Removing AVR parity
StephenEGC
Hi All,
Hopefully someone may be able to help me here.
I am running and AirNav radar box and have set both MM2 and VRS to receive Beast, Raw and SBS data on the three data ports.
I have used the required configuration and arguments in the setup to reformat these data ports in VRS and MM2 to output AVR on three different TCP posts
from the local host. I want to use an upstream software tool to overlay the data onto a GUI map, however the upstream application will only receive AVR format with zero parity.
Is there any external application/s that I can run on either armbian (jessie 8.8) and pi boards (buster?)?
Open to suggestions or alternate options that will assist in reformatting the data stream.
Thanks in advance.
