Small Problem with PIAware Linux Client
Nigel Ambridge
Hi All,
I have a small number of RPi receivers all at remote sites & access to them is limited to console (SSH)
These clients all require sharing codes but I've tried a few command line browsers such as Lynx / Links
/elinks but even after I input the data to create a new share code then nothing is returned via email , also the config file is not populated
One solution would be I guess to use the External IP Address of the remote unit(s) but this would involve re configuring firewalls which is a bit of a pain ;) another option is to edit the config file & manually input the parameters but this would not resolve the problem of generating a sharing codes
If anyone has some work around's for this problem then please let me know :)
BTW
Mods - if this is posted to the wrong area then please move it :)
Nigel
Hi Nigel,
What you could do is install a client locally and that will generate a share code and also a config.
Then you could upload these configs?
You can repeat the setup of your local client by deleting the config file generated.
Lee
Hi Lee,
Sounds like a plan , I'll give it a try later
Nigel
BTW - you might actually like to open the firewalls as the client is pretty good and exposes more info that other clients don't such as the auto pilot info.
A bit more advanced but SSH tunnelling?
Nigel Ambridge
Am in the office today so if you want to give me some details on SSH Tunnelling with the client I can get OpenSSH
installed on the RPi here & give it a test ;)
There are a ton of ways to do it so I would just suggest you Google and read about a bit. It's one of those things I think should be read up on as its your security at the end of the day!
