PlanePlotter v6.3.9.1 now available
Mark Daniels
PlanePlotter version 6.3.9.1 is now available for download:
http://www.coaa.co.uk/planeplotter6_3_9_1.exe
This one includes a nice new button to make it even easier to share your data with Plane Finder. You can find this via --> Options--> Share -->Setup
Please let us know that you are doing this and also please don;t forget to ask for some free apps!
New in version 6.3.9.1
Users operating as SMUs can use the OLE/COM interface to check on the SMU operation.
A problem with sorting the signal strength column in View-Aircraft has been fixed.
The Find command has been extended. If the machine is online, and if the chosen aircraft is not found in the local data, it will be escalated to the server and data for that aircraft will be retrieved if available at the time.
PlanePlotter now takes care of heading reports expressed in Magnetic degrees. Some aircraft use magnetic headings when on the ground and PP now plots the aircraft symbols correctly in this case.
A problem whereby SMUs get stuck not perfoming their role, has been fixed.
Prospective users who have already exhausted their 21 day trial period can enjoy a further 21 days trial with this version.
