I've only just re-installed this after a long time away (Over a year) and installed the newer client etc.
On the log view i get the above message, but I only run this on one PC.
Any ideas?
2018-03-22 11:13:03.106701 [!] Data upload failed with error: 'Sharecode in use on multiple machines - please create a new sharecode for each client - do not re-use! Contact support@planefinder.net for more info.
2018-03-22 11:12:32.791063 [-] Successfully sent 322 aircraft updates across 10 packets (31.00KB)
2018-03-22 11:12:12.563756 [-] Successfully sent 356 aircraft updates across 11 packets (34.00KB)
2018-03-22 11:12:02.411446 [!] Data upload failed with error: 'Sharecode in use on multiple machines - please create a new sharecode for each client - do not re-use! Contact support@planefinder.net for more info.
2018-03-22 11:10:51.501863 [-] Successfully sent 399 aircraft updates across 12 packets (37.00KB)
2018-03-22 11:10:41.402403 [!] Data upload failed with error: 'Sharecode in use on multiple machines - please create a new sharecode for each client - do not re-use! Contact support@planefinder.net for more info.'
2018-03-22 11:10:31.329421 [!] Data upload failed with error: 'Sharecode in use on multiple machines - please create a new sharecode for each client - do not re-use! Contact support@planefinder.net for more info.'
2018-03-22 11:10:21.251986 [!] Data upload failed with error: 'Sharecode in use on multiple machines - please create a new sharecode for each client - do not re-use! Contact support@planefinder.net for more info.'
2018-03-22 11:10:21.173481 [-] Successfully sent 332 aircraft updates across 10 packets (31.00KB)
2018-03-22 11:10:11.185470 [!] Data upload failed with error: 'Sharecode in use on multiple machines - please create a new sharecode for each client - do not re-use! Contact support@planefinder.net for more info.'
2018-03-22 11:10:01.88878 [!] Data upload failed with error: 'Sharecode in use on multiple machines - please create a new sharecode for each client - do not re-use! Contact support@planefinder.net for more info.'
2018-03-22 11:09:51.11860 [!] Data upload failed with error: 'Sharecode in use on multiple machines - please create a new sharecode for each client - do not re-use! Contact support@planefinder.net for more info.'
2018-03-22 11:09:40.939621 [!] Data upload failed with error: 'Sharecode in use on multiple machines - please create a new sharecode for each client - do not re-use! Contact support@planefinder.net for more info.'
2018-03-22 11:09:30.856234 [!] Data upload failed with error: 'Sharecode in use on multiple machines - please create a new sharecode for each client - do not re-use! Contact support@planefinder.net for more info.'
2018-03-22 11:09:20.784642 [!] Data upload failed with error: 'Sharecode in use on multiple machines - please create a new sharecode for each client - do not re-use! Contact support@planefinder.net for more info.'
2018-03-22 11:09:10.707497 [!] Data upload failed with error: 'Sharecode in use on multiple machines - please create a new sharecode for each client - do not re-use! Contact support@planefinder.net for more info.'
2018-03-22 11:09:00.341123 [!] Data upload failed with error: 'Sharecode in use on multiple machines - please create a new sharecode for each client - do not re-use! Contact support@planefinder.net for more info.'
2018-03-22 11:08:50.254070 [-] Successfully sent 348 aircraft updates across 10 packets (32.00KB)
2018-03-22 11:08:40.142963 [-] Successfully sent 347 aircraft updates across 10 packets (32.00KB)
2018-03-22 11:07:09.145719 [-] Successfully sent 336 aircraft updates across 10 packets (32.00KB)
2018-03-22 11:06:59.5712 [-] Successfully sent 335 aircraft updates across 10 packets (32.00KB)
2018-03-22 11:06:18.511118 [!] Data upload failed with error: 'Sharecode in use on multiple machines - please create a new sharecode for each client - do not re-use! Contact support@planefinder.net for more info.'
Any ideas?
