We were unable to place your client into configuration........
Rick Brown
Chaps.
I received the dreaded email to say my feed was no longer, erm, feeding this morning.
No idea why as I feed various other sites from the same RPi.
Anyway, I went to my account page and noticed that the feed was listed as "Inactive".
Checking the logs there was an entry for invalid share key.
I guess this is the problem then?
How do I create a new key?
If I go into:
myip:30053 and try to enable config mode I get the following message:
"We were unable to place your client into configuration mode. Please try again"
I've tried to reboot the RPi, just the same.
I've tried to remove the client completely from the RPi and reinstall. Just the same.
I've removed receiver in my account and run the install again and then when I go into :30053 it shows my old receiver and I still get the same message:
I should add that my other receiver is working fine.
Also, if I go to myip:30053 I still see the map with aircraft plots.
Can anyone shed any light on this one?
Rick.
Rick Brown
Update.
I've built a new RPi and setup a new share key.
I was able to configure the receiver correctly.
Once!
Now when I try to edit it again I get the same message!
Please, anybody suggest a fix?
Rick.
Mark Daniels
Hi Rick,
I do see an active feed so I think that you are entering the incorrect code for the running client/receiver.
I've emailed you directly with what I think is the correct code.
Thanks as always for sharing.
Mark
