed TCP connection to all provided addresses for: :
2015-06-10 06:19:52.926225 Failed to connect to all known addresses for host: ''
2015-06-10 06:19:47.910585 Failed TCP connection to all provided addresses for: :
2015-06-10 06:19:47.910585 Failed to connect to all known addresses for host: ''
2015-06-10 06:19:42.894943 Failed TCP connection to all provided addresses for: :
2015-06-10 06:19:42.894943 Failed to connect to all known addresses for host: ''
2015-06-10 06:19:37.891723 Failed TCP connection to all provided addresses for: :
2015-06-10 06:19:37.891723 Failed to connect to all known addresses for host: ''
2015-06-10 06:19:32.875614 Failed TCP connection to all provided addresses for: :
2015-06-10 06:19:32.875614 Failed to connect to all known addresses for host: ''
2015-06-10 06:19:27.859974 Failed TCP connection to all provided addresses for: :
2015-06-10 06:19:27.859974 Failed to connect to all known addresses for host: ''
2015-06-10 06:19:22.844332 Failed TCP connection to all provided addresses for: :
2015-06-10 06:19:22.844332 Failed to connect to all known addresses for host: ''
2015-06-10 06:19:17.828691 Failed TCP connection to all provided addresses for: :
2015-06-10 06:19:17.828691 Failed to connect to all known addresses for host: ''
2015-06-10 06:19:12.813050 Failed TCP connection to all provided addresses for: :
2015-06-10 06:19:12.813050 Failed to connect to all known addresses for host: ''
2015-06-10 06:19:07.802558 Failed TCP connection to all provided addresses for: :
2015-06-10 06:19:07.802558 Failed to connect to all known addresses for host: ''
2015-06-10 06:19:02.798895 Failed TCP connection to all provided addresses for: :
2015-06-10 06:19:02.798895 Failed to connect to all known addresses for host: ''
2015-06-10 06:18:57.783253 Failed TCP connection to all provided addresses for: :
2015-06-10 06:18:57.783253 Failed to connect to all known addresses for host: ''
2015-06-10 06:18:52.767611 Failed TCP connection to all provided addresses for: :
2015-06-10 06:18:52.767611 Failed to connect to all known addresses for host: ''
2015-06-10 06:18:47.751971 Failed TCP connection to all provided addresses for: :
2015-06-10 06:18:47.751971 Failed to connect to all known addresses for host: ''
2015-06-10 06:18:42.736331 Failed TCP connection to all provided addresses for: :
2015-06-10 06:18:42.736331 Failed to connect to all known addresses for host: ''
2015-06-10 06:18:37.721669 Failed TCP connection to all provided addresses for: :
2015-06-10 06:18:37.721669 Failed to connect to all known addresses for host: ''
2015-06-10 06:18:32.717061 Failed TCP connection to all provided addresses for: :
2015-06-10 06:18:32.717061 Failed to connect to all known addresses for host: ''
2015-06-10 06:18:27.701420 Failed TCP connection to all provided addresses for: :
2015-06-10 06:18:27.701420 Failed to connect to all known addresses for host: ''
2015-06-10 06:18:22.690456 Failed TCP connection to all provided addresses for: :
2015-06-10 06:18:22.690456 Failed to connect to all known addresses for host: ''
2015-06-10 06:18:17.674815 Failed TCP connection to all provided addresses for: :
2015-06-10 06:18:17.674815 Failed to connect to all known addresses for host: ''
2015-06-10 06:18:12.659177 Failed TCP connection to all provided addresses for: :
2015-06-10 06:18:12.659177 Failed to connect to all known addresses for host: ''
2015-06-10 06:18:07.644699 Failed TCP connection to all provided addresses for: :
2015-06-10 06:18:07.644699 Failed to connect to all known addresses for host: ''
2015-06-10 06:18:02.643240 Failed TCP connection to all provided addresses for: :
2015-06-10 06:18:02.643240 Failed to connect to all known addresses for host: ''
2015-06-10 06:17:57.627599 Failed TCP connection to all provided addresses for: :
2015-06-10 06:17:57.627599 Failed to connect to all known addresses for host: ''
2015-06-10 06:17:52.611957 Failed TCP connection to all provided addresses for: :
2015-06-10 06:17:52.611957 Failed to connect to all known addresses for host: ''
2015-06-10 06:17:47.596316 Failed TCP connection to all provided addresses for: :
2015-06-10 06:17:47.596316 Failed to connect to all known addresses for host: ''
2015-06-10 06:17:42.580675 Failed TCP connection to all provided addresses for: :
2015-06-10 06:17:42.580675 Failed to connect to all known addresses for host: ''
2015-06-10 06:17:37.565036 Failed TCP connection to all provided addresses for: :
2015-06-10 06:17:37.565036 Failed to connect to all known addresses for host: ''
2015-06-10 06:17:32.557480 Failed TCP connection to all provided addresses for: :
2015-06-10 06:17:32.557480 Failed to connect to all known addresses for host: ''
2015-06-10 06:17:27.543370 Failed TCP connection to all provided addresses for: :
2015-06-10 06:17:27.543370 Failed to connect to all known addresses for host: ''
2015-06-10 06:17:22.527727 Failed TCP connection to all provided addresses for: :
2015-06-10 06:17:22.527727 Failed to connect to all known addresses for host: ''
2015-06-10 06:17:17.512086 Failed TCP connection to all provided addresses for: :
2015-06-10 06:17:17.512086 Failed to connect to all known addresses for host: ''
2015-06-10 06:17:12.496447 Failed TCP connection to all provided addresses for: :
2015-06-10 06:17:12.496447 Failed to connect to all known addresses for host: ''
2015-06-10 06:17:07.485935 Failed TCP connection to all provided addresses for: :
2015-06-10 06:17:07.485935 Failed to connect to all known addresses for host: ''
2015-06-10 06:17:02.483587 Failed TCP connection to all provided addresses for: :
2015-06-10 06:17:02.483587 Failed to connect to all known addresses for host: ''
2015-06-10 06:16:57.450408 Failed TCP connection to all provided addresses for: :
2015-06-10 06:16:57.450408 Failed to connect to all known addresses for host: ''
2015-06-10 06:16:52.449268 Failed TCP connection to all provided addresses for: :
2015-06-10 06:16:52.449268 Failed to connect to all known addresses for host: ''
2015-06-10 06:16:47.440122 Failed TCP connection to all provided addresses for: :
2015-06-10 06:16:47.440122 Failed to connect to all known addresses for host: ''
2015-06-10 06:16:42.438388 Failed TCP connection to all provided addresses for: :
2015-06-10 06:16:42.438388 Failed to connect to all known addresses for host: ''
2015-06-10 06:16:37.422380 Failed TCP connection to all provided addresses for: :
2015-06-10 06:16:37.422380 Failed to connect to all known addresses for host: ''
2015-06-10 06:16:32.416560 Failed TCP connection to all provided addresses for: :
2015-06-10 06:16:32.416560 Failed to connect to all known addresses for host: ''
2015-06-10 06:16:27.404913 Failed TCP connection to all provided addresses for: :
2015-06-10 06:16:27.404913 Failed to connect to all known addresses for host: ''
2015-06-10 06:16:22.388918 Failed TCP connection to all provided addresses for: :
2015-06-10 06:16:22.388918 Failed to connect to all known addresses for host: ''
2015-06-10 06:16:17.373278 Failed TCP connection to all provided addresses for: :
2015-06-10 06:16:17.373278 Failed to connect to all known addresses for host: ''
2015-06-10 06:16:12.372138 Failed TCP connection to all provided addresses for: :
2015-06-10 06:16:12.372138 Failed to connect to all known addresses for host: ''
2015-06-10 06:16:07.366435 Failed TCP connection to all provided addresses for: :
2015-06-10 06:16:07.366435 Failed to connect to all known addresses for host: ''
2015-06-10 06:16:02.359699 Failed TCP connection to all provided addresses for: :
2015-06-10 06:16:02.359699 Failed to connect to all known addresses for host: ''
2015-06-10 06:15:57.346146 Failed TCP connection to all provided addresses for: :
2015-06-10 06:15:57.346146 Failed to connect to all known addresses for host: ''
2015-06-10 06:15:52.335525 Failed TCP connection to all provided addresses for: :
2015-06-10 06:15:52.335525 Failed to connect to all known addresses for host: ''
2015-06-10 06:15:47.332929 Failed TCP connection to all provided addresses for: :
2015-06-10 06:15:47.332929 Failed to connect to all known addresses for host: ''
2015-06-10 06:15:42.331525 Failed TCP connection to all provided addresses for: :
2015-06-10 06:15:42.331525 Failed to connect to all known addresses for host: ''
2015-06-10 06:15:37.315007 Failed TCP connection to all provided addresses for: :
2015-06-10 06:15:37.315007 Failed to connect to all known addresses for host: ''
2015-06-10 06:15:32.299366 Failed TCP connection to all provided addresses for: :
2015-06-10 06:15:32.299366 Failed to connect to all known addresses for host: ''
2015-06-10 06:15:27.288423 Failed TCP connection to all provided addresses for: :
2015-06-10 06:15:27.288423 Failed to connect to all known addresses for host: ''
2015-06-10 06:15:22.265872 Failed TCP connection to all provided addresses for: :
2015-06-10 06:15:22.265872 Failed to connect to all known addresses for host: ''
2015-06-10 06:15:17.252081 Failed TCP connection to all provided addresses for: :
2015-06-10 06:15:17.252081 Failed to connect to all known addresses for host: ''
2015-06-10 06:15:12.239526 Failed TCP connection to all provided addresses for: :
2015-06-10 06:15:12.239526 Failed to connect to all known addresses for host: ''
2015-06-10 06:15:07.237174 Failed TCP connection to all provided addresses for: :
2015-06-10 06:15:07.237174 Failed to connect to all known addresses for host: ''
2015-06-10 06:15:02.236161 Failed TCP connection to all provided addresses for: :
2015-06-10 06:15:02.236161 Failed to connect to all known addresses for host: ''
2015-06-10 06:14:57.235125 Failed TCP connection to all provided addresses for: :
2015-06-10 06:14:57.235125 Failed to connect to all known addresses for host: ''
2015-06-10 06:14:52.219241 Failed TCP connection to all provided addresses for: :
2015-06-10 06:14:52.219241 Failed to connect to all known addresses for host: ''
2015-06-10 06:14:47.210490 Failed TCP connection to all provided addresses for: :
2015-06-10 06:14:47.210490 Failed to connect to all known addresses for host: ''
2015-06-10 06:14:42.192634 Failed TCP connection to all provided addresses for: :
2015-06-10 06:14:42.192634 Failed to connect to all known addresses for host: ''
2015-06-10 06:14:37.190380 Failed TCP connection to all provided addresses for: :
2015-06-10 06:14:37.190380 Failed to connect to all known addresses for host: ''
2015-06-10 06:14:32.182449 Failed TCP connection to all provided addresses for: :
2015-06-10 06:14:32.182449 Failed to connect to all known addresses for host: ''
2015-06-10 06:14:27.167594 Failed TCP connection to all provided addresses for: :
2015-06-10 06:14:27.167594 Failed to connect to all known addresses for host: ''
2015-06-10 06:14:22.157895 Failed TCP connection to all provided addresses for: :
2015-06-10 06:14:22.157895 Failed to connect to all known addresses for host: ''
2015-06-10 06:14:17.147327 Failed TCP connection to all provided addresses for: :
2015-06-10 06:14:17.147327 Failed to connect to all known addresses for host: ''
2015-06-10 06:14:12.146094 Failed TCP connection to all provided addresses for: :
2015-06-10 06:14:12.146094 Failed to connect to all known addresses for host: ''
2015-06-10 06:14:07.130453 Failed TCP connection to all provided addresses for: :
2015-06-10 06:14:07.130453 Failed to connect to all known addresses for host: ''
2015-06-10 06:14:02.128567 Failed TCP connection to all provided addresses for: :
2015-06-10 06:14:02.128567 Failed to connect to all known addresses for host: ''
2015-06-10 06:13:57.112344 Failed TCP connection to all provided addresses for: :
2015-06-10 06:13:57.112344 Failed to connect to all known addresses for host: ''
2015-06-10 06:13:52.109428 Failed TCP connection to all provided addresses for: :
2015-06-10 06:13:52.109428 Failed to connect to all known addresses for host: ''
2015-06-10 06:13:47.99599 Failed TCP connection to all provided addresses for: :
2015-06-10 06:13:47.99599 Failed to connect to all known addresses for host: ''
2015-06-10 06:13:42.98340 Failed TCP connection to all provided addresses for: :
2015-06-10 06:13:42.98340 Failed to connect to all known addresses for host: ''
2015-06-10 06:13:37.97125 Failed TCP connection to all provided addresses for: :
2015-06-10 06:13:37.97125 Failed to connect to all known addresses for host: ''
2015-06-10 06:13:32.80950 Failed TCP connection to all provided addresses for: :
2015-06-10 06:13:32.80950 Failed to connect to all known addresses for host: ''
2015-06-10 06:13:27.75065 Failed TCP connection to all provided addresses for: :
2015-06-10 06:13:27.75065 Failed to connect to all known addresses for host: ''
2015-06-10 06:13:22.63069 Failed TCP connection to all provided addresses for: :
2015-06-10 06:13:22.63069 Failed to connect to all known addresses for host: ''
2015-06-10 06:13:17.47428 Failed TCP connection to all provided addresses for: :
2015-06-10 06:13:17.47428 Failed to connect to all known addresses for host: ''
2015-06-10 06:13:12.32008 Failed TCP connection to all provided addresses for: :
2015-06-10 06:13:12.32008 Failed to connect to all known addresses for host: ''
2015-06-10 06:13:07.16367 Failed TCP connection to all provided addresses for: :
2015-06-10 06:13:07.16367 Failed to connect to all known addresses for host: ''
2015-06-10 06:13:02.4604 Failed TCP connection to all provided addresses for: :
2015-06-10 06:13:02.4604 Failed to connect to all known addresses for host: ''
2015-06-10 06:12:57.3425 Failed TCP connection to all provided addresses for: :
2015-06-10 06:12:57.3425 Failed to connect to all known addresses for host: ''
2015-06-10 06:12:51.995777 Failed TCP connection to all provided addresses for: :
2015-06-10 06:12:51.995777 Failed to connect to all known addresses for host: ''
2015-06-10 06:12:46.994606 Failed TCP connection to all provided addresses for: :
2015-06-10 06:12:46.994606 Failed to connect to all known addresses for host: ''
2015-06-10 06:12:41.978310 Failed TCP connection to all provided addresses for: :
2015-06-10 06:12:41.978310 Failed to connect to all known addresses for host: ''
2015-06-10 06:12:36.977032 Failed TCP connection to all provided addresses for: :
2015-06-10 06:12:36.977032 Failed to connect to all known addresses for host: ''
2015-06-10 06:12:31.973396 Failed TCP connection to all provided addresses for: :
2015-06-10 06:12:31.973396 Failed to connect to all known addresses for host: ''
2015-06-10 06:12:26.972196 Failed TCP connection to all provided addresses for: :
2015-06-10 06:12:26.972196 Failed to connect to all known addresses for host: ''
2015-06-10 06:12:21.970314 Failed TCP connection to all provided addresses for: :
2015-06-10 06:12:21.970314 Failed to connect to all known addresses for host: ''
2015-06-10 06:12:17.752416 Failed to establish a data proxy connection. Receiver data cannot be sent!
2015-06-10 06:12:17.752416 Failed to connect to all known addresses for host: 'dataupload.planefinder.net'
2015-06-10 06:12:16.955539 Failed TCP connection to all provided addresses for: :
2015-06-10 06:12:16.955539 Failed to connect to all known addresses for host: ''
2015-06-10 06:12:11.939473 Failed TCP connection to all provided addresses for: :
2015-06-10 06:12:11.939473 Failed to connect to all known addresses for host: ''
2015-06-10 06:12:06.923671 Failed TCP connection to all provided addresses for: :
2015-06-10 06:12:06.923671 Failed to connect to all known addresses for host: ''
2015-06-10 06:12:01.921469 Failed TCP connection to all provided addresses for: :
2015-06-10 06:12:01.921469 Failed to connect to all known addresses for host: ''
2015-06-10 06:11:56.907708 Failed TCP connection to all provided addresses for: :
2015-06-10 06:11:56.907708 Failed to connect to all known addresses for host: ''
2015-06-10 06:11:51.899289 Failed TCP connection to all provided addresses for: :
2015-06-10 06:11:51.899289 Failed to connect to all known addresses for host: ''
2015-06-10 06:11:46.883347 Failed TCP connection to all provided addresses for: :
2015-06-10 06:11:46.883347 Failed to connect to all known addresses for host: ''
2015-06-10 06:11:41.878551 Failed TCP connection to all provided addresses for: :
2015-06-10 06:11:41.878551 Failed to connect to all known addresses for host: ''
2015-06-10 06:11:36.864048 Failed TCP connection to all provided addresses for: :
2015-06-10 06:11:36.864048 Failed to connect to all known addresses for host: ''
2015-06-10 06:11:31.848408 Failed TCP connection to all provided addresses for: :
2015-06-10 06:11:31.848408 Failed to connect to all known addresses for host: ''
2015-06-10 06:11:26.832972 Failed TCP connection to all provided addresses for: :
2015-06-10 06:11:26.832972 Failed to connect to all known addresses for host: ''
2015-06-10 06:11:21.820708 Failed TCP connection to all provided addresses for: :
2015-06-10 06:11:21.820708 Failed to connect to all known addresses for host: ''
2015-06-10 06:11:16.811111 Failed TCP connection to all provided addresses for: :
2015-06-10 06:11:16.811111 Failed to connect to all known addresses for host: ''
2015-06-10 06:11:11.795470 Failed TCP connection to all provided addresses for: :
2015-06-10 06:11:11.795470 Failed to connect to all known addresses for host: ''
2015-06-10 06:11:06.790376 Failed TCP connection to all provided addresses for: :
2015-06-10 06:11:06.790376 Failed to connect to all known addresses for host: ''
2015-06-10 06:11:01.774735 Failed TCP connection to all provided addresses for: :
2015-06-10 06:11:01.774735 Failed to connect to all known addresses for host: ''
2015-06-10 06:10:56.773038 Failed TCP connection to all provided addresses for: :
2015-06-10 06:10:56.773038 Failed to connect to all known addresses for host: ''
2015-06-10 06:10:51.757751 Failed TCP connection to all provided addresses for: :
2015-06-10 06:10:51.757751 Failed to connect to all known addresses for host: ''
2015-06-10 06:10:46.749059 Failed TCP connection to all provided addresses for: :
2015-06-10 06:10:46.749059 Failed to connect to all known addresses for host: ''
2015-06-10 06:10:41.733418 Failed TCP connection to all provided addresses for: :
2015-06-10 06:10:41.733418 Failed to connect to all known addresses for host: ''
2015-06-10 06:10:36.722776 Failed TCP connection to all provided addresses for: :
2015-06-10 06:10:36.722776 Failed to connect to all known addresses for host: ''
2015-06-10 06:10:31.708612 Failed TCP connection to all provided addresses for: :
2015-06-10 06:10:31.708612 Failed to connect to all known addresses for host: ''
2015-06-10 06:10:26.700417 Failed TCP connection to all provided addresses for: :
2015-06-10 06:10:26.700417 Failed to connect to all known addresses for host: ''
2015-06-10 06:10:21.696483 Failed TCP connection to all provided addresses for: :
2015-06-10 06:10:21.696483 Failed to connect to all known addresses for host: ''
2015-06-10 06:10:16.684945 Failed TCP connection to all provided addresses for: :
2015-06-10 06:10:16.684945 Failed to connect to all known addresses for host: ''
2015-06-10 06:10:11.669305 Failed TCP connection to all provided addresses for: :
2015-06-10 06:10:11.669305 Failed to connect to all known addresses for host: ''
2015-06-10 06:10:06.653663 Failed TCP connection to all provided addresses for: :
2015-06-10 06:10:06.653663 Failed to connect to all known addresses for host: ''
2015-06-10 06:10:01.638794 Failed TCP connection to all provided addresses for: :
2015-06-10 06:10:01.638794 Failed to connect to all known addresses for host: ''
2015-06-10 06:09:56.634183 Failed TCP connection to all provided addresses for: :
2015-06-10 06:09:56.634183 Failed to connect to all known addresses for host: ''
2015-06-10 06:09:51.618543 Failed TCP connection to all provided addresses for: :
2015-06-10 06:09:51.618543 Failed to connect to all known addresses for host: ''
2015-06-10 06:09:46.555493 Failed TCP connection to all provided addresses for: :
2015-06-10 06:09:46.555493 Failed to connect to all known addresses for host: ''
2015-06-10 06:09:41.539853 Failed TCP connection to all provided addresses for: :
2015-06-10 06:09:41.539853 Failed to connect to all known addresses for host: ''
2015-06-10 06:09:36.477336 Failed TCP connection to all provided addresses for: :
2015-06-10 06:09:36.477336 Failed to connect to all known addresses for host: ''
2015-06-10 06:09:31.467067 Failed TCP connection to all provided addresses for: :
2015-06-10 06:09:31.467067 Failed to connect to all known addresses for host: ''
2015-06-10 06:09:26.463047 Failed TCP connection to all provided addresses for: :
2015-06-10 06:09:26.463047 Failed to connect to all known addresses for host: ''
2015-06-10 06:09:21.447407 Failed TCP connection to all provided addresses for: :
2015-06-10 06:09:21.447407 Failed to connect to all known addresses for host: ''
2015-06-10 06:09:16.440158 Failed TCP connection to all provided addresses for: :
2015-06-10 06:09:16.440158 Failed to connect to all known addresses for host: ''
2015-06-10 06:09:11.424517 Failed TCP connection to all provided addresses for: :
2015-06-10 06:09:11.424517 Failed to connect to all known addresses for host: ''
2015-06-10 06:09:06.408877 Failed TCP connection to all provided addresses for: :
2015-06-10 06:09:06.408877 Failed to connect to all known addresses for host: ''
2015-06-10 06:09:01.398945 Failed TCP connection to all provided addresses for: :
2015-06-10 06:09:01.398945 Failed to connect to all known addresses for host: ''
2015-06-10 06:08:56.383652 Failed TCP connection to all provided addresses for: :
2015-06-10 06:08:56.383652 Failed to connect to all known addresses for host: ''
2015-06-10 06:08:51.368012 Failed TCP connection to all provided addresses for: :
2015-06-10 06:08:51.368012 Failed to connect to all known addresses for host: ''
2015-06-10 06:08:46.355437 Failed TCP connection to all provided addresses for: :
2015-06-10 06:08:46.355437 Failed to connect to all known addresses for host: ''
2015-06-10 06:08:41.354361 Failed TCP connection to all provided addresses for: :
2015-06-10 06:08:41.354361 Failed to connect to all known addresses for host: ''
2015-06-10 06:08:36.338721 Failed TCP connection to all provided addresses for: :
2015-06-10 06:08:36.338721 Failed to connect to all known addresses for host: ''
2015-06-10 06:08:31.323079 Failed TCP connection to all provided addresses for: :
2015-06-10 06:08:31.323079 Failed to connect to all known addresses for host: ''
2015-06-10 06:08:26.307510 Failed TCP connection to all provided addresses for: :
2015-06-10 06:08:26.307510 Failed to connect to all known addresses for host: ''
2015-06-10 06:08:21.301795 Failed TCP connection to all provided addresses for: :
2015-06-10 06:08:21.301795 Failed to connect to all known addresses for host: ''
2015-06-10 06:08:16.296342 Failed TCP connection to all provided addresses for: :
2015-06-10 06:08:16.296342 Failed to connect to all known addresses for host: ''
2015-06-10 06:08:11.280700 Failed TCP connection to all provided addresses for: :
2015-06-10 06:08:11.280700 Failed to connect to all known addresses for host: ''
2015-06-10 06:08:06.265059 Failed TCP connection to all provided addresses for: :
2015-06-10 06:08:06.265059 Failed to connect to all known addresses for host: ''
2015-06-10 06:08:01.249419 Failed TCP connection to all provided addresses for: :
2015-06-10 06:08:01.249419 Failed to connect to all known addresses for host: ''
2015-06-10 06:07:56.234265 Failed TCP connection to all provided addresses for: :
2015-06-10 06:07:56.234265 Failed to connect to all known addresses for host: ''
2015-06-10 06:07:51.218623 Failed TCP connection to all provided addresses for: :
2015-06-10 06:07:51.218623 Failed to connect to all known addresses for host: ''
2015-06-10 06:07:46.205018 Failed TCP connection to all provided addresses for: :
2015-06-10 06:07:46.205018 Failed to connect to all known addresses for host: ''
2015-06-10 06:07:41.189377 Failed TCP connection to all provided addresses for: :
2015-06-10 06:07:41.189377 Failed to connect to all known addresses for host: ''
2015-06-10 06:07:36.173735 Failed TCP connection to all provided addresses for: :
2015-06-10 06:07:36.173735 Failed to connect to all known addresses for host: ''
2015-06-10 06:07:31.158096 Failed TCP connection to all provided addresses for: :
2015-06-10 06:07:31.158096 Failed to connect to all known addresses for host: ''
2015-06-10 06:07:26.148937 Failed TCP connection to all provided addresses for: :
2015-06-10 06:07:26.148937 Failed to connect to all known addresses for host: ''
2015-06-10 06:07:21.134680 Failed TCP connection to all provided addresses for: :
2015-06-10 06:07:21.134680 Failed to connect to all known addresses for host: ''
2015-06-10 06:07:16.126963 Failed TCP connection to all provided addresses for: :
2015-06-10 06:07:16.126963 Failed to connect to all known addresses for host: ''
2015-06-10 06:07:11.121846 Failed TCP connection to all provided addresses for: :
2015-06-10 06:07:11.121846 Failed to connect to all known addresses for host: ''
2015-06-10 06:07:06.106207 Failed TCP connection to all provided addresses for: :
2015-06-10 06:07:06.106207 Failed to connect to all known addresses for host: ''
2015-06-10 06:07:01.90564 Failed TCP connection to all provided addresses for: :
2015-06-10 06:07:01.90564 Failed to connect to all known addresses for host: ''
2015-06-10 06:06:56.74924 Failed TCP connection to all provided addresses for: :
2015-06-10 06:06:56.74924 Failed to connect to all known addresses for host: ''
2015-06-10 06:06:51.65632 Failed TCP connection to all provided addresses for: :
2015-06-10 06:06:51.65632 Failed to connect to all known addresses for host: ''
2015-06-10 06:06:46.56089 Failed TCP connection to all provided addresses for: :
2015-06-10 06:06:46.56089 Failed to connect to all known addresses for host: ''
2015-06-10 06:06:41.52488 Failed TCP connection to all provided addresses for: :
2015-06-10 06:06:41.52488 Failed to connect to all known addresses for host: ''
2015-06-10 06:06:36.36848 Failed TCP connection to all provided addresses for: :
2015-06-10 06:06:36.36848 Failed to connect to all known addresses for host: ''
2015-06-10 06:06:31.21207 Failed TCP connection to all provided addresses for: :
2015-06-10 06:06:31.21207 Failed to connect to all known addresses for host: ''
2015-06-10 06:06:26.5566 Failed TCP connection to all provided addresses for: :
2015-06-10 06:06:26.5566 Failed to connect to all known addresses for host: ''
2015-06-10 06:06:20.991862 Failed TCP connection to all provided addresses for: :
2015-06-10 06:06:20.991862 Failed to connect to all known addresses for host: ''
2015-06-10 06:06:15.983808 Failed TCP connection to all provided addresses for: :
2015-06-10 06:06:15.983808 Failed to connect to all known addresses for host: ''
2015-06-10 06:06:10.980205 Failed TCP connection to all provided addresses for: :
2015-06-10 06:06:10.980205 Failed to connect to all known addresses for host: ''
2015-06-10 06:06:05.964564 Failed TCP connection to all provided addresses for: :
2015-06-10 06:06:05.964564 Failed to connect to all known addresses for host: ''
2015-06-10 06:06:00.948923 Failed TCP connection to all provided addresses for: :
2015-06-10 06:06:00.948923 Failed to connect to all known addresses for host: ''
2015-06-10 06:05:55.933282 Failed TCP connection to all provided addresses for: :
2015-06-10 06:05:55.933282 Failed to connect to all known addresses for host: ''
2015-06-10 06:05:50.917006 Failed TCP connection to all provided addresses for: :
2015-06-10 06:05:50.917006 Failed to connect to all known addresses for host: ''
2015-06-10 06:05:45.910467 Failed TCP connection to all provided addresses for: :
2015-06-10 06:05:45.910467 Failed to connect to all known addresses for host: ''
2015-06-10 06:05:40.906820 Failed TCP connection to all provided addresses for: :
2015-06-10 06:05:40.906820 Failed to connect to all known addresses for host: ''
2015-06-10 06:05:35.891179 Failed TCP connection to all provided addresses for: :
2015-06-10 06:05:35.891179 Failed to connect to all known addresses for host: ''
2015-06-10 06:05:30.875538 Failed TCP connection to all provided addresses for: :
2015-06-10 06:05:30.875538 Failed to connect to all known addresses for host: ''
2015-06-10 06:05:25.859897 Failed TCP connection to all provided addresses for: :
2015-06-10 06:05:25.859897 Failed to connect to all known addresses for host: ''
2015-06-10 06:05:20.856057 Failed TCP connection to all provided addresses for: :
2015-06-10 06:05:20.856057 Failed to connect to all known addresses for host: ''
2015-06-10 06:05:15.845379 Failed TCP connection to all provided addresses for: :
2015-06-10 06:05:15.845379 Failed to connect to all known addresses for host: ''
2015-06-10 06:05:10.833235 Failed TCP connection to all provided addresses for: :
2015-06-10 06:05:10.833235 Failed to connect to all known addresses for host: ''
2015-06-10 06:05:05.817595 Failed TCP connection to all provided addresses for: :
2015-06-10 06:05:05.817595 Failed to connect to all known addresses for host: ''
2015-06-10 06:05:00.801954 Failed TCP connection to all provided addresses for: :
2015-06-10 06:05:00.801954 Failed to connect to all known addresses for host: ''
2015-06-10 06:04:55.786312 Failed TCP connection to all provided addresses for: :
2015-06-10 06:04:55.786312 Failed to connect to all known addresses for host: ''
2015-06-10 06:04:50.779319 Failed TCP connection to all provided addresses for: :
2015-06-10 06:04:50.779319 Failed to connect to all known addresses for host: ''
2015-06-10 06:04:45.770912 Failed TCP connection to all provided addresses for: :
2015-06-10 06:04:45.770912 Failed to connect to all known addresses for host: ''
2015-06-10 06:04:40.758587 Failed TCP connection to all provided addresses for: :
2015-06-10 06:04:40.758587 Failed to connect to all known addresses for host: ''
2015-06-10 06:04:35.742946 Failed TCP connection to all provided addresses for: :
2015-06-10 06:04:35.742946 Failed to connect to all known addresses for host: ''
2015-06-10 06:04:30.727306 Failed TCP connection to all provided addresses for: :
2015-06-10 06:04:30.727306 Failed to connect to all known addresses for host: ''
2015-06-10 06:04:25.711665 Failed TCP connection to all provided addresses for: :
2015-06-10 06:04:25.711665 Failed to connect to all known addresses for host: ''
2015-06-10 06:04:20.705530 Failed TCP connection to all provided addresses for: :
2015-06-10 06:04:20.705530 Failed to connect to all known addresses for host: ''
2015-06-10 06:04:15.694210 Failed TCP connection to all provided addresses for: :
2015-06-10 06:04:15.694210 Failed to connect to all known addresses for host: ''
2015-06-10 06:04:10.681881 Failed TCP connection to all provided addresses for: :
2015-06-10 06:04:10.681881 Failed to connect to all known addresses for host: ''
2015-06-10 06:04:05.666240 Failed TCP connection to all provided addresses for: :
2015-06-10 06:04:05.666240 Failed to connect to all known addresses for host: ''
2015-06-10 06:04:00.650598 Failed TCP connection to all provided addresses for: :
2015-06-10 06:04:00.650598 Failed to connect to all known addresses for host: ''
2015-06-10 06:03:55.634957 Failed TCP connection to all provided addresses for: :
2015-06-10 06:03:55.634957 Failed to connect to all known addresses for host: ''
2015-06-10 06:03:50.630198 Failed TCP connection to all provided addresses for: :
2015-06-10 06:03:50.630198 Failed to connect to all known addresses for host: ''
2015-06-10 06:03:45.620213 Failed TCP connection to all provided addresses for: :
2015-06-10 06:03:45.620213 Failed to connect to all known addresses for host: ''
2015-06-10 06:03:40.605062 Failed TCP connection to all provided addresses for: :
2015-06-10 06:03:40.605062 Failed to connect to all known addresses for host: ''
2015-06-10 06:03:35.589421 Failed TCP connection to all provided addresses for: :
2015-06-10 06:03:35.589421 Failed to connect to all known addresses for host: ''
2015-06-10 06:03:30.573779 Failed TCP connection to all provided addresses for: :
2015-06-10 06:03:30.573779 Failed to connect to all known addresses for host: ''
2015-06-10 06:03:25.558138 Failed TCP connection to all provided addresses for: :
2015-06-10 06:03:25.558138 Failed to connect to all known addresses for host: ''
2015-06-10 06:03:20.547584 Failed TCP connection to all provided addresses for: :
2015-06-10 06:03:20.547584 Failed to connect to all known addresses for host: ''
2015-06-10 06:03:15.537012 Failed TCP connection to all provided addresses for: :
2015-06-10 06:03:15.537012 Failed to connect to all known addresses for host: ''
2015-06-10 06:03:10.532858 Failed TCP connection to all provided addresses for: :
2015-06-10 06:03:10.532858 Failed to connect to all known addresses for host: ''
2015-06-10 06:03:05.517218 Failed TCP connection to all provided addresses for: :
2015-06-10 06:03:05.517218 Failed to connect to all known addresses for host: ''
2015-06-10 06:03:00.501577 Failed TCP connection to all provided addresses for: :
2015-06-10 06:03:00.501577 Failed to connect to all known addresses for host: ''
2015-06-10 06:02:55.485936 Failed TCP connection to all provided addresses for: :
2015-06-10 06:02:55.485936 Failed to connect to all known addresses for host: ''
2015-06-10 06:02:50.482974 Failed TCP connection to all provided addresses for: :
2015-06-10 06:02:50.482974 Failed to connect to all known addresses for host: ''
2015-06-10 06:02:45.467790 Failed TCP connection to all provided addresses for: :
2015-06-10 06:02:45.467790 Failed to connect to all known addresses for host: ''
2015-06-10 06:02:40.462855 Failed TCP connection to all provided addresses for: :
2015-06-10 06:02:40.462855 Failed to connect to all known addresses for host: ''
2015-06-10 06:02:35.448509 Failed TCP connection to all provided addresses for: :
2015-06-10 06:02:35.448509 Failed to connect to all known addresses for host: ''
2015-06-10 06:02:30.435504 Failed TCP connection to all provided addresses for: :
2015-06-10 06:02:30.435504 Failed to connect to all known addresses for host: ''
2015-06-10 06:02:25.419861 Failed TCP connection to all provided addresses for: :
2015-06-10 06:02:25.419861 Failed to connect to all known addresses for host: ''
2015-06-10 06:02:20.409623 Failed TCP connection to all provided addresses for: :
2015-06-10 06:02:20.409623 Failed to connect to all known addresses for host: ''
2015-06-10 06:02:15.404722 Failed TCP connection to all provided addresses for: :
2015-06-10 06:02:15.404722 Failed to connect to all known addresses for host: ''
2015-06-10 06:02:10.402217 Failed TCP connection to all provided addresses for: :
2015-06-10 06:02:10.402217 Failed to connect to all known addresses for host: ''
2015-06-10 06:02:05.393715 Failed TCP connection to all provided addresses for: :
2015-06-10 06:02:05.393715 Failed to connect to all known addresses for host: ''
2015-06-10 06:02:00.387261 Failed TCP connection to all provided addresses for: :
2015-06-10 06:02:00.387261 Failed to connect to all known addresses for host: ''
2015-06-10 06:01:55.383069 Failed TCP connection to all provided addresses for: :
2015-06-10 06:01:55.383069 Failed to connect to all known addresses for host: ''
2015-06-10 06:01:50.381943 Failed TCP connection to all provided addresses for: :
2015-06-10 06:01:50.381943 Failed to connect to all known addresses for host: ''
2015-06-10 06:01:45.377036 Failed TCP connection to all provided addresses for: :
2015-06-10 06:01:45.377036 Failed to connect to all known addresses for host: ''
2015-06-10 06:01:40.364430 Failed TCP connection to all provided addresses for: :
2015-06-10 06:01:40.364430 Failed to connect to all known addresses for host: ''
2015-06-10 06:01:40.364430 Client restarted successfully
2015-06-10 06:01:39.796458 Restarting due to configuration change
2015-06-10 05:56:03.788590 Failed to establish a data proxy connection. Receiver data cannot be sent!
2015-06-10 05:56:03.787588 Failed to connect to all known addresses for host: 'dataupload.planefinder.net'
2015-06-10 05:52:18.298916 Echo port is now listening on: http://192.168.1.103:30054
2015-06-10 05:52:18.283291 Web server is now listening on: http://192.168.1.103:30053
2015-06-10 05:52:18.80166 We were unable to locate a configuration file and have entered configuration mode by default. Please visit: http://192.168.1.103:30053 to complete configuration.
kucengemok
Are you seeing planes on a map? - No
Can you post the full log please? - Yes
What is the client connecting to? By the looks of the config it is Dump1090 on the local machine? - use adsb dongle..
Thanks, you certainly have something funny with your local config going on there. You have it set to Beast format but connecting to port 30003. I don't know what you are connecting to from our client but from the log the connection is not right.
I would try "Beast" format first with port number 30005 and if that fails then "30003 Basestation" format connecting to port 30003
kucengemok
what about Tcp Address? what address should i use? 127.0.0.1?
kucengemok
sorry...just remove it. could not secure the connection to server - dataupload.planefinder.net
127.0.0.1 with beast 30005 and base 30003..
That message can be ignored. I can see your client talking to the server so it was a one off. The time is a long time ago.
Are you seeing planes on a map yet?
airbus340
I installed the beta version yesterday and it works great. One question, it said if I use a dongle I should use beast mode but I selected Basestation instead as I also run VRS and VRS to my own website. What would the difference be if I changed to Beast mode? More messages or better for your uploading to Planefinder?
I only selected Basestation as I am not very good at computers and with that selected all was configured to port 3003 and ready to rock right away.
I think VRS can output Beast format data and yes this is preferable!
We decode extra info from that as the 30003 format is quite old and does miss some info such as category type and auto pilot information.
