I have install fr2feed under Ubuntu Linux. The problem is that although the Plane Finder Client, which is running also on the same PC with fr24feed (linux machine), is connected it is not receiving any data, if I am using Plane Finder Client only with dump1090 on port 30005 and data as Beast it takes data perfectly.
how can I use both clients at the same time
Thank you
Pericles
Thank you
Pericles
