AnirbanSen
A difference of 0.07-0.08V.
Connect the negative/ground terminals of the power supplies for the RPi and bias-t.I have been unable to pinpoint to the cause.
sudo bash -c "$(wget -q -O - https://raw.githubusercontent.com/wiedehopf/adsb-wiki/master/rtl_test.sh)"
Normally, that should happen as the circuit shares a common ground. But perhaps I'll need a short just in case.Connect the negative/ground terminals of the power supplies for the RPi and bias-t.
If there is a potential difference, then it doesn't go via the dongle and should help with your problems.
Edit: I'm a little confused, that thing displaying 13.2 V is simultaneously supplying 5V via USB?
Noted. But the dongle also gets very hot. Will the foil trap the heat to help dissipate it. Will foil it and keep it away.Also don't put the cables going to the bias-t so close to the dongle.
(Maybe just put aluminium foil around the dongle, maybe that will help)
RTRealtek, RTL2838UHIDIR, SN: 00000001Have you checked which tuner that dongle has?
It should be somewhere in the output of this script of mine:
(iv) rtl_test -t showed that both dongles are otherwise fine when tested on a freshly booted system.
Using device 0: Generic RTL2832U OEM
Detached kernel driver
Supported gain values (29): 0.0 0.9 1.4 2.7 3.7 7.7 8.7 12.5 14.4 15.7 16.6 19.7 20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48.0 49.6
[R82XX] PLL not locked!
Sampling at 2048000 S/s.
No E4000 tuner found, aborting.
Reattached kernel driver
Can a single 2.2mH inductor work for both the BiasT and the RPi? They share the main step down source.If DC on the center conductor to the stick is indeed blocked by the capacitor, then this shouldn't be a problem.
You can also fit both power supplies with extra smoothing if you want.
The coil/inductor goes in series with the positive line of the power supply.
The capacitor goes across + and - on the side of the load (pi or bias-t).
So the positive cable coming from the power supply to the RPi for example is interrupted, you insert the coil.
Do the same with the supply for the bias-t.
Then the capacitor is in correct polarity connected across + and - on the side of the load, not towards the power supply.
This is an LC filter to reduce ripple.
Yeah heat is a problem.Noted. But the dongle also gets very hot. Will the foil trap the heat to help dissipate it. Will foil it and keep it away.
That's interesting.3) DVB-T Ground and RPi Ground: 0.07 - 0.08V [Again, the tuner stick does not share a common ground perhaps - is this true?]
So, just some feedback on this amp.
Mine is on its way now. Cost was USD 26. Also, someone keeps turning the Handy Spider on the roof. Wondering which kind of antenna would be more solid and tamperproof. Is a collinear likely to yield better result? You've mentioned previously that it does not necessarily give good results. And especially since I don't have a VNA. I'm almost tempted to buy a nanoVNA now but given the limited use, it would be a waste of money.I have RTL-SDR Tripple Filtered LNA. Eliminates Cell/Mobile signals.
Note:
The Bias-T and DC adapter in the photo are NOT supplied with the LNA. I have purchased these separately
View attachment 2965View attachment 2966
