Virtual Radar Server -> Plane Finder Client
Annunaki
Hi guys 1st I'd like to thank you for this excellent service and thank you for upgrading my subscription for sharing my feeds much appriciated.
Currently I have the Plane Finder client directly connecting to ADSB# however I would like to be able to use VRS to rebroadcast the data from ADSB# directly to the PFC (on the same machine) just like I have VRS doing with other flight tracking services but I'm not having much luck.
I wonder if someone could point me in the right direction?
So far i've tried
In VRS I have setup a AVR rebroadcast server to the PFC on local ip/port (127.0.0.1:30054) which does connect to fine and transfers whatever data and I've removed the connection to ASDB# in the PFC web setup but this is not working or displaying any flight data and in my log its spamming:
2020-04-21 19:22:19.550802 [-] Failed TCP connection to all provided addresses for: :
2020-04-21 19:22:19.550659 [!] Failed to connect to all known addresses for host: ''
Maybe I'm over thinking this but I did not have any issues setting up VRS rebroadcast servers for other flight tracking services.
Thanks for any pointers.
Annunaki
Ok sorry to be so hasty to post but I have just figured it out.
I had VRS set to push the data rather than wait for a connection from the PFC and I also had to enable in VRS Pass-Through format rather than AVR.
Seems to be working fine now.
