Plane Finder Pi not sending data!
rakeshvanamali
Some 10 days ago, my PF Pi (running Bullseye) stopped working
I put the SD card into a different PI, connected it to a different ADSB antenna, connected it to a different RTLSDR, did sudo apt update. But, nothing worked
So, I formatted the card, installed Bookworm, and created a new config.json file in which I added my existing PH share code + LAT & LONG
And, then, I installed the PF 5.0.161 client and pressed the Enter key to accept the default (keep the current version of the config file)
Then rebooted the Pi and restarted the PF client. But, no planes on the map!
So, I installed dump1090-fa, rebooted the Pi, and restarted the PF client. But, still no planes on the map!
The Pi shows connected to the PF network but is not sending data
