Upgrade my Pi and clients
mobisat
Currently my setup consists of using a Pi model B+, pfclient 3.3.222, dump 1090, cheap Chinese dongle and whatever else I put on it at the time (it's been a while).
I am going to replace it with a Pi 3 model B+, latest client, dump 1090-mutability, Flightaware Pro Stick Plus v1.0
I upload to Flightradar24.com and something else maybe? Only really concerned about FR24 I think.
How can I find my site identifiers etc. off my current system to add to my new one that will replace it? Or can I just link new one straight onto my accounts and delete the old one once I've proved it's working?
Thanks in advance.
The advise given by Lee Armstrong carries weight, and I strongly recomment it.
However just in case someone forgets his sharing code, he can retrive it by following method:
SSH to RPi and give following command:
cat /etc/pfclient-config.json
The above command will display following long text. Scroll right. Continue scrolling right till you reach end of text, and the share code will be there at the end.:)
{"tcp_address":"127.0.0.1","tcp_port":"30005","select_timeout":"10","data_upload_interval":"10","connection_type":"1","aircraft_timeout":"30","data_format":"1","latitude":"xx.xxxx","longitude":"yy.yyyy","sharecode":"zzzzzzzzzzzz"}
