THREE EASY ANTENNAS FOR BEGINNERS
3 EASY ANTTENNAS FOR BEGINNERS
The main disadvantages of stock antenna supplied with DVB-T USB Dongle are:
(1) It has a very short lead. Due to this, in most cases the antenna cannot be placed at an optimum location.
(2) The stock antenna is not optimized for 1090 Mhz.
SOLUTION FOR PROBLEM (1):
The short cable length can be overcome by connecting a MCX to F pigtail to the DVB-T USB Dongle, and connecting to the pigtail, the required length of commonly available RG6 cable with a DIY antenna at other end of RG6 cable.
Tip:
(a) For RG6 coax lengths in excess of 5m/15ft, coax attenuation will be high, and an amplifier may become necessary.
(b) Even with short lengths of Coax, use of amplifier increases plane count & range.
SOLUTION FOR PROBLEM (2):
The non optimized antenna can be replaced by a DIY antenna which has a ¼ wavelength vertical whip connected to core of coax cable, and a ground plane connected to shield of coax. The ground plane can be formed by a disc, a number of horizontal radials, a number of slanting radials, or a food/drink can.
Below are 3 different easy antennas for beginners: Spider, Platenna & Cantenna.
These all have a ¼ wavelength vertical whip connected to core of Coax cable, but use different methods of providing ground plane connected to shield of coax
EASY ANTENNA # 1 : SPIDER
Parts Required:
1. SO-239 Connector
2. PL-259 UHF to F adapter (to connect RG6 coax to SO-239 Connector)
3. Copper wire pieces 10 cm long - 5 pieces for 4 Leg Spider, 9 pieces for 8 Leg Spider.
4. Small Nuts & bolts 4 pieces for fixing wires at 4 corners of SO239 adapter
Schematic & Dimensions
Finished Antenna 4 Legs (Does not require soldering)
Built by jepolch
http://forum.planefinder.net/threads/ads-b-diy-antenna.23/page-31
Built by beckerm13 http://discussions.flightaware.com/post153170.html#p153170
Finished Antenna 8 Legs (Requires Soldering - Performs better than 4 Legs)
Built by autok
http://www.atouk.com/wordpress/?page_id=237
EASY ANTENNA #2 : CANTENNA
Please see below photos, showing construction details.
Completed Cantenna
Designed & Built by Author of this post (abcd567)
The whip at top is ¼ wavelength i.e. 69mm (see dimension drawing below)
The whip is core wire of coax cable.
It can be bare copper wire OR copper wire + core insulation.
Shield (braid+foil) MUST be removed from the whip.
VRS Coverage
The range rings are 50 nm apart, the outermost blue ring is 300 nm from the receiver.
HOW TO MAKE
Image 1 of 4 : Construction Details 1
Image 2 of 4 : Construction Details 2
Image 3 of 4 : Construction Details 3
Image 4 of 4 : Fully Assembled
DIMENSIONS
Sketch 1 of 2: Pepsi Can Dimensions
Sketch 2 of 2: Whip Measurements.
Any one of the two connectors shown in the sketch below can be used
Test Setup for CANTENNA
Picture 1 of 2
Cantennas using other types of cans:
Built by giacomo1989 http://forum.planefinder.net/threads/ads-b-diy-antenna.23/page-25#post-1530
Built by jepolch http://forum.planefinder.net/threads/ads-b-diy-antenna.23/page-74#post-2607
EASY ANTENNA # 3 : PLATENNA
The indoor antenna shown below is very easy to make without any special tools
or special parts. It uses a pie plate made of aluminum foil as ground plane (disc), a 68mm (finished
length) whip made of core of coax, and a cheap & readily available coax F-type barrel connector with nut &
washers.
Completed Platenna
Designed & Built by author of this post (abcd567)
Maximum Range Achieved: 250 nm
Range Rings are 50 nm apart. Outermost ring is 300nm radius
HOW TO MAKE:
1. Collect the Stuff
One Large Pi Plate made of Aluminum foil.
One Coax cable connector (barrel connector) with one nut & 2 washers
2. Assemble the Platenna
The whip at top is ¼ wavelength (69mm)
Whip Measurements.
Need to solder the rod?
NO, do not solder the rod to F Type Barrel Connector
After inserting the rod, you may use a drop of hot melt glue or silicone adhesive to fix the rod if you like, but these are not necessary
YES, solder the rod to F Type Panel Mount / Bulk head
YES, solder the rod to SO239
SIMULATION OF 2 DIY ANTENNAS
Simulation 1 of 2: SPIDER (8 Legged )
Gain = 1.7 dBi
SWR (75 ohms) = 1.3
Simulation 2 of 2: CANTENNA
Gain = 1.9 dBi
SWR (75 ohms) = 1.5
Excellent link. Part of the fun is trying things especially when they cost very little. I have a serious question for you : can i use a beer can instead of Pepsi ? :rolleyes: If so I will have to empty one.
AB CD , by reviewing your post I realize that ADSBSCOPE is a must to validate our work. I got the excellent installation instructions by ''sonicgoose'' to do it. (The user name sounds like he lives in north america and close to an airport........)
My first quick try did not work..... Not receiving anything. I am on Window 10 and using an un-tried usb dongle so I will have to do some verifications.
Have a great day, and again thanks for the moral support.
Eleventeen
I'm currently using a spider built on a solder-on female BNC connector. I have a whole bag of these, but unfortunately, they aren't panel mount style, where it would be easy to screw or solder in the radials. Fortunately, this is easily fixed by adding a 5/8" stainless washer that I've drilled mounting holes into:
I also asked my wife to start saving cans to build a cantenna...there's a olive can we used recently that I believe has suitable dimensions.
Welcome to the wire bender's club.
F1Rocket
Thanks to "blueskyspotter" for this antenna concept. To date the FA antenna is in fourth place behind the cantenna, soldered 8 leg spider, and by this "complicated" spider in first place. The construction alone of this antenna may be the reason it is 10-20% better than the soldered spider. Thanks to all for sharing ideas and providing direction.
Welcome to the Crazy Bandwagen of DIY Antennas
I have seen this photo of your "Complicated Spider" when you posted it on Flightaware forum few days ago. Nice built. I think in FA forum, you have mentioned that you will apply brass tubes over the Spider legs & the whip.
Eleventeen
I like this design, what are the terminals that attach the radials? They look to me like ground rod terminals, but I have not seen one like that locally that has the side tab on it like that.
F1Rocket
Terminals were bought at Home Depot. I think $1.77 for a bag of two.
Brand is: Thomas & Betts, Part # L35-B2 Terminal Lug.
k3who
I have been using a home brew 1/4 wave ground plane but I decided to try the cantenna.... And I had a tin lid laying around so I figured I'd try that too. So far the cantenna is doing slightly better than my 1/4 wave. Haven't tested the tin lid yet.
AlfySande
Hi...i am a new user here. I have a TP-LINK TLGWN722N WiFi USB adapter. The adapter has a connector on it so you can attach different external antennas to it. The manufacturer's website states the connector is RP-SMA. However, I think the connector is very small; it's 3/16 inches in diameter. I would assume the connector is female since it's reverse polarity and has a pin in the middle of the connector.Would just buying a cable that's RP-SMA male allow me to connect to it?
https://www.7pcb.com/
