PlanePlotter v6.4.1.6 now available
Mark Daniels
PlanePlotter version 6.4.1.5a is now available for download:
http://www.coaa.co.uk/planeplotter6_4_1_6.exe
It is really easy to share your data with Plane Finder. You can find this via --> Options--> Share -->Setup
Please let us know that you are doing this and also please don't forget to ask for some free apps!
New in version 6.4.1.5
  • on the y display, the permanent dots nw match the snowflakes
  • fix crash on TCAS alert
  • signal strength shows in MySky if enabled
  • VDL2 stops TCP receiver input (NFF)
  • TCAS alert shows aircraft identity
  • problem with target altitude via OLE/COM
  • Help..Test networking option to check "ntpq -p"
  • if the toolbar is at the bottom, pop up windows are displaced (NFF)
  • MultiPSK server on another IP address:port
